Food Smokers and Smoking Tips/Tricks/Techniques
Discussion in 'Food Talk' started by Polymerhead, Jul 15, 2012.
  1. Dec 19, 2016 at 9:02 AM
    #6241
    Kanyon71
    Kanyon71 Well-Known Member
    MI
    Ya I want to try and figure something out. I would like to know that the hopper is even like only 1/4 full or something. I'm just glad I checked ahead of time instead of getting everything ready getting it all started up and THEN realized that it was almost empty lol.
    scottalot[QUOTED] likes this.
  2. Dec 19, 2016 at 9:08 AM
    #6242
    Kanyon71
    MI
    Could be like some of the guys who put the smoke stacks on their diesel trucks and have it like 4' above the smoker lol.
  3. Dec 19, 2016 at 9:21 AM
    #6243
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    I tried something a little different this weekend.
    6lb pork shoulder
    Dry rubbed and vacuum sealed for 24 hours in the fridge.
    Sous Vied at 165 degrees for 24 hours
    And finished on the smoker at 260 for 3.5 hours
    By far the most moist pulled pork I've ever had. I'm doing another one for new years I'm going to mix it up and do 20 hours in the bath and 8 at 200 degrees on the smoker to see how that turns out
  4. Dec 19, 2016 at 9:25 AM
    #6244
    JLee
    Jerry
    Grass valley CA
  5. Dec 19, 2016 at 9:28 AM
    #6245
    JLee
    Jerry
    Grass valley CA
    It hooks on anything thinner then about 1.25" the cooler works well on the long cooks and the Sous Vied buckets are like 150 for the insulated ones.
  6. Dec 19, 2016 at 9:53 AM
    #6246
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    I thought the same...
  7. Dec 19, 2016 at 10:14 AM
    #6247
    Kanyon71
    MI
    The only thing that I can say worries me about this method is there used to be a lot of backlash on on chemicals leaching out from the plastic bags. Is this still an issue? I have wanted to try this method out but never have based on that.
    bigfoote13 likes this.
  8. Dec 19, 2016 at 11:31 AM
    #6248
    anonemoose
    anonemoose Well-Known Member
    Bill
    Big Pine, Calif
    2015 White TRD Sport V6 DCSB
    Ride-Rites, Everything Weather-Tech Makes Added some 12 volt outlets with relays
    Our GMG has wifi temp/timer/low pellets. They sell replacement parts might give you an idea on how to do it.
    http://greenmountaingrills.com/products/grills/davy-crockett-pellet-grill-wifi/
    Kanyon71[QUOTED] likes this.
  9. Dec 19, 2016 at 11:39 AM
    #6249
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Not so much of a modern issue, and sous vide is such low temperatures, I wouldn't be worried about it at all.
    There's a lot of backlash and fear mongering when it comes to consumer grade chemical exposure, like plastic bags, can linings, and thermal receipts from businesses. Now things are BPA free, but all that really meant is that they used a different chemical called BPS, which is essentially a twin to BPA but with far less studying done on it and with the same known problems, with slight variations.
    Unless you're one of those kinds of people who adamantly refuse to touch their receipts from their grocery stores with their bare hands, don't use microwaves, and don't eat off plastic utensils, I wouldn't think anything of sous vide cooking. It's safe.
    Kanyon71[QUOTED], JLee and Cold Iron like this.
  10. Dec 19, 2016 at 11:40 AM
    #6250
    bigfoote13
    bigfoote13 Well-Known Member
    Joe
    South Florida
    15 TRD SPORT
    2016 Sport suspension 1/2 spacer up front and aal in rear SCS Stealth 6 17 inch wheels Wildpeak AT3 265 70 17
  11. Dec 19, 2016 at 11:50 AM
    #6251
    anonemoose
    Bill
    Big Pine, Calif
    Yeah, love our Davy Crockett, I don't cook in the house oven anymore. Take it camping and have found it to be very useful with all the campfire/charcoal restrictions during the Calif fire season (all year now it seems). Running on 12vdc, I put plugs on the front toolbox of our teardrop to make it easy to set up on either side. Of course I found out I can run it directly from the solar panel but easier to run it on battery and charge at the same time so there is no possible interruptions.
    bigfoote13[QUOTED] likes this.
  12. Dec 19, 2016 at 1:01 PM
    #6252
    bigfoote13
    Joe
    South Florida
    15 TRD SPORT
    I was contemplating a DC for our Florida room but found out the exhaust fan was going to cost twice as much as the grill. So I decided that buying the DB with wifi would be a much better use of money!
  13. Dec 19, 2016 at 1:09 PM
    #6253
    Cold Iron
    Cold Iron Well-Known Member
    Mn.
    2013 AC T|X Baja
    I have to agree that a Weber 22 kettle is a great way to start especially if you don't have a charcoal grill. They are very versatile and I have the rotisserie for both the Weber Genesis and Kettle. Meat always taste good on a stick.
    I have a slow'n sear that is linked to however not as pleased with it as I thought I would be. For searing it doesn't take up enough surface area even with the water tray it doesn't come to the half way point across the grill surface. And you have to add a lot of coals to it so that they come to right below the grill surface. I ended up going back to the old way of sear and slide using the Weber 7402 charcoal rails to hold another charcoal grate right below the meat.
    But I like to Sear and Slide large chunks of meat obviously
    When using the kettle for smoking and the sear'n slide I didn't get the long burn down time I was hoping for. Eventually ended up going back to the Weber 7403 Char Baskets on each side of the grill and minon method. With the sear'n slide it pushes the meat to the other side and seems like less room. The baskets concentrate the meat into the center of the grill where there is more room. Then again on Amazon the sear'n slide has nothing but positive reviews so maybe it is just me. I don't care for the reverse sear using charcoal and still sear and slide so maybe I am just too old and set in my ways LOL.
    I like my Weber's obviously and normally grill ~3 times a week. Would smoke more often if it wasn't for the cold, and if I had a decent smoker. Have a Masterbuilt smoker that hasn't been used in a long time and I only use it as a dedicated fish smoker. Which it doesn't excel at to say the least. I use a Genesis for quick cooks on hotdogs, brats, sausage burgers, etc. The Kettle does a decent job for most of my needs. However....
    Been wanting to get a WSM for years and reading the Weber Virtual Bullet website for a long time. My concern is the cold here. It was -21F yesterday but up to 16 above today. Not all that uncommon here in the winter. The thermal jackets for the WSM look like a PITA for refueling, adjusting, etc. Wind shields only work up to a certain point and there is still the cold and temps change a lot during the day. It is a struggle with the kettle and will be with a WSM too with the wide temperature fluctuations.
    This weekend was looking at the Char-Griller 20" Akorn Kamado Kooker. It is a wanna be BGE and realize it will not last as long as a WSM and has no where near the surface area to cook on.
    But being insulated even if it is with air I think would do well for consistency. Debating if I should just bite the bullet :D and get a WSM like I've always wanted and work on modding it for the cold? Or go with something like the Kamado. Or am I missing something else? I have no desire to go with pellets, and electric will not work in the winter here. Thoughts?
    13SilverStreakTRD and Woundedyak like this.
  14. Dec 19, 2016 at 1:36 PM
    #6254
    horstuff
    horstuff Re-member
    PNW
    2015 Base 2.7 Access Cab 4x4 5 sp
    Great writeup. As far as searing on a WSM, you just remove the dome and middle portion, grab the grate, and set it directly on the coal ring. Did just that last night when reverse searing a trip tip. The coals couldn't be closer (if you want them to be close) and there's no sacrifice of grate room. Very quick and easy. Btw, I haven't found much issue at all with external air temps being an issue with the WSM. Wind yes, temp no. Once it's seasoned and has a decent coating of flat dull stuff on the inside (after the first couple smokes), it holds temp amazingly well no matter the outside temp. It's all about fiddling with it for your first, say, 5 smokes. After that, you are its master.
  15. Dec 19, 2016 at 1:39 PM
    #6255
    horstuff
    horstuff Re-member
    PNW
    Of course, for the ultimate, get a Primo. I want to but it'll wait... the WSM is just ducky for now.
    Cold Iron likes this.
  16. Dec 19, 2016 at 1:58 PM
    #6256
    bigfoote13
    Joe
    South Florida
    15 TRD SPORT
    I am confused about the sear n slide? Is that a product (slow n sear) or a cooking method?
    Thanks
  17. Dec 19, 2016 at 2:02 PM
    #6257
    Cold Iron
    Mn.
    2013 AC T|X Baja
    That is exactly what Meathead says too LOL. This thread has me reading there again even though I have his book. The general consensus from him and those on the board there is a kamado is the only way to fly in really cold temps. I did find several building insulated sheds for the WSM with vents of course and using a pit viper mod for heat control. I forgot about those although it does bring the cost up to closer to at least $450-$500 for the WSM. I doubt any of us are into this to save money however, it is for the damn fine food!
  18. Dec 19, 2016 at 2:09 PM
    #6258
    Cold Iron
    Mn.
    2013 AC T|X Baja
    My bad the product is Slow'n Sear. I got mine from Amazon
    Sear and Slide is where you cook your meat as hot as you can over flames for a short time then move it to the other side of the grill to finish cooking using indirect heat.
  19. Dec 19, 2016 at 4:14 PM
    #6259
    bigfoote13
    Joe
    South Florida
    15 TRD SPORT
    I like my slow and sear xl but I agree the sear area is not big enough. I like the using vortex with grill grates to get the sexy bbq lines!
  20. Dec 19, 2016 at 5:32 PM
    #6260
    grdgz97
    grdgz97 Well-Known Member
    Georgetown, TX
    2015 TRD Sport DCSB
