Food Smokers and Smoking Tips/Tricks/Techniques
Discussion in 'Food Talk' started by Polymerhead, Jul 15, 2012.
  1. May 7, 2024 at 2:30 PM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    I have and am seriously considering a pellet to replace my gasser. Can always keep the WSM for when I need to generate some testosterone (more than the pellet, but less than a stick burner). :thumbsup: But I need the gasser to die to justify it in my head.
  2. May 7, 2024 at 3:07 PM
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    Wish I would have bought a 26”. I bought a red 22” with the tall legs instead and regret not getting the bigger kettle almost every time I smoke something.
    A 26” is definitely in the future but don’t have space for one right now.
  3. May 7, 2024 at 3:55 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    :101010:
    :woot:
  4. May 7, 2024 at 5:48 PM
    Kilo Charlie
    Kilo Charlie Disruptor
    Iowa
    2017 Inferno Off Road
    @Delta09
    Don't be alarmed if you see the digital temp fluctuate... the pellet smoker / grills cycle much like an electric oven. It feeds the pellets to get to temp, then it cools down then cycles up again. If you put a $5 oven thermometer on the grate you'll see that the grate temperature remains at a constant temp.
  5. May 8, 2024 at 4:40 PM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    So first use today. Sorta a success, and sorta a failure, but more of a learning curve. Two racks of St. Louis style ribs on sale at the local Food Lion. Rubbed with Rajin Cajun seasoning and let it sit for a hot minute while I got the pellets going. Foil wrapped the top rack and set them on. I initially had it set on "S" or smoke mode. 30 minutes in I just felt like it just wasn't doing any cooking. This is where I messed up, but lesson learnt. Turned it up to 220-250 for the entire 3.5hours I had them on there. Periodically coated them with apple cider vinegar and the last hour I moved them to the bottom rack and added sauce.
    This is almost done here
    Pulled them off and let sit for a good 20 minutes or so. For the most part they were pretty good. The thinner parts were a little dried out and the thicker fattier parts were really good. You could taste the hint of smoke, so it definitely "smokes" even out of "S" mode. Overall 6/10 compared to what I've done before. However, I loved the fact that I wasn't constantly babysitting the thing. Only time I checked up on it was to wet it down, so that's a plus to me.
  6. May 8, 2024 at 4:58 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    What pellets did you use?
    Delta09[QUOTED] likes this.
  7. May 8, 2024 at 5:00 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Pit Boss comp blend. I'll have to experiment with different ones as well I recon. Although as far as flavor, it was top notch. Not overpowering, but there.
  8. May 8, 2024 at 5:02 PM
    Kremtok
    Kremtok Well-Known Member
    Gary
    Houston, TX
    2021 Tesla Model 3 Long Range AWD
    2018 Triumph Street Triple RS
    You'll want to verify the smoker temp with an good quality thermometer. Like the dial thermometers on most other grills, the digital thermometer on your pellet grill can't always be trusted. On my Traeger, it consistently read about 50F lower than the actual temperature and I ruined a lot of food before I figured that out.
    Superdave1.0 and Delta09 like this.
  9. May 8, 2024 at 5:03 PM
    wilcam47
    Will
    Bourbon state
    I think some put a smoke tube in if you dont get enough smoke flavor. We dont like a lit of smoke flavor so it works out
  10. May 8, 2024 at 8:31 PM
    Kilo Charlie
    Iowa
    @Delta09
    I use the Pit Boss Competition Blend for everything. I could save you the trouble of trying all the other flavors as I've been there and done that, but I'll let you decide what is best for you
    As @Kremtok mentioned, you can buy an oven thermometer for around $5 and set it right on the grate so you can monitor actual temps at food level. They're usually rated to 500F so no issues other than cleaning the face of it now and then with soapy water and a green Scotch bright pad.
    I've found that a 2-2-1 method works best for me, but I suggest a small notebook to keep track of your cooks so you remember what you did, what you liked or not and what you wanna try the next time.
    You can also turn your ribs the other direction and see if that makes a difference.
    Fargo Taco, la0d0g, Delta09 and 2 others like this.
  11. May 9, 2024 at 5:59 AM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    So north-south works best?? :rofl::rofl:
    :boink:
    nobescare and Delta09 like this.
  12. May 9, 2024 at 6:04 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    That's the way mine were facing sooo maybe not... o_O
  13. May 9, 2024 at 6:19 AM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Good point. So have them directed toward the sunrise.
  14. May 9, 2024 at 6:43 AM
    Kilo Charlie
    Iowa
    It's more about the direction of the air flow through the chamber and the thick side vs thin side of the meat. Some of that science stuff. But what do I know?
    BigEasy, TacomaUSA, nDub and 3 others like this.
  15. May 9, 2024 at 7:05 AM
    Kanyon71
    Kanyon71 Well-Known Member
    MI
    I use Lumberjack Competition Blend pretty much exclusively. Had great luck with and the flavor from them is great. Their Comp blend is M-H-C (Maple, Hickory and Cherry). Wife has been asking me to try out the charcoal ones, every once in a while we miss that charcoal grill taste on our burgers or steaks. I may try the pellets or see if I can find a cheap used Weber.
  16. May 9, 2024 at 7:11 AM
    nDub
    Lead Free Gasoline
    For sure. I flip my ribs and turn them around so that each side gets time being close to the heat. Same with other cuts of meat.
    I like to take an active role in smoking!
  17. May 9, 2024 at 8:10 AM
    Kilo Charlie
    Iowa
    I wasn't a fan of the charcoal pellets but everyone has different tastes. Buy a small bag to try out and then you can buy a bigger bag if you like them
    The Pit Boss Competition Blend is Hickory, Maple and Apple.
    nobescare, wilcam47 and Grey 2015 like this.
  18. May 9, 2024 at 8:16 AM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Just having some fun this morning. I was thinking of “rib-henge” with a circle of ribs all aligned for sunshine on the summer solstice.
  19. May 9, 2024 at 8:21 AM
    Kilo Charlie
    Iowa
    Not sure what it's called when you take a rack and tie it in a circle like a crown... sure those would want to be facing the sun too! Haha
    wilcam47 likes this.
  20. May 9, 2024 at 11:26 AM
    nDub
    Lead Free Gasoline
    Like this:
    la0d0g, szidls and nobescare like this.
