Food Smokers and Smoking Tips/Tricks/Techniques
Discussion in 'Food Talk' started by Polymerhead, Jul 15, 2012.
  1. Mar 12, 2017 at 2:37 PM
    #7281
    Woundedyak
    Woundedyak Well-Known Member
    Indy
    Some smoke vision for yall! 2 1/2 in center cut chops injected with sum love. Decided to pop a couple of pineapples on top.
    wilcam47, Kanyon71, la0d0g and 3 others like this.
  2. Mar 12, 2017 at 3:23 PM
    #7282
    itzyoboipaul
    itzyoboipaul Well-Known Member
    Paul
    PFville, TX
    2020 TRD OR Cement
    Great minds think alike I did the screws also on top corners lol
    wilcam47, la0d0g and truchador like this.
  3. Mar 12, 2017 at 4:07 PM
    #7283
    drwx
    drwx Well-Known Member
    M'boro, TN
    2017 DCSB TRD Offroad 4x4 BBP
    I've never needed to prop open the door on my 22.5 wsm. In fact, I usually strap it down with a ratchet strap to keep it tight and prevent leaks. The 22.5s like to run hot, and by hot I mean 280-300. I'm normally running with the 2 of the 3 bottom vents closed and the 3rd one open about 1/4" and the top mostly closed.
  4. Mar 12, 2017 at 5:26 PM
    #7284
    ChadVKealey
    ChadVKealey Well-Known Member
    Philadelphia, PA
    2017 Silver Sky Tacoma SR5
    None (yet)
    Good to know. My door was way out of whack out of the box, but I managed to get it pretty well shaped with no visible gaps. We'll see how well it seals after a cook or two and order a gasket kit if needed.
  5. Mar 12, 2017 at 7:22 PM
    #7285
    itzyoboipaul
    Paul
    PFville, TX
    2020 TRD OR Cement
    I used to do 225degrees 12hr brisket cook. But ever since I learned and mastered the quick 5hr high heat brisket that's what I've been doing lately. Taste about the same.
    When I'm doing a high heat brisket ,I'm running the WSM between 350-375 degrees which is why I prop the door open
    I have a nice tight stainless door for other slow cooks.
  6. Mar 12, 2017 at 7:58 PM
    #7286
    horstuff
    horstuff Re-member
    PNW
    2015 Base 2.7 Access Cab 4x4 5 sp
    I do the 5 hour 350 brisket a lot too, never had to prop door open on my 18.5 WSM. Wonder what the diff is? I start out with full chimney unlit and dump a full chimney lit on top of that. Will hold 350 for at least 6 hours.
    scottalot and Woundedyak like this.
  7. Mar 13, 2017 at 5:22 AM
    #7287
    Woundedyak
    Indy
    If you guys want to prop the door open with out using some back country engineering. Get the cajun bandit door and install a compression latch. You can un hook the latch and it holds the door open a few inches
    https://www.amazon.com/gp/aw/d/B002...sion+latch&dpPl=1&dpID=41wLEmrURdL&ref=plSrch
    scottalot likes this.
  8. Mar 13, 2017 at 5:26 AM
    #7288
    Woundedyak
    Indy
    Forgot to post finish pics. The boss did an amazing job on some mash taters and blanched shrimp in a garlic butter sauce.
    grdgz97, TroutBum, truchador and 4 others like this.
  9. Mar 14, 2017 at 4:33 PM
    #7289
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Tip of the day, get your propane bottle dates checked. They changed the rules from every 12 yrs to every 10yrs...I had to exchange mine today since it was out of date and the guy wouldnt fill the old one which there prob wasnt anything wrong with it.:rolleyes:. Our 100lb tank is out of date and will have to get replaced once we run out of propane this summer. Amerigas is supposed to be able to fix them/replace the valves or whatever they do. I dont know the cost though. Just an FYI to prevent hassles next time you fill your bottles.
    Boerseun, Kanyon71 and robssol like this.
  10. Mar 14, 2017 at 4:54 PM
    #7290
    horstuff
    horstuff Re-member
    PNW
    or use charcoal :crapstorm: :D
    Boerseun, bigfoote13, grdgz97 and 6 others like this.
  11. Mar 14, 2017 at 5:17 PM
    #7291
    wilcam47
    Will
    Bourbon state
    I dont think that will work inside the house;) I do have a charcoal smoker too...but I like the quick heat on propane grill :)
    Boerseun, WBF610 and scottalot like this.
  12. Mar 14, 2017 at 5:44 PM
    #7292
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Devil Horns by Andres, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers, Pop and Lock tailgate theft deterrent mod 2.0, Plasti-dip rear bumper. Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    Thanks for the heads up:wink:
    Ditto, but our camper uses propane for refrigeration, heating, two burner cook top.:thumbsup:
  13. Mar 14, 2017 at 5:50 PM
    #7293
    wilcam47
    Will
    Bourbon state
    I just checked one in my shop and its good, the house one need updated though. The camper should be good but I have to verify. We got our camper 2 years ago so Im thinking its good.
  14. Mar 14, 2017 at 6:09 PM
    #7294
    TroutBum
    TroutBum Well-Known Member
    Michigan
    06 SR5 AC 4x4 Sold, 17 Sport 6MT DCSB, 2020 OR DCSB
    Leer 100R
  15. Mar 14, 2017 at 7:30 PM
    #7295
    Woundedyak
    Indy
    Well done! Gotta respect the dedication. This is a nasty cold snap
    grdgz97 and TroutBum[QUOTED] like this.
  16. Mar 16, 2017 at 1:29 PM
    #7296
    DBTaco
    DBTaco Well-Known Member
    NC
    '08 4x4 TRD off road
    Lately I've been thinking about getting my first charcoal grill. I've always had gas grills but I'm wanting to try charcoal. I've been looking at different grills and I've looked at the Char-griller 2121 version at Lowes. If I went this route, I would also want to get the smoker box that attaches to the side of the grill. Would this be a good one to learn on and start experiencing with charcoal? I would keep my gas grill for when we needed something grilled fast. Just to give me an idea on time, how long does it take to grill boneless chicken breast on charcoal from starting charcoal to finishing?
    jpneely, robssol and WBF610 like this.
  17. Mar 16, 2017 at 1:32 PM
    #7297
    WBF610
    WBF610 Member well known
    Carey
    Eastern PA
    2016 DC OR
    mats, flaps, and stickers. Extang solid fold 2.0. Mobtown sliders and full skids. AVS vents
    Check out the Oklahoma Joe's 4 or 3 in one. I have it, and like it so far.
    I don't do chicken, can't help you there.
  18. Mar 16, 2017 at 1:42 PM
    #7298
    la0d0g
    running for the hills
    For crawling not hauling
    I won't cook poultry without bones so not sure on the chicken cook time but I always plan on 30 minutes to get the grill rolling.
  19. Mar 16, 2017 at 1:43 PM
    #7299
    robssol
    Rob
    S. Wisconsin
    You'll definitely want a chimney starter. I think they're faster than using petroleum with a better taste. Times vary greatly depending on how much charcoal you light, size and thickness of the meat, and alcohol consumption :rolleyes:
  20. Mar 16, 2017 at 2:13 PM
    #7300
    horstuff
    horstuff Re-member
    PNW
    Definitely get a chimney starter, don't use that nasty lighter fluid crap.
    Good briquettes make a difference.... tons of people swear by the very common easy to find Kingsford blue, but Ive switched to Stubbs. I was definitely noticing an ammonia type smell using the Kingsford, and with the Stubbs there's none of that. Lowes carries Stubbs.
    When I was in Burbank I bought my sister a Weber 22" kettle, and I also bought a couple of coal baskets that could be held to one side for smoking. It worked great. IMO, a big Weber kettle (they've been around for 8700 years, well proven design) and a coal basket or two is a very versatile, effective, affordable setup for all your BBQ needs. For grilling, just remove the coal baskets. There's also a special contraption that works even better for smoking that the coal baskets, but maybe you'll graduate to one of those if you find you even want to smoke anything.
    I do most of my BBQ in a Weber Smoky Mountain, but those are designed more for smoking, and grilling isn't really what they do. I *have* moved the grill to the bottom portion of the WSM to get direct heat, but it's VERY direct heat. Great for a quick sear.
    Grilling boneless chicken breasts... including getting the coals lit and placed, I would figure (for the above mentioned Weber 22" kettle) about 10 minutes per side until an internal temp of 160.
    FFBlack, Woundedyak and bigfoote13 like this.
