Food Smokers and Smoking Tips/Tricks/Techniques
Discussion in 'Food Talk' started by Polymerhead, Jul 15, 2012.
  1. Jun 27, 2020 at 8:50 PM
    TK-422
    TK-422 Toyota! Oh what a feeling.
    So Cal - SCV
    2015 4Runner TEP
    Toytech 2.5 lift BFG KO2 275-70-17
    If you replace that water tray with aluminium baking trays your smoker will keep a more constant temperature. It will hold more water and allow for better air flow.
  2. Jun 28, 2020 at 1:11 AM
    Kilo Charlie
    Kilo Charlie Disruptor
    Iowa
    2017 Inferno Off Road
    I had just cleaned mine too.. I shop vac up all the ash after each use to that pile of ash is all from the Charcoal pellets.
    My water pan has louvers in it for airflow and it holds about 3 hours worth of water...I'm good with that but thank you for sharing so others may utilize that great idea!
    You can see in the picture above how the louvers and the shape allow the right airflow.
    TK-422[QUOTED] likes this.
  3. Jun 28, 2020 at 1:44 AM
    TK-422
    So Cal - SCV
    2015 4Runner TEP
    I have basically the same smoker as you. Different name. same manufacturer. I spent a lot of time testing it. It is burried in this thread many pages back. The louvers actually prevent the air from flowing especially if you are smoking a large amount in these awesome smokers.
    After hearing complaints about heat spikes I did a test with multiple probes all over the smoker. I will sum it up.
    There are three levels - heat box, water box, cooking box.
    Heat box - Where the most temperature fluctuation occurs. 5 degrees at least. At the temperature selected the auger feeds pellets into the fire pit. As the pellets light up the temp rises very quickly. As they burn up the temp cools down until the controller decides to add more pellets. This is the burn cycle.
    Water Box - The one that comes with these smokers is small and the louvers do not provide enough flow. There are many post that are mostly from owners that pack in a lot of meat and the smokers cant keep up. What it comes down to is the design. The water amount and the few louvers aren't enough to provide enough airflow if you want to smoke more than a couple pounds at a time.
    Cooking Box - A lot have complained about the temperature swings in the cooking box area. By now you have read on the first two issues and if you have addressed them this should be solved.
    I have been using the Louisiana for over a year and am only trying to help.
  4. Jun 28, 2020 at 2:33 AM
    Kilo Charlie
    Iowa
    Haha I appreciate the information... Here's my take on mine since I've had it a couple of years now ... I keep the original water I place because I feel it's perfect for the design of the smoker. It keeps all that fat from dripping into the fire box area, it helps regulate the heat.I've test ran it without the water pan in there and the chamber temps near the top were over 100F higher than the set point.
    There's always more than one way to do things and with this not being my first nor my only vertical smoker I've learned along the way. I've done single pork shoulders and I've done 10 shoulders at once in this thing and I do understand the airflow etc.
    I'm definitely not saying there can't be improvements to these style smokers but I for one have always ran the water pan and I will likely continue to do so. I'd hate for someone to come along and read all this and ruin a $100 brisket because they took the water pan out.
  5. Jun 28, 2020 at 6:11 AM
    la0d0g
    running for the hills
    For crawling not hauling
    All you really need is a big pot and a thermometer.
  6. Jun 28, 2020 at 7:35 AM
    WBF610
    WBF610 Member well known
    Carey
    Eastern PA
    2016 DC OR
    mats, flaps, and stickers. Extang solid fold 2.0. Mobtown sliders and full skids. AVS vents
    they all will have some smalls in the bag, based on my experience. I normally use brick though.
    308savage[QUOTED] likes this.
  7. Jun 28, 2020 at 7:56 AM
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    I guess it was a success! 14 pounds gone in a few hours.
    Cold Iron, SwampYota, TK-422 and 7 others like this.
  8. Jun 28, 2020 at 8:15 AM
    TreeFortRichard
    TreeFortRichard Barcelona Red is the best red...
    Brian
    42.3115167,-71.6638516
    '23 SR5 DCSB 4x4 Barcelona Red
    I did some split chicken breast last night I wanted to try out the rub that I got for Father's Day.
    Rub
    I felt like cooking on the Weber kettle...so many options...kettle, smoker, gas grill...I've perfected chicken on the Weber Genesis. I haven't burned a piece in nearly 8 years. Heat the thing up to 400F (all 3 on Med). Place the chicken skin down over the left burning flame for three minutes flip it over and sear the underside for three minutes. Shut off the left-hand burner with the right two burners on medium 20 to 25 minutes later your chicken will be 165F and crispy and not burned. This works for bone in meat and wings. Best part is it also pre-burns the hairs off the wings...
    Back to business.
    The tools for tonight. This Royal Oak burns really hot and fast. I like to use it for this type of cooking, we are going to need a temperature of about 350F for at least an hour. It takes far more Kingsford's to get that temperature and I didn't want as much surface area for the coals. It would overcook the outside too quickly. I also used some maple chips to give a little bit of sweetness.
    Seared
    Smoking
    It seemed stalled at 160F so I repositioned them closer to the coals in the tray.
    A little rest...
    Malbec with smoked meats.
    Plated with some corn on the cob I foiled and cooked along side the chicken. I cut off the end hairs and leave it in the husk. I also picked up a large house fried rice from the Chinese restaurant in town because I was just craving the hell out of it while walking the dog and thought I'll pick some up on the way home. That way I'm also supporting local businesses.
    Good stuff.
    Cold Iron, la0d0g, SwampYota and 7 others like this.
  9. Jun 28, 2020 at 8:28 AM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    That was eye catching! Ryobi :thumbsup:
    wilcam47[QUOTED] likes this.
  10. Jun 28, 2020 at 8:30 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    We got a little off track talking tools...a buddy has the rigid multi tool and loves it
  11. Jun 28, 2020 at 8:33 AM
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
    Now I want fried rice with chicken for dinner tonight. THANKS.
    actually I’ll probably do that. Chicken thighs/drums on the gasser with a fried rice from the Chinese place down the street.
  12. Jun 28, 2020 at 9:22 AM
    TheCochese
    TheCochese The Bronze T4R OG
    Attempting to flee the south
    Cavalry Blue soccer machine
    Fine corinthian leather
    I may try to put these leftover ribs in the sous vide to see if they can work as leftovers. We had over a full rack left as my son found the Butt Rubb too spicy and my wife had to grab something on the way home. I ate my share, though.
    wilcam47 likes this.
  13. Jun 28, 2020 at 9:24 AM
    Black05
    Black05 Well-Known Member
    Harford Co. MD
    2005 ac 4×4
    Full trd pro suspension. Toytec progressive add-a-leaf pack (with overload in). Sema trd 4runner rims. 285 70 17 ridge grapplers. Satoshi grill.
    Anyone have both a vertical (cabinet style) and a horizontal (grill style) pellet smoker. If so which do u prefer
    Kilo Charlie and wilcam47 like this.
  14. Jun 28, 2020 at 9:37 AM
    Kilo Charlie
    Iowa
    Yes and I prefer the vertical.
    I have a gas grill for grilling and I think the cabinet has better heat distribution.
    Purely my opinion tho and I'm sure there's others.
  15. Jun 28, 2020 at 9:43 AM
    TreeFortRichard
    Brian
    Cut them into mini racks of 3 or 4 bones and freeze them. I keep a few in the freezer for months. I reheat it in the microwave for 30 seconds to liquify the ice and then cut them into single ribs, foil pouch them in the toaster oven for about 45 min. Open it up, add some bbq sauce and finish on high heat for 5 min.
  16. Jun 28, 2020 at 9:46 AM
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    Yep, vacuum seal if you have one. Sous vide will work to reheat from frozen that way. 5-10 min in the oven at 350-400 to bring back the bark works well.
  17. Jun 28, 2020 at 11:17 AM
    timred93
    timred93 Never too old to Tacoma
    Tim
    NW AR
    2013 Spruce Mica TRD Sport
    Predator Tube Steps, Fuel Hardline Wheels, 265/70 R 17 Nitto Ridge Grapplers, 2 inch Rough Country Leveling Struts, Undercover Armour Flex Hard Folding Tonneau Cover, Pop and Lock Tailgate Latch With Key Lock.
    Smoking this green chile fatty on the egg. Holding right on 250 f. No more adjustments needed. I can't even remember life before my big green egg.
    Cold Iron, SwampYota, TK-422 and 4 others like this.
  18. Jun 28, 2020 at 12:53 PM
    Kilo Charlie
    Iowa
    Disclaimer!! I'm sharing MY opinion and a process and link from where I learned it.
    There will be many different opinions on this subject so take it with a grain of salt and do your own research and keep the negative to a minimum.
    @nDub
    I've personally used this wet curing brine with great success with many things from making bacon to inventing pulled ham to corned beef, Canadian bacon etc.
    https://www.smokingmeatforums.com/threads/pops6927s-wet-curing-brine.110799/
    While this is off your current topic of beef jerky, it is a great resource. Unfortunately, even on SMF there's many opinionated people who will tell you this is all wrong etc.
    However, if you want to try your hand at it you need Cure #1 and a digital scale that measures in grams.
    The reasons for this are to weigh each ingredient to make each gallon of water exactly the same. You want consistency in case you have to make another gallon to cover a piece of meat.
    Do NOT try to make a half gallon or cut the recipe in half. The ingredients are cheap and if you only need say a 1/2 gallon to cover the meat, you can pour the other half in ziplock bags to weigh the meat down. (If you use water in the ziplock bags and it leaks it will dilute the brine)
    I actually took the time to measure out all the ingredients in grams and while the salts and sugars are negotiable, the amount of cure is NOT.
    For every gallon of water I use the following:
    1 gallon of water
    24 grams of Cure #1
    144 grams Kosher salt
    (OR 136.50 grams of table salt but NOT both!!)
    200 grams Sugar
    200 grams Brown Sugar
    Mix well and use it.
    Like I said I weighed out the things in 1/4, 1/3, 1/2, 3/4 and 1 cup sizes. I started with 200 grams of Kosher when I began to keep things easy, but I've cut the Kosher salt back.
    Again, I'll be happy to answer any questions about this process that I can, but I'm not here to defend it again and again. (Speaking from experience here)
    Here's Pops himself explaining it.
    https://www.smokingmeatforums.com/threads/pops-curing-brine.298897/
  19. Jun 28, 2020 at 12:58 PM
    lapoltba
    CT - 06076
    Lots of ways to accomplish the same thing. I have a cookbook that is probably older than me I use for reference. I personally have never "cured" my jerky. I do however seal and freeze it for long term storage.
    The book:
    And my favorite recipe (dry rub).
    nDub likes this.
  20. Jun 28, 2020 at 12:58 PM
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    Perfect. Thank you!
    I need to looking cure #1.
    Kilo Charlie[QUOTED] likes this.
