Food Smokers and Smoking Tips/Tricks/Techniques
Discussion in 'Food Talk' started by Polymerhead, Jul 15, 2012.
  1. Nov 24, 2020 at 10:47 PM
    Beef Nachos
    Beef Nachos Here for a good time, not a long time
    Dallas/Ft. Worth
    2017 SR5 DCSB 4x4
    Yes, job #1
    wilcam47[QUOTED] likes this.
  2. Nov 25, 2020 at 3:13 AM
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    I’ve had our two turkeys in the spare fridge since Friday, they should they be unthawed all the way through shouldn’t they?
    FastEddy59 and wilcam47 like this.
  3. Nov 25, 2020 at 3:15 AM
    jmdaniel
    jmdaniel Has A Well Known Member
    Jeff
    Leander, TX
    2018 Tundra SR5 CrewMax, 1977 FJ40 Landcruiser
    If I recall correctly, it's about 10 minutes per pound, at 325, to get to breast temp of 165 and/or leg temp of 180. Good luck!
  4. Nov 25, 2020 at 4:32 AM
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
    first and foremost, NEVER smoke something from frozen. It hovers in the danger zone for bacteria and that’s a no no. Also it doesn’t cook good. But more important, it’s dangerous.
    I have never done a breast on rib cage in the smoker. I always smoke boneless turkey breast. I would say do a seasoned brine, then into the smoker for probably 3 to 4 hours. However, since that’s my timeframe for boneless breast, it might take longer.
    normally you take off turkey about 5 to 10 degrees before 165, as it cooks a bit while resting. I haven’t seen that in the smoker, typically you’ll want to leave it to temp. At least I usually do.
    subjectively, that skin will be shoe leather once it’s done. Leave it on for the smoke, but don’t expect a good crunchy and crispy skin like out of the oven. I do chicken drums and thighs time to time and those come out like leather, but the meat is spot on.
    Any wood will do. Hickory is fine. Some people are very particular about their wood selection, but if you don’t do it on a regular basis you’ll probably not be able to tell the difference.
    I do 225 on the barrel grill as an offset smoker. Good luck!
    Edit: I forgot the rest! Rest it for at least an hour before you hack into it.
  5. Nov 25, 2020 at 5:34 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Yes, you can quick thaw in sink with water
    I drain about half and refill/move it every 30 min.
  6. Nov 25, 2020 at 5:49 AM
    Black05
    Black05 Well-Known Member
    Harford Co. MD
    2005 ac 4×4
    Full trd pro suspension. Toytec progressive add-a-leaf pack (with overload in). Sema trd 4runner rims. 285 70 17 ridge grapplers. Satoshi grill.
    I brine large bone in turkey breasts for about 12-16 hours. Make sure you get the outside nice and dry. I then use whatever poultry or custom rub I like at the moment and smoke it at 225 until it hits 150 i.t. Then I finish it of at 275 until 160-165 i.t. I like to use cherry wood
    grdgz97, la0d0g, six5crèéd and 2 others like this.
  7. Nov 25, 2020 at 5:50 AM
    GarlicFarts
    Lil Rhody
    i would think so. Are you brining? A bribe will help ensure fully thawed too.
    six5crèéd[QUOTED] and wilcam47 like this.
  8. Nov 25, 2020 at 5:53 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    No.
    wilcam47 likes this.
  9. Nov 25, 2020 at 5:58 AM
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    They most likely will be. If not, the internal temp should be very close to 32f. They will finish thawing as you wash/prepare them. It's the same with any meat.Time depends on meat mass and frig temp.
    I'm going to season as I used to, if iirc, wash, dry, rub in and out with softened butter, and rub in and out with seasoned salt. 150f for an hour, then 225f til 160 IT. Wrap in foil and rest for at least an hour. I'm pretty sure this is how I used to do a whole bird on a different smoker.
    Thanks for the advice fellas. Have a great Thanksgiving, and don't get any of them chinese cooties.
    wilcam47 and six5crèéd[QUOTED] like this.
  10. Nov 25, 2020 at 6:19 AM
    GoGoGadget
    GoGoGadget Well-Known Member
    2017 DCLB OR
    Mix some cornstarch in with whatever rub or seasoning you are putting on the skin, and let it sit uncovered in the fridge for several hours before cooking. Then crank the heat up at the end of your cook and the skin will crisp up much better.
    jmdaniel, six5crèéd and wilcam47 like this.
  11. Nov 25, 2020 at 6:25 AM
    EPBlueTaco
    EPBlueTaco Well-Known Member
    Ted
    El Paso
    07 DCLB SR5
    None yet
    Yeah, I did not plan on putting frozen meat on the smoker. I was just talking about what the instructions on the package stated
  12. Nov 25, 2020 at 6:36 AM
    GarlicFarts
    Lil Rhody
    you’re probably fine. I have a breast I moved into the fridge on Sunday afternoon/evening and it’s fully thawed now. I’m brining later today though.
    I’ll give that a whirl next time I do chicken. Thanks!
    ah fair enough. Yeah, you can do frozen in the oven and instant pots/pressure cookers, since it blasts it through the no go zone quickly. Bacteria doesn’t get a chance to grow. Not so with low and slow where it hangs out there for a while.
  13. Nov 25, 2020 at 6:59 AM
    jmdaniel
    Jeff
    Leander, TX
    Baking powder, (not baking soda), will do the same thing.
  14. Nov 25, 2020 at 11:12 AM
    Lil Puke
    Lil Puke Well-Known Member
    Oregon
    ‘99 Taco
    crumbs between seat cushions, junk in glove box, center console mostly full
    Okay guys, thought I’d share one of my go-to rubs. It’s an easy one and works well on tri-tips, Prime Ribs, etc. If anyone tries it out I’d love to hear some feedback. What you liked and what you didn’t like. Maybe some critiques on improving it as well?
    Equal parts of:
    Course ground pepper
    Course ground salt
    Dried parsley
    Dehydrated onion flakes
    Red pepper flakes (by taste)
    I generally mix this up using 3 TBSP of each ingredient, but only 2TBSP of Red Pepper Flakes (they can overpower the flavor pretty quickly).
    Key verbiage here is “COURSE GROUND” as it keeps the meat from getting too salty.
    throw the rub on pretty liberally and let it set a couple hours or overnight. Just let the flavors get to know each other.
    Easy as that, let me know whatcha think!
    la0d0g and wilcam47 like this.
  15. Nov 25, 2020 at 12:53 PM
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
  16. Nov 25, 2020 at 12:58 PM
    308savage
    308savage Well-Known Member
    Adam
    East Tennessee
    2012 Tacoma TRD Sport DCSB
    Leveling kit, roll bar
    Butter and seasoned salt only? I’ve got to figure out what to put on ours!
  17. Nov 25, 2020 at 1:02 PM
    Black05
    Harford Co. MD
    2005 ac 4×4
    Does the smoke still get to the entire thing well when using a pan underneath like that?? Sure would make my clean up a lot easier
  18. Nov 25, 2020 at 2:22 PM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    So kinda like Waterboardin’ then. Aggressive cook.
  19. Nov 25, 2020 at 2:36 PM
    GarlicFarts
    Lil Rhody
    Yup. Unless you have fans going pulling air, the smoke wanders a lot. You won’t be missing any side as long as you have it on a grate above the pan like this. You want air/grates underneath. As long as you do that, you’ll be fine.
  20. Nov 25, 2020 at 3:15 PM
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    Well no, change of plans lol. Butter, even tho I patted dry and then air dried didn't stick very well. Next time melted butter. The seasoned salt was best by... 06. Nope, prolly still ok but the spices were that old. So Tony Chacheres Creole seasoning, about the same thing with a little more kick. IT at 156f, will be coming into rest soon.
    grdgz97, Bigdaddy4760 and GarlicFarts like this.
