Food Smokers and Smoking Tips/Tricks/Techniques
Discussion in 'Food Talk' started by Polymerhead, Jul 15, 2012.
  1. Apr 28, 2020 at 6:47 PM
    Kanyon71
    Kanyon71 Well-Known Member
    MI
    Ya I’ve never used that type. I use the barrel style and mine isn’t double walled (yet - I want to build one). Sounds like they are completely different beasts. :)
    Kilo Charlie[QUOTED] likes this.
  2. Apr 28, 2020 at 6:52 PM
    gnarthirty2
    gnarthirty2 Well-Known Member
    Brandon
    2017 Toyota Tacoma TRD Pro
    I ran my Pitboss 800 Pro Series overnight at 225*. Filled the hopper about an hour after turning on and 12 hrs later it was still half full.
    TK-422 and Toywoodsguy82[QUOTED] like this.
  3. Apr 28, 2020 at 6:59 PM
    ctagz
    ctagz Well-Known Member
    Fountain Valley, CA
    2017 TRD Sport dcsb - Inferno
    Thanks for the response. I've read several reviews of this 7 series and the Pitboss version (same item, different colors/name - as far as I can tell). The issue I keep seeing is people getting error messages regarding the hopper jamming. Sounds like a cheap pellet issue. I run Cookin' Pellets which seem to be pretty low dust so hopefully won't cause a problem.
    Any issue with yours? It's really the only thing keeping me from pulling the trigger on this over the Rectec even with the $200 off the Rectec.
  4. Apr 28, 2020 at 7:05 PM
    TK-422
    TK-422 Toyota! Oh what a feeling.
    So Cal - SCV
    2015 4Runner TEP
    Toytech 2.5 lift BFG KO2 275-70-17
    Love it. I had smaller propane and electric ones before that and its nice not to have to cut a rack of ribs in half to fit them in the smoker. Cleanup is a little more since it has a glass front. I usually just cook for two but my wife likes to take some of what I smoke to work and share.
    I have never felt it was too large. Some of my cooks on it.
  5. Apr 28, 2020 at 7:08 PM
    Kilo Charlie
    Kilo Charlie One flat foot on the Devil's wing
    Iowa
    2017 Inferno Off Road
    I run the Pit Boss brand pellets in mine.. and mind you it hold 60# at a time so you won't have to fill it very often.. but they are the cheapest.. 40# bag at Walmart for $15... And I haven't had an issue with them at all.
    When I first bought mine I had an issue with the internal temp probe and after Customer Service replaced it... I have had zero issues.
    I keep mine in my garage when not in use and don't open a bag of pellets until I can dump the whole bag I'm the hopper.
    I have other pellets that I use in a tube smoker for cold smoking but I keep those in 5 gallon buckets with gamma lids to keep the moisture out.
    TK-422 and wilcam47 like this.
  6. Apr 28, 2020 at 9:10 PM
    TK-422
    So Cal - SCV
    2015 4Runner TEP
    I had the error one time after I had dumped a bag of pellets in an empty hopper. The pellets landed just right and created a dome so they didnt go into the tunnel. I used a 3 foot metal rod to stir them up and go into the tunnel and haven't had it happen since.
    The smoker also comes with a cover and once I left it uncovered in the pouring rain. Water got into the feed screw and got the pellets wet. A week later I started it up and the feeder was jammed. It only took a few minutes to pull it apart and clean it out. I always cover it after I use it now.
    Misplaced Nebraskan likes this.
  7. Apr 28, 2020 at 9:30 PM
    ctagz
    Fountain Valley, CA
    Thanks for the feedback folks. I think I'll give the Louisiana vertical smoker a chance. Worst case, I return it to Costco and get the Rectec around Father's Day. I'm sure they'll give me some time to decide if I want another Rectec.
    Kilo Charlie likes this.
  8. Apr 29, 2020 at 6:29 AM
    p_chinnici
    p_chinnici Well-Known Member
    Pete
    South Nj
    2015 Trd Pro Access Cab, 2.5 Kings, Dakars
    2.5 Kings all around, HD Dakars -1 OL, Camburg Moog BJ UCA, Leer 100r topper, Prinsu rack
    Hey guys. I will be in the market for a new grill. I’m either looking for a Traeger or a Green egg. My sister has the green egg in that thing is awesome. I’ve cooked meat to pizza on it and love the results. I’ve seen a lot of people with Traegers now. I have never used or ate food off of one. Has anyone used both for comparisons. Pros and cons? Traegers electric vs GReen egg analog?
  9. Apr 29, 2020 at 6:55 AM
    GoGoGadget
    GoGoGadget Well-Known Member
    2017 DCLB OR
    I went from an Akorn (egg style) to a Green Mountain Grill pellet grill. Ease of use and increased capacity of the GMG has me using it way more than the Akorn. I think the only time I have used the Akorn in the last 6 months was to make pizza.
  10. Apr 29, 2020 at 2:25 PM
    la0d0g
    running for the hills
    For crawling not hauling
    Shoulder with OG pitface. 15 hour cook. 6 hour rest. So good.
  11. Apr 29, 2020 at 6:35 PM
    Cold Iron
    Cold Iron Well-Known Member
    Mn.
    2013 AC T|X Baja
    I like the 26" kettle so much for smoking tonight decided to roll the WSM out of the way. The kettle is more efficient and as easy to use if not more so. Can still roll the WSM out to use if I have to easy enough.
    Put the rotisserie ring on the 22" kettle and set the Jumbo Joe inside of it. Can use lifted grate setup for steaks on the 22" but the JJ is faster and uses less charcoal.
    No need for the pellet smoker right now. Or the gasser, it almost hit 60 here today going to go with winter is over, but I hate to poke that sleeping bear.
  12. Apr 30, 2020 at 6:51 PM
    Parras
    Parras Member
    Gabriel
    Monterrey
    Tacoma 2020 4x4
    KO2
    I make sausages and salamis, the salami is warm short smoked for curing over a month
    looking to do cold smoke for curing meats and fish
  13. Apr 30, 2020 at 7:19 PM
    WBF610
    WBF610 Member well known
    Carey
    Eastern PA
    2016 DC OR
    mats, flaps, and stickers. Extang solid fold 2.0. Mobtown sliders and full skids. AVS vents
    Looks really good.
    Parras[QUOTED], k20me and wilcam47 like this.
  14. Apr 30, 2020 at 7:47 PM
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
    hot damn. Sausage is one of my favorites to do in the smoker. If I have anything planned I almost always end up with at least 5 as filler since I’m running it anyway. So good
  15. May 1, 2020 at 3:49 AM
    Black05
    Black05 Well-Known Member
    Harford Co. MD
    2005 ac 4×4
    Full trd pro suspension. Toytec progressive add-a-leaf pack (with overload in). Sema trd 4runner rims. 285 70 17 ridge grapplers. Satoshi grill.
    wilcam47 and Misplaced Nebraskan like this.
  16. May 1, 2020 at 5:38 AM
    la0d0g
    Chopped pork nachos
    AugustaTaco, nDub, TK-422 and 11 others like this.
  17. May 1, 2020 at 8:25 AM
    Misplaced Nebraskan
    Misplaced Nebraskan TTC #007 'First Gen Best Gen'
    Zach
    Austin
    2001 Taco & 16 T4R TPE
    Fantastic!
  18. May 1, 2020 at 8:34 AM
    GarlicFarts
    Lil Rhody
    Might end up with some ribs to smoke this weekend. I have two packs of spicy italian sausage. Went to the grocery store and had a Modern Family alpaca moment - haven't seen these in weeks! So I got 10 (2 packs of 5). Need to add something else to smoke alongside them, I'm thinking ribs.
  19. May 1, 2020 at 8:42 AM
    Misplaced Nebraskan
    Zach
    Austin
    Close enough :D
    wilcam47 and GarlicFarts[QUOTED] like this.
  20. May 1, 2020 at 8:44 AM
    GarlicFarts
    Lil Rhody
    Hmmmmmmmm I haven't done any read meats in a while....Maybe I'll do a rack of ribs and maybe some sort of roast or something.
