Food Smokers and Smoking Tips/Tricks/Techniques
Discussion in 'Food Talk' started by Polymerhead, Jul 15, 2012.
  1. Sep 5, 2016 at 3:58 PM
    #4641
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    Would definitely brine longer if I was going to brine. I'd pull at 160 or so because it's going to continue to rise after its pulled. Wild breasts have even less fat than domestic turkey and you don't want it to dry out. .02
    robssol[QUOTED] and scottalot like this.
  2. Sep 5, 2016 at 4:55 PM
    #4642
    grdgz97
    grdgz97 Well-Known Member
    Georgetown, TX
    2015 TRD Sport DCSB
    Ball tip. It was $3.25lb. Similar to tri tip.
    tcBob and scottalot like this.
  3. Sep 5, 2016 at 5:18 PM
    #4643
    itzyoboipaul
    itzyoboipaul Well-Known Member
    Paul
    PFville, TX
    2020 TRD OR Cement
    I do this with my WSM.. No water.. Just foil the hell out of the water pan..easy clean up.
    Woundedyak and scottalot like this.
  4. Sep 5, 2016 at 6:19 PM
    #4644
    Soflanick
    Soflanick Well-Known Member
    Nick
    FLORIDA
    2001 tacoma prerunner
    5100 front, 5125 rear, 2"all, old ARE topper, 16x8 XD enduro's on 265/75r16 KO2's
    finally got myself a cast iron pan ... question, how do you clean it? i seasoned it with veggie oil baked for an hour then some bacon, then i made these chops . came out DELICIOUS
    Boerseun likes this.
  5. Sep 5, 2016 at 6:24 PM
    #4645
    horstuff
    horstuff Re-member
    PNW
    2015 Base 2.7 Access Cab 4x4 5 sp
    Cast iron... One of the best investments you can make. I just leave mine in the oven (taking it out when I use the oven) and then right before I need to use it I heat it over medium, scrape the gunk out with sharp metal spatula, add about a tbsp of veg oil, scrape again, wipe with paper towels. It has never seen the sink. As long as you heat it up good, any bad juju will get killed before your stuff goes in. All that stuff adds to the seasoning of the iron. I never do fish in it though... Seperate pan.
    Soflanick[QUOTED] likes this.
  6. Sep 5, 2016 at 6:25 PM
    #4646
    916carl
    916carl Well-Known Member
    Carl
    2008 DCSB TRD Sport SR5
    Clean it with warm water and a nylon bristle brush. No soap! If you hot water/soap it then you start the seasoning process over.
    Once you clean it make sure you dry it thoroughly, put it on the stove top with medium/high heat to really dry it off then rub with a light coat of oil. I use canola on a paper towel. Don't leave water in it to soak for very long: you'll get rust. That happens you need fine steel wool to remove and reseason.
    To get heavy stuff off use a chainmail scrubber. This is the one I use. Gets the big crud off without removing the seasoning.
    https://www.amazon.com/gp/product/B0164AD2L8/ref=oh_aui_detailpage_o06_s00?ie=UTF8&psc=1
    I bought a Lodge (made in the USA!) 12" pan and it's been awesome. I wanted a smaller pan. I found they also make an 8' pan. For $11! How can you beat that?! Got it in 2 days, free shipping.
    https://www.amazon.com/gp/product/B00008GKDG/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
    scottalot likes this.
  7. Sep 5, 2016 at 6:31 PM
    #4647
    grdgz97
    Georgetown, TX
    2015 TRD Sport DCSB
    It is one of the bigger ball tips I've seen. Prob 4.5
    Paper towel wadded up to wipe out the big chunks. About 1/8 in of water, let it warm over low. Dump it, dry it, place back on warm burner with a splash of oil. Let her warm up and take a paper towel and wipe that oil all over her. Just how I do it. :notsure:
    scottalot[QUOTED] likes this.
  8. Sep 5, 2016 at 6:42 PM
    #4648
    t4daddy
    North Alabama
    This... My Grandma told me over 50yrs ago "never wash cast iron". Just like stated above, preheat and that will take of anything that might happen to be there.
  9. Sep 5, 2016 at 6:51 PM
    #4649
    Soflanick
    Nick
    FLORIDA
    perfect thanks a lot
    that scrubber almost costs as much as the pan!
    yeah i went with the lodge 12"
  10. Sep 5, 2016 at 7:33 PM
    #4650
    grdgz97
    Georgetown, TX
    2015 TRD Sport DCSB
    She got away from me while I was cooking Mac....good flavor but too done for my taste.
    tcBob, Woundedyak and scottalot like this.
  11. Sep 5, 2016 at 9:04 PM
    #4651
    tubbsisland
    tubbsisland I took snowtanks beer
    Cliff
    Arizona
    I ruined a small brisket this weekend. Trimmed it down to about 3.25 lbs, 1/4 fat cap, 3 hour smoke on the traeger at 165 then 4.5 more hours in foil at 225 to an internal temp of 185. I think I wrapped it too quickly cuz i had a horrible soft bark on this one almost like it never had time to materialize and no smoke ring which was surprising to me. Still edible but far from what I was hoping for.
  12. Sep 5, 2016 at 11:25 PM
    #4652
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Totaled but still alive! Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers,m, Rear bumper 2.0, Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    My cast iron from my dad who got it from grandma. She would scrap, rinse, and I think she used bacon fat to season. (Probably not the best thing to use) Then back on the back burner with a lid.
    Send it over here! I'll take care of it:hungry:
    Did you smoke the Mac & Cheese?
  13. Sep 6, 2016 at 12:26 AM
    #4653
    t4daddy
    North Alabama
    I have a few, one is dedicated to nothing but cornbread. It gets nothing but a paper towel wipe after cooling. My "frying" pan may get a plastic scrubber then a paper towel wipe. Neither have seen any metal (of any sort) or water since I've owned them. That's closing in on thirty years!!!
    scottalot and grdgz97 like this.
  14. Sep 6, 2016 at 3:27 AM
    #4654
    grdgz97
    Georgetown, TX
    2015 TRD Sport DCSB
    I didn't smoke the Mac this time. Just easy on the stove. I still wonder why people bother with that boxed stuff.
  15. Sep 6, 2016 at 3:30 AM
    #4655
    grdgz97
    Georgetown, TX
    2015 TRD Sport DCSB
    My father in law has one that I keep trying to get from him! I told him I ain't trying to send him to the grave or anything like that, but I "claimed" that pan already. :laugh:
    robssol and scottalot like this.
  16. Sep 6, 2016 at 4:08 AM
    #4656
    perpetualenigma3
    perpetualenigma3 Well-Known Member
    Mr.
    Im here and there. Mostly there than here.
    2016 QuickSand Taco TRD OffRoad
    A new bolt here, a new bolt there, a new bolt everywhere.
    Carnitas not really meat smoking, but it was smoking good...couldn't even take the meat out with the tongs with out it falling apart. That was a Fat Sunday...:hungry:20151126_161450.jpg
    wilcam47 likes this.
  17. Sep 6, 2016 at 5:23 AM
    #4657
    jpneely
    jpneely Well-Known Member
    Charleston, SC
    2005 Land Cruiser, 2017 Land Cruiser
    Are they still on sale?!?! Im down to my last bag after I stocked up from the last sale they had.
  18. Sep 6, 2016 at 7:45 AM
    #4658
    Kanyon71
    Kanyon71 Well-Known Member
    MI
    Ya he is doing something wrong. I can get the same smoky flavor on my Traeger that my friend gets in his smoker and the food is just as good. With the pellet poopers it's all about quality of the pellets you use. I stay away from Traeger's they make it nice and warm but 0 flavor. I'm a Lumberjack Pellets fan.
  19. Sep 6, 2016 at 7:51 AM
    #4659
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Typically they are a little tough and on the dry side. They dont have a lot of fat in them is the main reason. The best luck Ive had is cutting them up in chunks and a simple breading, then deep fry them.
    truchador and scottalot like this.
  20. Sep 6, 2016 at 7:53 AM
    #4660
    Kanyon71
    MI
    Ya the plugging it in thing can be a pita. Mine has the nice wheels on it so it gets rolled back into the garage after I'm done. If I had to leave it out I would have bought the cover for it. I also bought the thermal blanket for it so I can smoke outside in the winter, worked really well last year. Will get it's workout again this winter lol.
    This weekend between my smoker and my friends we did 3 briskets, a bunch of brat's, 4 smoked pizzas (two cheese and two with brisket, one we also added bacon and sausage to it). Then yesterday had some family over and I did about a 20-30 min smoke on some porterhouse steaks then cranked it up to do the actual cooking. Don't have any pictures from the smoke fest weekend but lot's of happy people.
    Next weekend will most likely end up with a couple of fattie's being smoked.
    t4daddy and scottalot[QUOTED] like this.
