Food Smokers and Smoking Tips/Tricks/Techniques
Discussion in 'Food Talk' started by Polymerhead, Jul 15, 2012.
  1. Apr 24, 2017 at 8:55 AM
    #8521
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    I was using my electric smoker and it appears I had evaporative cooling which stalled it, also why it was a little dry. I should have wrapped it when it got to 170 then let it cook the rest of the way. Oh well next time :)
    scottalot likes this.
  2. Apr 24, 2017 at 9:05 AM
    #8522
    drwx
    drwx Well-Known Member
    M'boro, TN
    2017 DCSB TRD Offroad 4x4 BBP
    what temp did you take it to? there's so much fat in a pork shoulder that it's almost impossible to dry out.
  3. Apr 24, 2017 at 9:23 AM
    #8523
    wilcam47
    Will
    Bourbon state
    it was at 230 stalled i took it up to 275 and it stayed at 175. so i covered it put it in the oven@ 300 for 1hr to 190
  4. Apr 24, 2017 at 9:30 AM
    #8524
    drwx
    M'boro, TN
    go higher... i take pork butts to at least 195F. any lower and they are really hard to pull and may seem dry. the collagen in the meat doesn't really start to melt until 192F. really on pork butt unless you are really wanting it to take a long time, there's no need to keep the smoker at 230F. i shoot for the 250-275 range. i also try to not cook any that are bigger than 6 pounds and prefer the ones in the 4-5 pound range. if they are on sale and have 8 pound butts, i ask them to cut them in half so i have 2 4 pound butts. you get more bark and it cooks faster.
    scottalot and wilcam47[QUOTED] like this.
  5. Apr 24, 2017 at 9:31 AM
    #8525
    Woundedyak
    Woundedyak Well-Known Member
    Indy
  6. Apr 24, 2017 at 9:33 AM
    #8526
    wilcam47
    Will
    Bourbon state
    Do you cover yours with foil at all? How long a cook time? Yeah next time I'll start out at higher temp. Im definitely still learning...I wish I would have gotten into BBq many years ago...
  7. Apr 24, 2017 at 9:34 AM
    #8527
    wilcam47
    Will
    Bourbon state
  8. Apr 24, 2017 at 10:03 AM
    #8528
    truchador
    truchador Well-Known Member
    Otto
    WV
    15 DC OR
    weathertech, seat covers, scratches
    Gross lol I'd leave those ones
    U probably find a bunch at burn sites right?
    wilcam47[QUOTED] and scottalot like this.
  9. Apr 24, 2017 at 10:07 AM
    #8529
    drwx
    M'boro, TN
    i don't foil nothing while it's cooking. i do tent foil over it while it is resting.
    i shoot for 1.5-2 hours per pound. with this math, a 4 pound butt should be done in less than 8 hours.
    wilcam47[QUOTED] likes this.
  10. Apr 24, 2017 at 10:14 AM
    #8530
    wilcam47
    Will
    Bourbon state
    lol...yeah years ago I remember getting a plastic grocery bag full of them in one outing...2015 was a good year, I gave a bunch away. last year was a bad year, I only had a handful of them.
    cool I'll keep that in mind for next time, I can only get better at it the more I smoke :)Ive typically been cooking ribs and brisket but with all the pork shoulders being done and pics posted I had to get in on it ;)
  11. Apr 24, 2017 at 10:15 AM
    #8531
    drwx
    M'boro, TN
    if you want pork butt without the time commitment, look up "pork burnt ends". there's a lot of recipes and pictures on this thread.
  12. Apr 24, 2017 at 10:19 AM
    #8532
    wilcam47
    Will
    Bourbon state
    I like pulled pork for a sammich;) its also good as carnitas in a tomatillo sauce:hungry:
    Kanyon71 likes this.
  13. Apr 24, 2017 at 10:21 AM
    #8533
    la0d0g
    running for the hills
    For crawling not hauling
    I fatty without stuff rolled inside makes me sad.
    @wilcam47 made tortillas on friday using your recipe. They came out a little doughy but I think that's because I used bread flour and a mixer. Thanks for the recipe though, now I'm on a mission to make great tortillas!
    wilcam47, Smtaco89 and scottalot like this.
  14. Apr 24, 2017 at 10:25 AM
    #8534
    wilcam47
    Will
    Bourbon state
    How long did you cook them? they should kinda bubble up and have just slightly browned, then flip. I just use AP and hand mix...its a pain but changes to the right consistency. Bacon grease works great or even coconut grease.
  15. Apr 24, 2017 at 10:31 AM
    #8535
    la0d0g
    They were on the griddle for a couple mins each side. I definitely think using AP will make a difference and mixing the lard with the dry ingredients first prior to adding the water too.
  16. Apr 24, 2017 at 10:45 AM
    #8536
    wilcam47
    Will
    Bourbon state
    yeah I usually only go about 1minute on the first side and 45seconds on the second, if you are doing 2 minutes you should roll out the tortilla thinner.
    I mix the grease in the dry flour with pastry blender till its smaller pea-sized pieces similar to making a pie crust, then incorporate the hot (not boiling) water.
  17. Apr 24, 2017 at 10:47 AM
    #8537
    la0d0g
    Copy that. I didn't get any pea sized pieces and I definitely think I could have rolled them thinner too. Can't wait for next time! Might be tonight.
  18. Apr 24, 2017 at 10:50 AM
    #8538
    Gasturbine
    Gasturbine Well-Known Member
    Central Ohio
    2011 Regular Cab 2.7l 5-speed 4WD
    32" BFG KO tires on MT rims, Front lifted 2", N-Fab 12,000lb front pull point w/10,000lb red clevis, mud flap delete, tail pipe delete, 20" LED light bar, 2 Hella 500s, N-Fab light bar mount, tinted windows.
    Baby Back ribs on the Weber Smokey Mountain.
    Rib prep.
    Start smoker.
    Home made rub, and halved.
    225, perfect.
    Add Hickory wood, and close her up.
    Started to drizzle a bit...improvisation.
    3 hours later.
    Foil wrap with some apple and pineapple juice.
    2 hours later, finish on the grill with home made BBQ sauce.
    This one has my name on it.
    With my home made IPA.
    [Burp]
    Kanyon71, Boerseun, grdgz97 and 10 others like this.
  19. Apr 24, 2017 at 10:52 AM
    #8539
    wilcam47
    Will
    Bourbon state
    You'll notice a difference hand mixing. The blender would work but maybe only 2-3 minutes as with a blender its typically half the time of hand mixing.
  20. Apr 24, 2017 at 11:08 AM
    #8540
    la0d0g
    Cool. I might try the Cuisinart too st some point.
