Food Smokers and Smoking Tips/Tricks/Techniques
Discussion in 'Food Talk' started by Polymerhead, Jul 15, 2012.
  1. Apr 16, 2021 at 3:05 PM
    Haslefre
    Haslefre Well-Known Member
    Brady
    TN
    2019 Tundra
    Some flags and center console divider... lots of things on the wanted list.
    I am changing it to something like this next time, probably still a 3-1-1 though. Same smoke time, small steam, then good temp for bark.
    wilcam47[QUOTED] likes this.
  2. Apr 16, 2021 at 5:02 PM
    Kilo Charlie
    Kilo Charlie Disruptor
    Iowa
    2017 Inferno Off Road
    I've kinda followed Aaron Franklin and just done 2/2 on spare ribs.. I haven't had any issues with following that.
    That being said ... everyone is different is how they want their ribs.. just keep track in a notebook what happened this time..what you wanna change next time etc until you find out exactly what works for YOU.
  3. Apr 16, 2021 at 7:26 PM
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    So it's been a while... Winter *was* over and I have 4 racks of ribs and 2 pork shoulders with rub on them sitting in the fridge for the weekend. I woke up to 3" of snow this morning, it snowed all day, and we got about 6" total. Thankfully it is supposed to be warm the next several days so hopefully it will melt.
    Anyway... I finally got around to upgrading my holding cabinet with a charcoal "grill" to add heat. I wanted to be able to control the temperature a little more easily, and I went back and forth on how I wanted to do it.
    Goals:
    1. Cheap (relatively speaking)
    2. Easy to use
    3. Accurate
    4. Use off the shelf components readily available from Amazon or a hardware store.
    Here is what I ended up with:
    What your looking at is my brainchild for controlling draft of a small charcoal fire. The "pit" consists of a 6" deep steam table pan, and a 4" deep perforated insert. I got a 3/4" barbed bulkhead fitting and some high temperature silicone tubing from Amazon, along with a cheap 12V air mattress pump, a PID temperature controller, a K thermocouple, and a 12VDC speed controller.
    Bill of Materials:
    Temperature controller: https://www.amazon.com/gp/product/B007MMOEWY/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8
    $25.99 - There are cheaper ones, but this one was available for prime delivery today.
    Thermocuple: https://www.amazon.com/gp/product/B07MGG6DPH/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8
    $14.99 - Same as above, but this one had M8 threads which made it a perfect fit for a rivet nut in the existing hole in my smoker.
    Bulkhead: https://www.amazon.com/gp/product/B08691NLRB/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8
    $21.99 - Brass would have worked just fine and would have been cheaper (~$12), but I like stainless.
    1/2 size perforated pan: https://www.amazon.com/gp/product/B07ZQY5WJL/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8
    $10.00 - 2 pack so I have a spare when the first warps to shit.
    1/2 size steam table pan: https://www.amazon.com/Steam-Stainl...011&rnid=2470954011&rps=1&s=industrial&sr=1-8
    $19.99 - I didn't use this specific one because I already had one. This one sould work just fine.
    Air pump: https://www.amazon.com/gp/product/B07MYFNWNS/ref=ppx_yo_dt_b_asin_title_o01_s01?ie=UTF8
    $7.99 - This is about as cheap as you can get one of these things. It works fine, but it isn't the best quality and I expect to wear it out at some point. For $8, I'll buy another.
    Silicone Tubing: https://www.amazon.com/gp/product/B01LZ5ZK53/ref=ppx_yo_dt_b_asin_title_o01_s01?ie=UTF8
    $22.99 - I could probably have found something cheaper and shorter, but I needed it in 2 days.
    12VDC speed control: https://www.amazon.com/gp/product/B07PBD4CNH/ref=ppx_yo_dt_b_asin_title_o01_s01?ie=UTF8
    $4.29 - These are everywhere in all different flavors and it really makes no difference which one you use. I got this one because I can panel mount it when I am ready.
    The idea is that I will pass the tubing through one of my lower vents and place the pan at the bottom of the cabinet. Everything else goes outside, and the thermocouple is mounted where the original thermometer would have been. The PID is very responsive, and the quick and dirty auto-tune I did isn't too bad. I set it to 80 degrees at the beginning, and then switched over to show the duty cycle from the PID loop. You can see it jumps up fairly quickly and then when I warm up the probe with my hand it drops back down. I used a wet paper towel to cool it a bit more to show it climbing back up. I will need to play with the speed of the blower to have enough draft to make heat quickly when I have to open the door, but not too much that it overshoots and runs away. At about the 1:45 mark, I turned up the speed control too far and the crappy 12V adapter I had couldn't handle the POWA! I'll use a be using a higher current one in normal use. I am going to set it up on the smoker tomorrow for a test run and get the PID tuned properly. Once I am happy with it, I will put it in an enclosure and make a mount for it. Wish me luck!
    nDub, CurtB, EricL and 2 others like this.
  4. Apr 16, 2021 at 7:44 PM
    EricL
    EricL Tomahawk Chopper
    Greenwood, SC
    2015 Slowmobile
    SOS Offroad Concepts Armor
    Dr Frankenstein, I presume? :hattip:
    Kilo Charlie likes this.
  5. Apr 16, 2021 at 7:49 PM
    Kilo Charlie
    Iowa
    Nothing wrong with experimenting!
    EricL[QUOTED] likes this.
  6. Apr 16, 2021 at 7:49 PM
    lapoltba
    CT - 06076
    Nah, I'm just more of a build not buy kind of guy. I get this picture in my head of how I want things to be, so I go off to the internet to search it out. Inevitably, exactly what I want doesn't exist so I resort to just making it the way I want. I freely admit, this could be a complete failure. I already know of a few potential issues. For one, the air tends to come out of the holes on the opposite side of the pan from the inlet more, so the fire will burn hotter/faster there.
  7. Apr 16, 2021 at 9:12 PM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    I’ve used hot plates, tiger torches, whatever you got handy as long as it’s not lead or toxic to burn whatever you’re smokin’. When it’s Cold the key is to keep heat in. I’ve seen some pretty innovative ideas in backyards. I’m sure some have gone to market too.
  8. Apr 17, 2021 at 2:22 PM
    lapoltba
    CT - 06076
    Well, It works, but it was too hot. I put wayyyyy too much charcoal in to start with and by the time it got completely going and in the smoker, it just started to run away. It crept up to 300F before I gave up. I have a feeling that a 1/2 size pan is too large for my smoker. It's pretty well insulated so it doesn't take much heat to keep it at temperature. Too late for this weekend, but I am going to try to find a 6" deep 1/4 pan and perforated insert to do the same thing. For tomorow I'm just going to put a stainless bowl with some gravel in it to block off part of the insert. That should be enough.
    Kilo Charlie, FastEddy59 and wilcam47 like this.
  9. Apr 17, 2021 at 3:02 PM
    Fargo Taco
    Fargo Taco Well-Known Member
    Not Drew but still Drew
    Fargo
    2019 TRD Pro
    Lomax tonneau cover, N-Fab Podium steps, bed mat
    After 2 months, I finally have a functioning smoker. First cook on it right now.
  10. Apr 17, 2021 at 3:05 PM
    grdgz97
    grdgz97 Well-Known Member
    Georgetown, TX
    2015 TRD Sport DCSB
    Been quite a while. Only variable today is that as of late the pooper has decided to spike and dip like nuts!
  11. Apr 17, 2021 at 3:14 PM
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
  12. Apr 17, 2021 at 3:25 PM
    Fargo Taco
    Fargo
    2019 TRD Pro
    CurtB[QUOTED] likes this.
  13. Apr 17, 2021 at 4:59 PM
    Fargo Taco
    Fargo
    2019 TRD Pro
    Thick cut pork chops, Pork Barrel rub and cherry wood.
  14. Apr 17, 2021 at 6:12 PM
    grdgz97
    Georgetown, TX
    2015 TRD Sport DCSB
    Ribs. Tater salad, green beans.
  15. Apr 17, 2021 at 6:15 PM
    lapoltba
    CT - 06076
    Looks awesome. I don't really like the baby back ribs and like a bit more bark, but I wouldn't turn down a plate of those!
  16. Apr 17, 2021 at 7:56 PM
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    Nice. Good job on the build. Inspiring.
    Would a simple computer fan in a fan box work just as well as the blower? Might fix the on-off-on-off switching every few minutes. Maybe double up on the fans for air volume. Just a thought.
    I built something similar for my kegerator and tap tower. I’m super interested in doing something for a bbq.
    lapoltba[QUOTED] likes this.
  17. Apr 17, 2021 at 8:21 PM
    lapoltba
    CT - 06076
    Thanks, I'm just screwing around here.. lol.. A standard "muffin" fan would work in most cases, and I did that initially when playing around but it didnt' do what I wanted.. I really want to be able to control draft independently of air circulation through the smoker though. I may end up having to add a fan for forced draft thorough the smoker chamber separate from the heat source. The issue I am really trying to solve is that this thing doesn't have a usable heat source, and I haven't figured out hot to effectively control the normal airflow through it yet.
    The hardware is good, I just need to put together something that gets me the heat and stability I want. I'm hoping limiting the fuel source to about 1/2 of what I had for my test run today will help. I will have to add to it a coupple times during the day though. From playing around today, it seemed to recover pretty quickly which is good.
    nDub[QUOTED] likes this.
  18. Apr 17, 2021 at 8:31 PM
    FastEddy59
    Eddie
    Sounds like VFD time. This could get complicated just like work. What could go wrong. :notsure:
  19. Apr 17, 2021 at 9:02 PM
    nDub
    Lead Free Gasoline
    Right on.
    Just out of curiosity, what are you cooking with?
  20. Apr 17, 2021 at 9:03 PM
    lapoltba
    CT - 06076
    You mean variable frequency drive? We're not there yet. There is enough control here to work, it needs some fine tuning though.
    FastEddy59[QUOTED] likes this.
