Food Smokers and Smoking Tips/Tricks/Techniques
Discussion in 'Food Talk' started by Polymerhead, Jul 15, 2012.
  1. Jun 25, 2020 at 6:47 PM
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
    I have an 8 inch that doesn't do well with the palm sander but I have just used elbow grease and gotten it down. Worth the effort, but I use the 8 and the 10 1/4 lodge pans basically daily.
    I waste enough time here on this site between this thread and the stocks trading thread o_O Don't give me another one to waste my time on during work.
    ......Subscribing to this thread now.
    The No 3 is a Griswold as well. There's a following of vintage pans like that, especially as long as they are not warped! Both are good pans. To the point that some of those pans will go for 75$ +. To me, it's not worth it. A 10$ lodge with 10 minutes with a palm sander and it's the same thing, these things are hunks of metal, nothing fancy that the new pans or old pans did better. The old pans have a surfacing operation after casting, that modern pans got rid of. Lodge says it's so that the rougher pan holds the seasoning better. I call shenanigaaaaaannnnnnnnss that Lodge gave it to their marketing team. I don't think they are wrong but I disagree. I surfaced my pans with a 300 grit and what a difference that made on the cooking surface!
    DON'T put them in the fire like some people think is the right thing to do. It warps them. You do not want warp - warp is caused by the same stresses that cause cracking, which you really don't want. Especially not on the vintage pans like that.
    The Taiwan pan is fantastic for doing potatoes in a camp fire because it's worth less than the potatoes that it will hold. I have a walmart taiwan level 12" pan that I can chuck in the fire and not give a rip about. Love it. my workhorses are a lodge 10 1/4" pan (10 1/2?? can't remember but I've had a few drinks this evening........) and a lodge 8". Those two pans do 99% of my cooking, and I have a lodge 12" that I use enough to justify having it. Plus the junker 12" that goes in the fire - oak fire roaster potatoes done once will prove that purchase worth it to anybody. Walmart, camping aisle - check it out :)
    ....did I mention that, what some of y'all have for smoking, I miiiiight have for cast irons? :D I know more and care more about cast irons than I'm willing to make public knowledge.......
    That's agressive :D
    I use a stripping pad first then use a 300 grit pad on my palm sander when I strip and surface my pans. I have wire wheels but I haven't used them. That might be a lie I may have used them for the groove in the bottom of the pan last time, but I don't remember. I focus my efforts on the cooking surface and just blast the outside and handle and don't really focus efforts there.
    I tend to season with crisco first. I do like bacon, but not a big bacon guy..... I know, not a big red meat or bacon guy, WTF. Crisco does well. I can't remember the chemistry off the cuff right now because....I've had a few drinks, BUT Bacon does well and crisco does well because they're long string polymers (??????) so when they "cling" to the pan, they hold better than, say, olive oil. Wife is vegan - she has a 9 inch pan (also used for baking stuff, 9 inch is a common size) so that one doesn't get the Bacon treatment. I do have a jar of saved bacon grease in the fridge though. Actually just made sweet potato fries with some this evening :)
    Everything can be used for the stovetop and the grill. Usually grills will "top out" around 500 to 550, which isn't really enough to destroy a cast iron. What really kills them is a thermal shock. If you take the pan out of the freezer with some frozen snausages and drop it on a preheated high heat 550 degree grill, that shock can either warp or crack the pan, it's the same stresses that cause both. If you "gently" get to 550 degrees and "gently" cool back down, you'll be fine to use it in the grill. The issues come in when you chuck it in the flames of a campfire, "because that's what grandma did". As mentioned I have a campfire pan, but it's a cheapo that I can guarantee you is now more warped than Phil Spector, but whatever, I chuck it in the fire (potatoes, steak, sometimes chicken.........pb&j......)
    The 2 gris pans are good finds though.
  2. Jun 25, 2020 at 9:19 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    i got some already made...;)
    Bigdaddy4760 and CurtB[QUOTED] like this.
  3. Jun 25, 2020 at 9:20 PM
    wilcam47
    Will
    Bourbon state
    id buy at$400
  4. Jun 26, 2020 at 4:27 AM
    jmdaniel
    jmdaniel Has A Well Known Member
    Jeff
    Leander, TX
    2018 Tundra SR5 CrewMax, 1977 FJ40 Landcruiser
    Don't forget the bottle opener...
  5. Jun 26, 2020 at 8:12 AM
    Clark27
    Clark27 Well-Known Member
    Springfield, MA
    2015 Lexus GX460
    It’s certainly heating up in the Northeast but I think I’m suffering from what some people would call meat sweats :thumbsup:
    nobescare, SwampYota, TK-422 and 10 others like this.
  6. Jun 26, 2020 at 8:26 AM
    TheCochese
    TheCochese The Bronze T4R OG
    Attempting to flee the south
    Cavalry Blue soccer machine
    Fine corinthian leather
    Kinda looking for an easy intro to longer cooks on the Weber. When we had a charcoal grill before, like over 15 years ago, one of the reasons we switched was that the meat was never done enough, that I either didn't leave things on enough or the fire never got hot enough. That was a similar situation with the london broil earlier this week, and why I had to cut it up and throw it back on.
    I'm already committed to the idea that my first bag of coal and my first few cooks are going to be experimental. I also need to read up on some accessory gear. I have an instant read, but I need to look into wifi or BT-enabled thermos so I'm not opening the lid a lot and trust that things are going well.
    Bigdaddy4760 and bvbull200 like this.
  7. Jun 26, 2020 at 8:38 AM
    la0d0g
    running for the hills
    For crawling not hauling
    On a Weber kettle you can do the snake method for long cooks.
  8. Jun 26, 2020 at 10:55 AM
    JeffRoyJenkins
    JeffRoyJenkins Essentially Non-Essential
    Jeff
    Lake Stevens, WA
    2024 F-150 XLT PowerBoost
    A good meat thermometer is your best friend for steaks, or pretty much anything on the Weber.
    I have one similar to this to monitor the temp inside the grill as well as 1 or more points in the meat throughout the cook for something that is going to take a while.
    https://smile.amazon.com/dp/B076QDC5VL/ref=cm_sw_em_r_mt_dp_U_SuJ9Eb08AQ5Y0
    and a standalone one to spot check areas if I want or if I pull the probes out so I can flip the meat over hot coals on a reverse sear.
    https://smile.amazon.com/dp/B07X9ZSCD8/ref=cm_sw_em_r_mt_dp_U_0uJ9Eb89WG195
    If I'm doing something that I expect to take a couple hours or longer on the Weber I will do the snake method but for most smaller/shorter cooks like tri-tip roast or pork tenderloin that take maybe an hour I usually use the minion method to make sure it has enough fuel for the cook.
    TheCochese[QUOTED] likes this.
  9. Jun 26, 2020 at 10:58 AM
    Kilo Charlie
    Kilo Charlie Disruptor
    Iowa
    2017 Inferno Off Road
    @Misplaced Nebraskan @bvbull200
  10. Jun 26, 2020 at 11:35 AM
    bvbull200
    bvbull200 Well-Known Member
    Bryan
    DFW, Texas
    2013 DCSB SR5 Prerunner Texas Edition
    Fresh wiper fluid
    @Misplaced Nebraskan has some pics from times where he's done this, but the best way is to line up the charcoal in a ring around the outer edge of the bowl. Maybe 2-3 briquettes tall with some wood chunks mixed in there. Get some charcoal started in your chimney starter (maybe 10 pieces or so?) and once they're lit, add them to the starting edge of your snake. They'll eventually light the briquettes like a big, long, slow burning fuse. You can put a little foil pan of water in the middle of the charcoal grate, then put the meat off to the opposite side of the fire. You'll need/want to rotate your cooking grate during the cook to keep the meat opposite the fire, but it'll work. Ideally, you'll keep the exhaust fully open and adjust temps on the intake side, but I usually end up having to tap the exhaust shut a little to get temps down.
    I've made great food going low 'n slow in the Weber kettle. If you want, put a short snake in there, light it up, then just play around with it as a test run. Throw some poppers in there to get something out of the heat ;).
  11. Jun 26, 2020 at 11:41 AM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    :gossip: Finally explains Crop Circles too.
  12. Jun 26, 2020 at 11:43 AM
    bvbull200
    Bryan
    DFW, Texas
    Fresh wiper fluid
    It's just ET using the snake method to cook an intergalactic brisket.
  13. Jun 26, 2020 at 11:45 AM
    FastEddy59
    Eddie
    Clear manipulation of gravity right there.
  14. Jun 26, 2020 at 12:04 PM
    Misplaced Nebraskan
    Misplaced Nebraskan TTC #007 'First Gen Best Gen'
    Zach
    Austin
    2001 Taco & 16 T4R TPE
    obviously ignore the Vortex in this pic. Just using it as a heat shield of sorts as I was fully loading the pit up.
    But Bryan pretty much covered it all. Just a visual for ya.
  15. Jun 26, 2020 at 12:22 PM
    bvbull200
    Bryan
    DFW, Texas
    Fresh wiper fluid
    Zach, can you link me to the post of your stuffed chicken breasts? I think I'm going to attempt those tonight.
  16. Jun 26, 2020 at 12:24 PM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    You forgot to tell him that you place the charcoal in there one at a time.
  17. Jun 26, 2020 at 12:30 PM
    GarlicFarts
    Lil Rhody
    Regular charcoal grill - you're going to go through a bag a lot faster than you think. For a shoulder I use half a bag or so. BUT I have a bigger barrel grill. I don't use the snake method I just tend a small fire in one side of mine.
  18. Jun 26, 2020 at 12:33 PM
    TheCochese
    This is more along the lines of what I was looking for. It's not that I don't appreciate any help, it's that I sometimes don't ask questions in exactly the right way the first time. I'm kinda looking more for the steps 5-9 of a ten step process vs steps 1-2, then 10 like I see on a lot of YouTube videos. As in, I'll see stuff like "Get your grill to 225, then eight hours later you're done." The way my mind works, it helps me to know what to do during those eight hours besides spritzing it every hour and turning it. Like for the snake, I know how to set it up but I also am looking for things like what target temp should I be looking for and what do I do if I exceed or don't get there, etc. I always like to go in with a plan and possible scenarios of how to address, that's just the way my mind works. Here is what we do and why is how I teach everyone at work because that's what I appreciate as well.
    I did just watch this video and was pretty enlightening on the setup portion of things, even though I don't have an SnS. https://www.youtube.com/watch?v=ABtv2xeV60A
    I hope that helps, but like I said I'm appreciative of everything.
    wilcam47 and Bigdaddy4760 like this.
  19. Jun 26, 2020 at 1:11 PM
    Kilo Charlie
    Iowa
    YouTube Aaron Franklin... Start there and expand.
  20. Jun 26, 2020 at 1:15 PM
    Cold Iron
    Cold Iron Well-Known Member
    Mn.
    2013 AC T|X Baja
    Yep bvbull200 pretty much covered it. Another visual (on the 26" kettle though) and I use the Slow N Sear as a heat shield and template for the coals.
    I don't stack them on the 26" just pour the coals on between the slow n sear, works great. 22" I always stacked them though.
    Got the slow n sear when it first came out because so many ranted and raved about how great it was for smoking but never really did feel it worked better than the Weber baskets.
    For thermometers I have moved to ThermoWorks for everything and no regrets they are worth it.
    Have the original Smoke remote 2 channel and used it the other night for reverse sear on the Wagyu steak I did.
    Rain, snow it doesn't matter it just keeps on working.
    Thermoworks has the Smoke X on sale right now 20% off Red, white or blue.
    With the Smoke X you can add the Billows and have an Automatic Temperature Controller, even on a kettle if you want but believe it requires drilling a hole on the kettle. Most smokers they have adapters for it.
