Food Smokers and Smoking Tips/Tricks/Techniques
Discussion in 'Food Talk' started by Polymerhead, Jul 15, 2012.
  1. Jul 3, 2020 at 12:16 PM
    AugustaTaco
    AugustaTaco Well-Known Member
    Josh
    Augusta, GA
    2015 DCSBXSPX4X4 2017 GX460
    "Getting out of hand" - Wife
    Yes! That's how I got my second 22, free on the side of the road. Swapped some grates around and now use both regularly. The freebie has a shallower bowl which makes for better high heat cooks
    Congrats! :cheers:
  2. Jul 3, 2020 at 12:18 PM
    medic2230
    Murph
    Bama! Roll Tide
    That thing looks good to be by the road. Awesome score!
  3. Jul 3, 2020 at 12:38 PM
    AugustaTaco
    Josh
    Augusta, GA
    Have any of you guys built a table for your kettle? I'm thinking of kind of building mine into the carport area to give me some nice prep space.
    Similar to the green egg ones you see all the time or like this kit on Home Depot:
  4. Jul 3, 2020 at 12:45 PM
    TheCochese
    TheCochese The Bronze T4R OG
    Attempting to flee the south
    Cavalry Blue soccer machine
    Fine corinthian leather
    I'm sitting here putting some finishing touches on my rough draft. Hopefully it will fit in temporarily with the gas grill under my disintegrating gazebo.
    Made room for the charcoal container, three bins of wood chunks, the chimney, utensil storage behind both doors, two drawers, and maybe some gourmet inserts hanging on the outside wall next to the grill. Did I miss any tricks?
  5. Jul 3, 2020 at 12:54 PM
    AugustaTaco
    Josh
    Augusta, GA
    Nope that pretty much covers it lol
    If I build one it won't be nearly that fancy...my biggest concern is mounting the grill and the heat. But I kind of like the way you have it because you could keep a small gap
    TheCochese[QUOTED] likes this.
  6. Jul 3, 2020 at 1:36 PM
    Kanyon71
    Kanyon71 Well-Known Member
    MI
    Ya that doesn’t sound good. Can’t have a smoker that doesn’t produce smoke. Hopefully you just have a faulty controller and they will swap it out. If not I can totally understand where you’re coming from on selling both.
    Bigdaddy4760 likes this.
  7. Jul 3, 2020 at 1:37 PM
    Bigdaddy4760
    Maner
    Poolville Texas
  8. Jul 3, 2020 at 1:39 PM
    Kanyon71
    MI
    My sticks are the same as yours just put through a big press. :)
  9. Jul 3, 2020 at 1:42 PM
    Bigdaddy4760
    Maner
    Poolville Texas
  10. Jul 3, 2020 at 2:07 PM
    Black05
    Black05 Well-Known Member
    Harford Co. MD
    2005 ac 4×4
    Full trd pro suspension. Toytec progressive add-a-leaf pack (with overload in). Sema trd 4runner rims. 285 70 17 ridge grapplers. Satoshi grill.
    Thank u for the details for anyone thinking of getting this smoker
  11. Jul 3, 2020 at 2:36 PM
    rmac010
    rmac010 Well-Known Member
    2017 DCSB TRD Sport
    Last update for the Lockhart.
    On smoke setting
    Temperature in the cabinet dropped down to 115 since the last update.
    The Pro1100 settled at 130 and stabilized.
    If you want to replace your gas grill, this is NOT the grill for you.
    If you want an outdoor oven, go buy an oven and put it outside.
    If you want low smoke outputs at lower temps in the upper cabinet, this is not the smoker for you.
    In conclusion, if you need a 250lb boat anchor, this is what you need.
    At least the.... never mind, this thing is a pile of crap.
    Fuck you Pitboss
    :violent:
  12. Jul 3, 2020 at 2:38 PM
    Kanyon71
    MI
    Can you return it and tell em its garbage?
    Bigdaddy4760 and rmac010[QUOTED] like this.
  13. Jul 3, 2020 at 2:39 PM
    Kanyon71
    MI
    Should make a pellet press then you can make your own pellets. :)
  14. Jul 3, 2020 at 2:40 PM
    Kilo Charlie
    Kilo Charlie Disruptor
    Iowa
    2017 Inferno Off Road
    You've mentioned this before... plans?
    rmac010 and Bigdaddy4760 like this.
  15. Jul 3, 2020 at 2:44 PM
    rmac010
    2017 DCSB TRD Sport
    Reaching out to them
    :frusty::annoyed:
    Going need to bribe a few neighbor with bbq to help load and then unload this thing at wal mart.
  16. Jul 3, 2020 at 2:45 PM
    Kanyon71
    MI
    I need to figure out exactly how they work then I can make plans. I’ve only looked at commercial one that are built.
  17. Jul 3, 2020 at 2:46 PM
    Kanyon71
    MI
    Ya that’s the crappy part.
    rmac010[QUOTED] and Bigdaddy4760 like this.
  18. Jul 3, 2020 at 2:59 PM
    medic2230
    Murph
    Bama! Roll Tide
    Just get ya a stick burner. No issues with smoke.
  19. Jul 3, 2020 at 3:02 PM
    WBF610
    WBF610 Member well known
    Carey
    Eastern PA
    2016 DC OR
    mats, flaps, and stickers. Extang solid fold 2.0. Mobtown sliders and full skids. AVS vents
    You burning sticks or charcoal? How’s the temp Control So far?
  20. Jul 3, 2020 at 3:05 PM
    medic2230
    Murph
    Bama! Roll Tide
    Got a base of Royal Oak (One chimney full) with a oak log, a chunk of cherry and few small pieces of mesquite in there. The top probes are about 100 degrees apart. I don’t have a water pan in there blocking off the heat from the fire box though. That ought to even it out a little more.
    Going to have to seal the door on this one. Unless the metal moves a little on the burn in and seals better.
