Food Smokers and Smoking Tips/Tricks/Techniques
Discussion in 'Food Talk' started by Polymerhead, Jul 15, 2012.
  1. Jan 7, 2020 at 10:24 AM
    Zeke588
    Zeke588 Well-Known Member
    Zeke
    Billings, Mt
    Bluerunner
    03 V8 limited
    Too much $$$ Probably make a UDS that has a side door that doubles as a vertical spit. I can make a small mounting plate on the outside at the bottom of the door too set the bottom of the spit. I have plenty ideas just need to find the right drum or keg and get to work on it on my lunch breaks.
  2. Jan 7, 2020 at 11:06 AM
    Kanyon71
    Kanyon71 Well-Known Member
    MI
    If you do that I would suggest making the side hinged so you can open, slice, close and continue cooking. :)
    Zeke588[QUOTED] and Bigdaddy4760 like this.
  3. Jan 7, 2020 at 11:16 AM
    itzyoboipaul
    itzyoboipaul Well-Known Member
    Paul
    PFville, TX
    2020 TRD OR Cement
    Nice. I know some got canceled. Some got theirs.
    My only order (last picture) for one tp15 hasn’t been cancelled YET. Says arriving Thursday
  4. Jan 7, 2020 at 11:56 AM
    Zeke588
    Zeke
    Billings, Mt
    Bluerunner
    03 V8 limited
    Yep. Found an old brinkmaster electric drum smoker on craigslist here. Probably use that for parts.
  5. Jan 7, 2020 at 11:57 AM
    Kanyon71
    MI
    Make sure you take some pics. I'm interested to see how it all comes out. Might copycat you at some point. Wife and I really like chicken shawarma.
    wilcam47 and Zeke588[QUOTED] like this.
  6. Jan 7, 2020 at 12:00 PM
    Zeke588
    Zeke
    Billings, Mt
    Bluerunner
    03 V8 limited
    Also found this. Not a smoker but still pretty cool.
    bvbull200 likes this.
  7. Jan 7, 2020 at 2:52 PM
    bvbull200
    bvbull200 Well-Known Member
    Bryan
    DFW, Texas
    2013 DCSB SR5 Prerunner Texas Edition
    Fresh wiper fluid
    A little higher heat for the bacon, maybe, but that thing looks great! Especially for a first try. I think most of my first one ended up falling through the grates. :laugh:
  8. Jan 7, 2020 at 2:56 PM
    bvbull200
    Bryan
    DFW, Texas
    Fresh wiper fluid
    Not sure if he still has it since it was about 5 years ago, but there is a guy not too far from me that made an R2D2 UDS. He was providing us with little rubber plugs with pass-thru for temp probes. It was a neat drum. Dude was a major enginerd.
  9. Jan 8, 2020 at 6:43 AM
    jmdaniel
    jmdaniel Has A Well Known Member
    Jeff
    Leander, TX
    2018 Tundra SR5 CrewMax, 1977 FJ40 Landcruiser
    Jump start the bacon cook in a microwave before weaving. Not very long, but enough to have it finished when your fatty hits the internal temp.
  10. Jan 8, 2020 at 8:53 AM
    Zeke588
    Zeke
    Billings, Mt
    Bluerunner
    03 V8 limited
    So what are y'all using in these fattys. Might have to try it this weekend. Temp and times as well!
    bvbull200 and wilcam47 like this.
  11. Jan 8, 2020 at 8:54 AM
    Kilo Charlie
    Kilo Charlie One flat foot on the Devil's wing
    Iowa
    2017 Inferno Off Road
    You spelled air fry wrong!
  12. Jan 8, 2020 at 8:57 AM
    Cold Iron
    Cold Iron Well-Known Member
    Mn.
    2013 AC T|X Baja
    Curious to see what you come up with! :popcorn:
    Horizontal rotisserie doesn't work so well for slicing. I have rotisserie for the WSM, kettle and gasser. The spit diameter is large on all 3. Plus the forks that are required to hold the meat in place interfere with slicing. Then there is the problem with the juices not flowing through all the meat stack like it does held vertically.
    I added a stacker to my WSM and used a gateway drums holder made for a 18" UDS.
    And used it with marinated beef hanging on a PBC skewer
    It works, to some extent, but the heat still is mainly at the bottom.
    The dripping juices cools the coals where it drips so moved it around after pulling out to slice. The bottom still cooks a lot faster than the top. And the bottom couple pieces of meat get over cooked but not a show stopper. But far from a Doner.
    I think if someone made a vertical firebox with expanded steel to fit along one side and fed it fuel from the top it would work. The side opposite the firebox could hold a motor and turn a vertical spit. Doesn't have to turn fast and steel cables should work with the heat. Lot of work to build something like that though would be unique and should work close to a Doner (Trompo) which are usually propane fueled.
    la0d0g, SwampYota, oscolivar1 and 4 others like this.
  13. Jan 8, 2020 at 9:17 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
  14. Jan 8, 2020 at 9:20 AM
    Zeke588
    Zeke
    Billings, Mt
    Bluerunner
    03 V8 limited
    wilcam47[QUOTED] likes this.
  15. Jan 8, 2020 at 9:22 AM
    wilcam47
    Will
    Bourbon state
    They got cheaper electric models for under $100
  16. Jan 8, 2020 at 9:24 AM
    RickS
    RickS New Old Stock
    Rick
    DFW'ish, Texas
    '22 Tundra Limited
    Bobbles and trinkets
    Maybe something like the Blaze basket that you get with the Caliber Pro Kamado. Keeps it to one side.
  17. Jan 8, 2020 at 9:26 AM
    Cold Iron
    Mn.
    2013 AC T|X Baja
    Exactly! Now just to find a vertical rotisserie to work with it...
  18. Jan 8, 2020 at 9:40 AM
    bvbull200
    Bryan
    DFW, Texas
    Fresh wiper fluid
    Basics are:
    1. Ground meat
    2. Stuffing
    3. Bacon weave
    What you use for each component is where the creativity comes in. For my "go-to" fatty, I do this:
    1. 1lb of Jimmy Dean original breakfast sausage
    2. Stuff with a dusting of BBQ rub, feta & mozzarella cheeses, chopped fresh spinach
    3. ~1lb of bacon for the weave (I prefer the 'regular' as opposed to thick cut)
    Ideally, you'll get it made, then wrap in plastic wrap and put in the fridge for a couple/few hours.
    Cook it at 250* for roughly 2-2.5 hours and pull when the ground meat is at 160-165* IT.
  19. Jan 8, 2020 at 9:40 AM
    RickS
    RickS New Old Stock
    Rick
    DFW'ish, Texas
    '22 Tundra Limited
    Will have to find a WSM 14 on CL and drill a hole in the top. Then wait for CB to run a sale on rotisserie parts.
    wilcam47 and Cold Iron[QUOTED] like this.
  20. Jan 8, 2020 at 9:42 AM
    bvbull200
    Bryan
    DFW, Texas
    Fresh wiper fluid
    I'd keep the rotisserie horizontal in a drum smoker, but build it to have a pivot point so that when you cut it, you could swing the rotisserie up in to the vertical position for shaving, the swing it back down and continue cooking.
    Maybe capture the juices just below it and reintroduce after each time you slice off some meat.
