Food Smokers and Smoking Tips/Tricks/Techniques
Discussion in 'Food Talk' started by Polymerhead, Jul 15, 2012.
  1. Nov 15, 2019 at 6:52 PM
    uhplifted
    uhplifted The Hopfather
    Brian
    Huntington Beach, CA
    16 DCLB OR
    Costco has full packers again!!!!
  2. Nov 15, 2019 at 8:03 PM
    uhplifted
    Brian
    16 DCLB OR
    2 tri tips goin on shortly
  3. Nov 15, 2019 at 9:58 PM
    uhplifted
    Brian
    16 DCLB OR
    Holy shit unicorn is really good on the tri tip
  4. Nov 15, 2019 at 10:04 PM
    Bigdaddy4760
    Maner
    Poolville Texas
    Yes it is
  5. Nov 16, 2019 at 2:42 AM
    nobescare
    nobescare Well-Known Member
    Mark
    43.5448° N, 80.2482° W
    2019 Highlander SE
    My 2005 prerunner had frame failure Aug 2024
    Doing a brisket for family tonight on the Weber kettle. Light coat of yellow mustard and Keg seasoning. Mesquite and Hickory. 4.4kg/10.3lb. Went on at 5;30 this am
    I think I'm gonna be fighting with the weather all day. Expected high is -5
    20191116_053239.jpg 20191116_052141.jpg 20191116_053239.jpg 20191115_190953.jpg Screenshot_20191116-052022_WTForecast.jpg
  6. Nov 16, 2019 at 3:30 AM
    Inoculum
    Inoculum Well-Grown Member
    Parts Unknown
    16’ Limited
    I’ve got a GMG pellet smoker. Something goes on it every Sunday
  7. Nov 16, 2019 at 5:05 AM
    AustinMada
    AustinMada Thinking About Tacos
    WA.
    19 DCSB OR
    49 days dry aged sirloin
  8. Nov 16, 2019 at 6:41 AM
    Cold Iron
    Cold Iron Well-Known Member
    Mn.
    2013 AC T|X Baja
    Both @Aloha Scout and @JeffRoyJenkins on here are running PBC's and have posts in this thread. They work well.
    Dedicated smoking sites often have debates about which is better a Pit Barrel Cooker or a Ugly Drum Smoker. Do a search for PBC vs UDS. They both work well and have pros and cons. But bottom line is don't think you can go wrong with a PBC.
    I put a Cajun Bandit stacker on my WSM and purchased a hanging rack for a UDS then skewers from PBC. Kind of a hybrid of a bullet smoker, PBC and UDS. With an ATC to control temperature.
    For when I feel like the flavor profile of meat cooked directly over coals with juices dripping on them smoking to flavor the meat.
    :thumbsup: After 9 straight days of not getting above freezing finally going to get up to -5° C for a high here too!
    A friend of mine smokes all winter long with a 26" Kettle even down to -30° C. He says that the 26" works better than a 22" when it is colder because he can add more fuel. But it takes more fuel with a larger kettle also, it is almost 150% in surface area larger.
    I use my kettle to smoke often in the summer but really haven't done it once it gets below freezing I end up using the WSM then. I expect you are correct and will be adding a lot of fuel through the day. Good luck and am sure it will turn out fantastic!
    And thanks for the smile! :D
  9. Nov 16, 2019 at 7:53 AM
    Captdan762
    Captdan762 Well-Known Member
    Dan
    Kentucky/ Tennessee
    09 Tacoma TRDOR (sold)/ 17 T4R OR 2020 Tundra
  10. Nov 16, 2019 at 8:05 AM
    tntacomaguy
    tntacomaguy Well-Known Member
    Doing my first pork spare ribs right now. Are they done basically like other racks of ribs or is there anything I need to know about them?
    Coated in Pit faced spicy
    edit no clue why the pics are sideways
  11. Nov 16, 2019 at 8:21 AM
    WBF610
    WBF610 Member well known
    Carey
    Eastern PA
    2016 DC OR
    mats, flaps, and stickers. Extang solid fold 2.0. Mobtown sliders and full skids. AVS vents
    You can just leave them on the pit till they are are done, or do the 3-2-1 method.
  12. Nov 16, 2019 at 10:12 AM
    tntacomaguy
    2hrs in
    anyone know why my pics won’t upload correctly? They are upright on my phone but won’t upload and I can’t find if I can rotate once uploaded
  13. Nov 16, 2019 at 11:04 AM
    WBF610
    Carey
    Eastern PA
    2016 DC OR
    What method you decide upon?
    Bigdaddy4760 likes this.
  14. Nov 16, 2019 at 11:40 AM
    tntacomaguy
    Just gonna leave them in til done. I rarely wrap anything anymore.
  15. Nov 16, 2019 at 12:02 PM
    relkins0413
    relkins0413 Well-Known Member
    Kings Mountain, NC
    2013 Silverado 2500HD Duramax
    Giggity
  16. Nov 16, 2019 at 1:16 PM
    JeffRoyJenkins
    JeffRoyJenkins Essentially Non-Essential
    Jeff
    Lake Stevens, WA
    2024 F-150 XLT PowerBoost
    Mine was my first jump into charcoal smoking and has made some really good food. It takes a little experimentation to learn what it does well and what it's not so great for. I typically only fire it up for cooking 8-10+ lbs of meat because it's a bit to get going for anything smaller.
    You also have to learn to just let it run because you will go mad trying to maintain temp. There is really no adjustment and through the cook the temps will climb and fall seemingly at random. Just start it up, throw in your meat and watch the meat temp until it's done.
    It has made some absolutely amazing ribs, pork belly burnt ends and al pastor pork among other stuff. I still haven't gotten brisket the way I would like on it but I have struggle with it on the Weber kettle too. I'm going to try my first turkey on it tomorrow so we will see how that goes.
    wilcam47 and Bigdaddy4760 like this.
  17. Nov 16, 2019 at 2:31 PM
    Captdan762
    Dan
    Kentucky/ Tennessee
    Awesome, thanks for the feedback. What you are using it for will be the same I do. Just taught for the price I might add it to the collection. That is the main complaint I have heard is keeping the temp regulated and it doesn’t really cook at a low temp.
  18. Nov 16, 2019 at 2:35 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    My phone will ask if I want to change the size of the photo when I add it into posts on this forum. If I don’t click “keep actual size,” it’ll rotate the photo for some reason. Might be your issue also?
    The forum software automatically resizes photos, so I just keep it full size each time. In case anybody else has or maybe doesn’t have this issue, my phone is an iPhone 11 Pro Max. Didn’t happen on my old iPhone 7 Plus, so not sure what changed besides (assumedly) the file size of the pics.
    tntacomaguy[QUOTED] likes this.
  19. Nov 16, 2019 at 2:38 PM
    relkins0413
    Kings Mountain, NC
    I just noticed this issue last night. I had been resizing my photos before and hadn’t had that issue. I have an iPhone X but haven’t upgraded recently.
    T4RFTMFW[QUOTED] likes this.
  20. Nov 16, 2019 at 2:39 PM
    T4RFTMFW
    Wonder if the forum software had an update then! @tcBob
