Food Smokers and Smoking Tips/Tricks/Techniques
Discussion in 'Food Talk' started by Polymerhead, Jul 15, 2012.
  1. May 5, 2017 at 2:13 PM
    #8861
    Sleipnir
    Sleipnir Still havent found that stupid snipe
    I'm a horse
    Asgard
    Furd Rangero Ecoboost
    Seasoning the new grill for tomorrow. Got a 12.5 lb brisket and some rub to let it sit over night! Also bought a 40 lb bag of hickory wood to cook with :D just to be clear on want to have the brisket in the fridge over night right?
    wilcam47, Woundedyak and SpruceTaco like this.
  2. May 5, 2017 at 2:15 PM
    #8862
    horstuff
    horstuff Re-member
    PNW
    2015 Base 2.7 Access Cab 4x4 5 sp
    With brisket I trim fat to 1/4" and then lots of kosher salt and fresh ground pepper overnight on a cookie rack in fridge lightly covered. That's just one way, I'm sure others will chime in here.
  3. May 5, 2017 at 2:17 PM
    #8863
    Sleipnir
    I'm a horse
    Asgard
    Lady at the meat market said she leaves all the fat on and cooks it fat side up this way it cooks in its fat. Also said a few hours before it's done wrap it in foil shiny side in to real cook the bark
  4. May 5, 2017 at 2:24 PM
    #8864
    horstuff
    horstuff Re-member
    PNW
    Fat up, fat down is a never ending who knows... everybody does it thier own way. I do fat up. As far as it basting in it's fat, that's a myth. The meat aint gonna get basted. And, leaving the fat on prevents your seasonings from doing any good, because nobody will eat that much fat (probably:) ). And the foil... wrapping in foil destroys bark, not help. No foil = crunchy bark. Foil = no crunch, no bark. BUT, having said all that, there's really no way to fuck it up except under or overcooking. Just watch the IT and pull at 200-205 and let rest for awhile, then slice. It'll be good no matter all this other hooey.
    wilcam47 likes this.
  5. May 5, 2017 at 2:26 PM
    #8865
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    2012 Spruce Mica TRD Sport
    Tinted windows 5%, sill protectors, TRD stubby antenna, weathertech in channel rain guards, wheathertech floor mats, BHLM, Truxedo low pro qt, DTRL deleted, anytime backup camera, bed storage locks, fog lights on anytime, tailgate theft deterrent, painted engine cover, relocated horns, l.e.d bed lights, l.e.d engine bay lights, l.e.d lights above cup holders, in glove box, rear cup holder, in console storage & cubby next to steering wheel, Grillcraft grill, 17x8.5 SCS Ray10's, 35x12.50 Nitto Ridge Grapplers, Borla cat back exhaust, map & dome l.e.d's, TEQ badge on grill, Redline tuning hood struts, Maxtrac spindles, SPC Light Racing UCA's, Bilstein 5100's front set at 0 with OME 885's & extended length Bilstein 5100's in the rear, All Pro expedition leaf springs & 2" blocks, extended brake lines front & rear, 1.5" 4crawler drive shaft spacer, Beefed Taco carrier bearing drop, 1.25" spidertrax wheel spacers on rear, Kenwood DNX570 touchscreen with navigation, 30" led light bar in lower bumper opening, 1/4" top plate spacer drivers side, Bullet Proof Fabricating skid plate, Cali Raised ditch lights & Rago f Fabrication brackets, Amp Research power steps, smoked l.e.d 3rd brake light, Wet Okole seat covers, under cab LED'S tied to dome circuit
    That butt I posted earlier I cooked fat up, seemed a little greasy. I'm gonna go back to fat down. I've never done a brisket but foe my butts I like to inject them with saltwater then when the water cooks out the salt will stay in the meat & I pat them dry then a light coat of mustard with a dry rub on top. I let them sit in the fridge over night.
    I like to let them cook for a couple hours uncovered then wrap with foil for the rest of the time.
    Sleipnir[QUOTED] likes this.
  6. May 5, 2017 at 2:27 PM
    #8866
    Capt Jrod
    Capt Jrod Well-Known Member
    Jarrod
    Northern Ohio
    15 WHITE DCSB 4x4 TRD SPORT
    I brine my chicken over night, but the pork and beef get a starting rub, 2 hrs of smoke, a finishing rub, into the foil, then dried up a bit in the end. Pulled pork doesn't get dried. Ribs get some sauce cooked on then they rest before serving. Chicken doesn't get foil
    Sleipnir likes this.
  7. May 5, 2017 at 2:27 PM
    #8867
    Sleipnir
    I'm a horse
    Asgard
    She's looking mighty fine now :hungry:
    truchador, Woundedyak and SpruceTaco like this.
  8. May 5, 2017 at 2:30 PM
    #8868
    Capt Jrod
    Jarrod
    Northern Ohio
    We run the butts hot for the first hour. We let it spike the temp around 375 and then catch it on the way down to hold about 275. In the foil we go to 300 until it turns to mush. That first heat gets some nice and crispy corners and ends
    SpruceTaco likes this.
  9. May 5, 2017 at 3:36 PM
    #8869
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    First brisket I did, I didn't get down to 1/4" or less and I thought that there was too much fat on the finished brisket.
  10. May 5, 2017 at 3:57 PM
    #8870
    Woundedyak
    Woundedyak Well-Known Member
    Indy
    On big batches I use a slicer and vacuum sealer store. Smaller batched I try to keep my knife skills up to par. If you are in the market for a slicer. Just stick with a hobart. Reason being you will always be able to find parts and new blades.
    Cold Iron likes this.
  11. May 5, 2017 at 4:01 PM
    #8871
    Woundedyak
    Indy
    Yes. Wrap tightly or no wrap at all. Let it sit on the counter an hour or so before placing on cooker
  12. May 5, 2017 at 4:19 PM
    #8872
    horstuff
    horstuff Re-member
    PNW
    I always figured the "tightly wrap" in the fridge will screw up the rub (S&P). That's why I just lightly cover, meaning a big piece of foil just tented over it, not even touching, overnight. I probably don't even need to do that but I want my baby at least protected from spills and whatnot :D
    Woundedyak[QUOTED] likes this.
  13. May 5, 2017 at 4:32 PM
    #8873
    Woundedyak
    Indy
    Just sum scrimp on the barby
    Kanyon71, truchador, wilcam47 and 2 others like this.
  14. May 5, 2017 at 4:34 PM
    #8874
    WBF610
    WBF610 Member well known
    Carey
    Eastern PA
    2016 DC OR
    mats, flaps, and stickers. Extang solid fold 2.0. Mobtown sliders and full skids. AVS vents
    I did a flank steak on the grill this evening. Was outstanding.
    truchador, wilcam47 and Woundedyak like this.
  15. May 5, 2017 at 5:37 PM
    #8875
    Justanotherhemi
    Justanotherhemi Space Cowboy/Ninja
    Rick James
    Area 52 (because area 51 was full)
    Intelligent Life Exists
    Bone In Ribeye, Chicken Breast & Sausage awaiting the grill
    Kanyon71, 75z28, truchador and 3 others like this.
  16. May 5, 2017 at 6:18 PM
    #8876
    Woundedyak
    Indy
    Dam son! Looks like those ribeyes are twins!
    scottalot likes this.
  17. May 5, 2017 at 7:01 PM
    #8877
    Cold Iron
    Cold Iron Well-Known Member
    Mn.
    2013 AC T|X Baja
    Agree. I know Hobart has been around since at least the 70's and those that have them still have them. Although I don't use a slicer. In a group setting always enough people that want to take turns seeing who can slice the best pieces you don't even need to do it yourself.
    And that is where the high walled cast iron griddle really shines in the morning. Weighs about 40 pounds and holds the heat for a long time.
  18. May 5, 2017 at 7:20 PM
    #8878
    WBF610
    Carey
    Eastern PA
    2016 DC OR
    I believe I'm going to finish smoking some cheese I bought a few weeks ago. High of 56 tomorrow, maybe rain, should be easy to keep temps low. Then I'm doing a few racks of ribs and a little pork loin.
    scottalot, Cold Iron and Woundedyak like this.
  19. May 5, 2017 at 7:21 PM
    #8879
    truchador
    truchador Well-Known Member
    Otto
    WV
    15 DC OR
    weathertech, seat covers, scratches
    I use cherry almost exclusively because it typically makes up most of my firewood pile lol. It works great :)
  20. May 5, 2017 at 8:12 PM
    #8880
    Justanotherhemi
    Rick James
    They did make it to the grill. Medium to Medium well 1 in cut. Needless to say they were the go to food for the evening for our guests.
    scottalot, TroutBum, wilcam47 and 2 others like this.
