Food Smokers and Smoking Tips/Tricks/Techniques
Discussion in 'Food Talk' started by Polymerhead, Jul 15, 2012.
  1. May 6, 2024 at 5:06 AM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Where's the fun in that? :D
  2. May 6, 2024 at 5:11 AM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    This should be on grilling thread but since I'm here.....
    1st time using Guinness and molasses in a marinade for these ribeyes. (and 1 top round)
    F#$&ing delicious, is all I can say..
    Grey 2015, MarX, Kanyon71 and 7 others like this.
  3. May 6, 2024 at 5:13 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    I'm lazy, that's all :anonymous:
  4. May 6, 2024 at 5:16 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    they are heavy. Only thing ive had small issue with is cleaning out the ash cup. If you dont it will give an error. Lowes has different pellets. I use competition blend.
    Grey 2015 and Delta09[QUOTED] like this.
  5. May 6, 2024 at 5:19 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Rural King near me has a bunch of different kinds in store. My favorite wood is Pecan though and it seems like those are harder to find.
    Grey 2015 and wilcam47[QUOTED] like this.
  6. May 6, 2024 at 5:45 AM
    wilcam47
    Will
    Bourbon state
    I like the ease of use. I put aluminum foil under the grates on the heat shield for easier cleanup. And some disposable aluminum cups for the drip tray.
    https://www.amazon.com/Compatible-O...cint=&hvlocphy=&hvtargid=pla-4584070153341558
  7. May 6, 2024 at 6:41 AM
    Kilo Charlie
    Kilo Charlie One flat foot on the Devil's wing
    Iowa
    2017 Inferno Off Road
    @Delta09 do you have power out there?
    Pellet grills /smokers require power. There also must be a cover of some sort for weather.
    You'll want to keep your extra pellets dry so ponder a 5 gallon bucket with a gamma lid.
    A 27 gallon tote from home depot holds (3) 40 pound bags of pellets. Walmart is the cheapest place to buy pellets. I use the Pit Boss brand at $15 a 40 pound bag. Never had an issue with the pellets.
    I own several Pit Boss smokers and all of them have been reliable.
  8. May 6, 2024 at 6:47 AM
    Fargo Taco
    Fargo Taco Well-Known Member
    Not Drew but still Drew
    Fargo
    2019 TRD Pro
    Lomax tonneau cover, N-Fab Podium steps, bed mat
    :fistbump:
  9. May 6, 2024 at 6:55 AM
    Kilo Charlie
    Iowa
    One of my smokers is a vertical Pit Boss.. it's literally an outdoor easy bake oven. It's designed with a water pan so I use that (all the naysayers can just hush). I have to refill that every couple of hours but the hopper on that thing holds 60 pounds of pellets I can smoke for days without ever worrying about those. A newer version I saw will hold 80 pounds!
    For those curious, in my experience, depending on the weather, I burn about 1.5 to 2 pounds of pellets per hour. Seems to be consistent across the different styles I have.
  10. May 6, 2024 at 7:07 AM
    wilcam47
    Will
    Bourbon state
    Wow 60-80lbs!
    Kilo Charlie[QUOTED] likes this.
  11. May 6, 2024 at 7:13 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    After that much time on the smoker it's taken about as much smoke as its going to, just move it to the oven to finish it up to temp. I have done this a few times when its gone longer then I thought and my fuel has/is running out.
    Superdave1.0[QUOTED] likes this.
  12. May 6, 2024 at 7:17 AM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    I think the food takes on all the smoke it can in the 1st 30min but don't quote me on that.
    I like doing reverse smoke sears with steaks sometimes. (Maybe an hour in the smoker then flash them on a hot grill after.)
    Grey 2015 and Kilo Charlie like this.
  13. May 6, 2024 at 7:34 AM
    Kilo Charlie
    Iowa
    I got by temp on steaks this way... take them to about 125F the the reverse seared on the grill takes them to 140F then pull it and let it rest give a perfect 145.
    bkhlrTaco's[QUOTED] likes this.
  14. May 6, 2024 at 7:35 AM
    Kilo Charlie
    Iowa
    Like you don't know already I don't mess around hahaha
    Delta09 likes this.
  15. May 6, 2024 at 7:58 AM
    nobescare
    nobescare Well-Known Member
    Mark
    43.5448° N, 80.2482° W
    2019 Highlander SE
    My 2005 prerunner had frame failure Aug 2024
    I add a couple diced jalapeño to mine too
  16. May 6, 2024 at 8:12 AM
    szidls
    szidls Well-Known Member
    Scott
    Prescott Valley, AZ
    2014 MGM AC TRD OR
    Most everything I have read indicates proteins will take on smoke up to 3 hours.
    :thumbsup:smoke reverse sear.
  17. May 6, 2024 at 9:27 AM
    Beef Nachos
    Beef Nachos Here for a good time, not a long time
    Dallas/Ft. Worth
    2017 SR5 DCSB 4x4
    Thats a good rule of thumb.
    I wrap when the bark I like starts to form and pull when it’s tender (probe goes in like room temperature butter).
  18. May 6, 2024 at 9:36 AM
    Beef Nachos
    Dallas/Ft. Worth
    2017 SR5 DCSB 4x4
    As long as it is exposed to smoke, meat will continue to take it on.
    As an example, you could cook an unwrapped brisket for 12 hours with perfect smoke throughout and absolutely ruin it with dirty smoke in the last 30 minutes.
    Science says ‘things’ don’t magically become immune to smoke after a certain time or temperature.
  19. May 6, 2024 at 10:04 AM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Logic, reality, science?? On an Internet board?
    GET OUT!!
    :rofl::rofl::rofl:
  20. May 6, 2024 at 10:13 AM
    Kilo Charlie
    Iowa
    I've modified this recipe several times with additions.. the basics remain the same.
    Examples:
    Added Crawfish and Andouille Sausage with Cajun Seasonings.
    Added shredded rotisserie chicken, Buffalo Sauce and Blue Cheese.
    Added corn, Jalapeños, Cilanto, Garlic, Chipotle powder, lime zest and Cotija Cheese (think Elote or Mexican Street Corn)
