Food Smokers and Smoking Tips/Tricks/Techniques
Discussion in 'Food Talk' started by Polymerhead, Jul 15, 2012.
  1. Oct 18, 2022 at 7:31 PM
    SwampYota
    SwampYota Strange things are afoot at the Circle K
    Jon
    Concord, North Carolina
    '03 Tacoma SR5 TRD 5VZ-FE, 5 Speed
    Floor mats
    I like your idea of working the leftover pulled pork into dishes. I usually just eat it straight for the next 3-4 days and don’t smoke a butt again for 2 months…
  2. Oct 18, 2022 at 7:51 PM
    la0d0g
    running for the hills
    For crawling not hauling
    Heck yeah. The first half of this fed the crew on a trail ride then on to a few leftovers. I usually vacuum seal some for the freezer but this time there isn't much left.
  3. Oct 19, 2022 at 7:36 PM
    AKBorealis
    AKBorealis Active Member
    22 MG Taco OR DCLB
    Well I searched for "chopped ham" in this thread and didn't find what I was looking for, so...
    I love smoking all sorts of foods, mostly wild Alaskan seafood and game in my Cookshack smoker. I'd heard smoked bologna was good and wanted to give it a whirl sooner or later. Decided to experiment on 2-5lb blocks of inexpensive chopped ham.
    Scored them in a diamond pattern. Slathered yellow mustard all over them as a binder to hold a generous sprinkling of rib rub.
    4 ounces of hickory wood chips @ 225 degrees for 5 hours in the smoker. Incredible variety to add to the menu!
  4. Oct 23, 2022 at 3:48 PM
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    Feels like it’s been too long!
    Ribs and chicken :bananadance:
  5. Oct 25, 2022 at 12:33 PM
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    Which model Cookshack do you have?
    That ham looks great!
    I am currently trying to decide which smoker to upgrade to, and a Cookshack is one of my options.
    I assume you like it - anything you don't like about it?
  6. Oct 28, 2022 at 3:47 PM
    Kremtok
    Kremtok Well-Known Member
    Gary
    Houston, TX
    2021 Tesla Model 3 Long Range AWD
    2018 Triumph Street Triple RS
    Tomorrow I'm doing ribs on the 26" kettle for the first time. Going to do a snake around the outside. Any tips or tricks that I need to know about before I give it a go?
    nDub likes this.
  7. Oct 28, 2022 at 3:58 PM
    AugustaTaco
    AugustaTaco Well-Known Member
    Josh
    Augusta, GA
    2015 DCSBXSPX4X4 2017 GX460
    "Getting out of hand" - Wife
    Speaking from experience, patience to let the temp stable before putting the meat on makes all the difference. Bottom vent is usually barely open, top wide open if I can to make sure it breathes well.
    That being said, some of the best ribs I make are when I leave it all alone around 275 for 5-6 hours lol
  8. Oct 29, 2022 at 1:12 PM
    Kilo Charlie
    Kilo Charlie Disruptor
    Iowa
    2017 Inferno Off Road
    Sweet and Spicy
    Smoked meatballs and cocktail weiners
    2 pounds frozen meatballs
    24 oz little smokies
    Can of crushed pineapple
    BBQ Sauce
    Jalapeños
    275 for 2 hours stirring every 30 min
  9. Oct 29, 2022 at 3:33 PM
    Kremtok
    Gary
    Houston, TX
    Ribs were a hit for sure! Way more smoke flavor than I used to get with my Traeger.
    At first the temp wouldn't go much above 215 even with bottom vent full open. Once I opened the lid to wrap at 2 hours, temps got a lot higher and I closed bottom vent to only 1/4 open and that kept temps at about 250. My other lesson learned is that if I'm going to do one rack, I may as well do three.
    I used up about 3/4 of my snake in a little over 5 hours. How do people handle longer cooks? Can the snake be refueled?
    EPBlueTaco, nobescare, la0d0g and 2 others like this.
  10. Oct 29, 2022 at 3:55 PM
    la0d0g
    That looks great! Going to do that next weekend!
  11. Oct 29, 2022 at 5:45 PM
    nobescare
    nobescare Well-Known Member
    Mark
    43.5448° N, 80.2482° W
    2019 Highlander SE
    My 2005 prerunner had frame failure Aug 2024
    Ya when I do a brisket I end up building 2-3 snakes
    GarlicFarts, Fargo Taco and wilcam47 like this.
  12. Oct 29, 2022 at 6:00 PM
    Kilo Charlie
    Iowa
    Use a spicy BBQ sauce to balance the sweet of the pineapple.
  13. Oct 30, 2022 at 9:32 AM
    4x4runner2002
    4x4runner2002 Well-Known Member
    Zach
    2002 4x4 limited
    suspension and armor
    Ribs on. Ribs are killer hogs hot, Pitfaced spicy meat massage, and salt pepper garlic to be finished with bbq sauce. Here to the the next 6-7 hours.
  14. Oct 31, 2022 at 7:27 AM
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
    YES to many things.
    1. Snakes yeah you can just add more. It's a circle, just keep the circle going :D I have a barrel grill so I just dump on more as need be, instead of doing snakes. But I might try one next time just for the fun of it :notsure:
    2. I'm the same way. If I am filling the smoker with smoke, why have any dead space? I have a vac sealer, so when I do a smoke now I fill it. If there's any dead space, it gets filled with sausages, chicken thighs, etc.
    3. Meat is the heat sink. One rack of ribs doesn't do much, but 3, or a full smoker, will take up more of the heat and change the size, smoke, etc. You may go through more fuel if you have a full smoker full of cold meats, verses a relatively insignificant 1 rack of ribs.
    Ribs and butts are forgiving. It's hard to under or overcook them since the window of "done" is so wide.
    EPBlueTaco and Fargo Taco like this.
  15. Oct 31, 2022 at 7:32 AM
    outdoorgb
    outdoorgb (.)(.)
    Burbs of Oregon
    2014 DCSB TRD Sport Silver Sky...
    Carved pumpkins yesterday with the better half. Put the seeds on some foil and smoked on the Green Mtn. Grill along with pork loin.
    Cooled, had a few to sample... Best ever.
    Then, wife knocked plate on floor along with a glass, seeds and glass everywhere. Into garbage went my seeds.
  16. Nov 1, 2022 at 7:27 PM
    la0d0g
    :eek::(
    wilcam47 likes this.
  17. Nov 1, 2022 at 7:29 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    :annoyed:
  18. Nov 6, 2022 at 5:21 PM
    Beef Nachos
    Beef Nachos Here for a good time, not a long time
    Dallas/Ft. Worth
    2017 SR5 DCSB 4x4
    Smoked and seared a picanha for a quick dinner
    F73BAB25-81DF-42EA-B646-E3ED74F92FAC.jpg 3E578EF9-75E3-46EE-912C-285EEEB6D15B.jpg
  19. Nov 7, 2022 at 4:13 PM
    Kremtok
    Gary
    Houston, TX
    Kid wanted steak for her birthday, so I obliged:
    szidls, la0d0g, SwampYota and 6 others like this.
  20. Nov 7, 2022 at 4:58 PM
    Kremtok
    Gary
    Houston, TX
    Update:
    OhNoItsMe, PhoS, nobescare and 13 others like this.
