Food Smokers and Smoking Tips/Tricks/Techniques
Discussion in 'Food Talk' started by Polymerhead, Jul 15, 2012.
  1. May 12, 2017 at 5:58 AM
    #9021
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    I cooked the chicken low since I wanted the ribs done low, so the chicken just went along for the ride. I hadn't said it, but I did spatchcock the chicken too, first time trying that and surprisingly easy to do.
    greeneggsnspam and scottalot like this.
  2. May 12, 2017 at 6:00 AM
    #9022
    Chrisf06
    Chrisf06 Well-Known Member
    Bogart, Georgia
    2014 MGM Tacoma DC TRD Off Road
    Ah gotcha... Yeah i have always found with low and slow chicken, just give up on the skin, it'll be rubber.
    scottalot likes this.
  3. May 12, 2017 at 6:27 AM
    #9023
    Cold Iron
    Cold Iron Well-Known Member
    Mn.
    2013 AC T|X Baja
    What is this salad of which you speak? It looks like what food eats, didn't work this hard to get to the top of the food chain to eat what food eats. :D I do eat a fair amount of salad. As long as it has meat in it.
    My .02 cents on chicken and poultry, I do a fair amount of it. And wild game birds.
    The skin is key to keeping it moist. I breast or skin out my wild birds (ruff grouse and pheasants) which usually makes them poor candidates for smoking or grilling. Have plucked phez and smoked but they are lean so even then not the best candidate. Hence the cooking method of pheasant under glass, the glass is to keep them from drying out. But if the birds aren't too shot up I will pick pellets out with a toothpick and use a light coating of homemade shore lunch and fry in bacon grease on low heat in a cast iron skillet. Because all great recipes start with first you cook a pound of bacon. The batter helps act as an "artificial" skin to help keep the meat moist.
    But will do boneless skinless chicken thighs on the gas grill a couple times a month. Those I marinate overnight in a ziplock with Italian Dressing. And keep the burners down as low as possible. Can't probe them but when the thinner pieces start to dry out your usually done. Can do them on charcoal but that can be tricky without even heat, and also very low heat.
    Whole birds with skin intact always work best. For chicken I salt them at least an hour ahead of time just like a good steak, I just do the outside if you do it advance no need to do under the skin. It helps keep the skin crispy and juices flowing on the inside of the bird. The chickens here are Iowa corn fed birds and the size of a small pterodactyl. And contain a lot of fat internally. Cooking longer helps render the fat out into the meat so usually try to keep the temps down ~275*. For chicken splatchcocking seems to do well as does rotisserie, but can get 2 birds on the spit so if looking for leftovers will often do that. Doesn't seem to be a lot of difference between splatchcocking chickens and rotisserie, both are really good. I do the standard 165 in breast and 180 thighs and they are never dry with salting the skin in advance. 165* is the minimum safe temp for poultry.
    Splatchcocking chicken is one of the few times I use the slow n sear although the charcoal baskets do just as well. Paid $100 bucks for the som of a bitch so going to use it!
    As the skin dries you can see bubbles of fat run up the breast between the thighs to the top of the breast and then drip back down and start over again. Damn that almost sounds sexual in nature... Splatchcocking a chicken for supper tonight and will be doing it this way.
    Turkey I wet brine overnight in an old Igloo cooler with ice. Between smoking, splatchcocking and rotisserie the rotisserie seems to be a clear winner on the turkeys. Not sure why, but those that have eaten mine cooked the different ways all seem to agree too. They all seem to take 6-8 hours depending on time of year, etc.
    The Weber Genesis gas grill does an acceptable job although lacks the complex flavors of charcoal obviously. The drip pan with veggies stays cleaner and cooks better on the gas grill. Still need to parboil the potatoes no matter how you do it however. Grilled veggies basted in turkey fat are always a good thing.
    But turkey on the kettle rotisserie seems to be the consistent winner.
    Again just my 2 cents and worth what you paid for it.
  4. May 12, 2017 at 6:30 AM
    #9024
    Kanyon71
    Kanyon71 Well-Known Member
    MI
    I've never been able to stomach spam. Looks and smells like someone already ate it lol. Odd because I LOVE corned beef hash and it looks and smells like something someone already fed to the cat as my wife tells me.
    scottalot and la0d0g[QUOTED] like this.
  5. May 12, 2017 at 6:35 AM
    #9025
    Cold Iron
    Mn.
    2013 AC T|X Baja
    I like spam never smoked it may have to try it. They make Spam near here and Hormel even has a Spam museum in Austin, Mn. near where I shoot skeet.
    Can't find any scrapple in these parts though. I think I know why all the best parts of the hog go into Spam instead of scrapple around here.
    scottalot and la0d0g like this.
  6. May 12, 2017 at 6:47 AM
    #9026
    la0d0g
    running for the hills
    For crawling not hauling
    There are some somewhere in this thread :spy:
    Mmm, love me some corned beef hash too :hungry:
    Spam museum?!?! That's awesome!
    Living on the west side of the country there is no way I'm finding scrapple here. I make my own every once in awhile.
  7. May 12, 2017 at 7:19 AM
    #9027
    Cold Iron
    Mn.
    2013 AC T|X Baja
    Homemade scrapple... So what time is breakfast?! :burnrubber:
    The best that I have found that is close to homemade and like I used to help my grandfather make back in the late 60's-70's is from Leona Meat Plant in Troy, Pa. They ship anywhere in the CONUS although shipping in coolers and freezer packs cost more than the pans of scrapple. Every year before hunting season I order a couple of loafs from them. How a person is supposed to follow the dog through the woods all day busting brush without a decent breakfast of scrapple and eggs is beyond my comprehension.
    Cooked in bacon grease. Of course.
  8. May 12, 2017 at 7:34 AM
    #9028
    DBTaco
    DBTaco Well-Known Member
    NC
    '08 4x4 TRD off road
    Those of you that have a side smoker box attachment or made on the grill, do you always put your coals, wood, etc. in the side box and cook by temperature or does it depend on what you are cooking? Using my gas grill, I cook chicken breast @ 350 degrees with two outside burners going and two inside burners off for indirect grilling. Grill for 15-20 minutes, put on plate and wrap in tin foil, let them sit for 10 minutes or so and they come out juicy and tender. Just trying to get my thoughts together for when I start cooking on charcoal.
  9. May 12, 2017 at 7:44 AM
    #9029
    Chrisf06
    Bogart, Georgia
    There are a lot of things i grill direct, usually on raised grid. Boneless chicken breasts, pork tenderloins, really most lean things i go higher heat, raised direct, and just hit with some smoke at the beginning. If i want some more smoke, sometimes i will go indirect until 10-20 degrees from finish temp, and then hit them direct for a few min just to get a char/crisp. Thats what I do with chicken thighs and usually with wings (if i sauce them, throw them back on direct for 1 min per side).
    Cold Iron, scottalot and Kanyon71 like this.
  10. May 12, 2017 at 8:44 AM
    #9030
    la0d0g
    Oh man, I didn't know I could order scrapple from the source! Thanks for the info, might just order some today!
    scottalot and Cold Iron[QUOTED] like this.
  11. May 12, 2017 at 11:43 AM
    #9031
    la0d0g
    In 20 minutes I'll be eating my brisket sandwich. This will be the fifth day in a row and the last. I'm not complaining but also happy I portioned up the remaining and vacuum sealed it :D
  12. May 12, 2017 at 12:43 PM
    #9032
    hemitruk
    hemitruk Old man , young boi truk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    I do spatchcock turkey at 325 to 350 . 12lb turkey cooks in about 1.5 to 2 hours . Surprisingly moist . Heard because of fast cooking doesn't dry out .Worked for me. Skin not crispy but soft and edible (my favorite part lol)
    In Hawaii spam is " Da Steak of Hawaii lol " There is a a Spam Jam blocks (lol) party on Kalakaua Ave. in Waikiki every year
  13. May 12, 2017 at 2:12 PM
    #9033
    WBF610
    WBF610 Member well known
    Carey
    Eastern PA
    2016 DC OR
    mats, flaps, and stickers. Extang solid fold 2.0. Mobtown sliders and full skids. AVS vents
    I've been trying to drink my allergies away. It isn't working.
  14. May 12, 2017 at 2:15 PM
    #9034
    horstuff
    horstuff Re-member
    PNW
    2015 Base 2.7 Access Cab 4x4 5 sp
    Snort the beer :D
    Cold Iron and WBF610[QUOTED] like this.
  15. May 12, 2017 at 4:03 PM
    #9035
    FFBlack
    FFBlack Well-Known Member
    2019 TRD OFF ROAD
    Birthday Dinner! 4 hours on the WSM!
    Kanyon71, wilcam47, la0d0g and 5 others like this.
  16. May 12, 2017 at 4:10 PM
    #9036
    horstuff
    horstuff Re-member
    PNW
    Niiice
  17. May 12, 2017 at 5:00 PM
    #9037
    Misplaced Nebraskan
    Misplaced Nebraskan TTC #007 'First Gen Best Gen'
    Zach
    Austin
    2001 Taco & 16 T4R TPE
    :drool::drool::drool::drool:
    That's some amazing color on them. Well done :cheers::bowdown:
    scottalot and FFBlack[QUOTED] like this.
  18. May 12, 2017 at 5:13 PM
    #9038
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    2012 Spruce Mica TRD Sport
    Tinted windows 5%, sill protectors, TRD stubby antenna, weathertech in channel rain guards, wheathertech floor mats, BHLM, Truxedo low pro qt, DTRL deleted, anytime backup camera, bed storage locks, fog lights on anytime, tailgate theft deterrent, painted engine cover, relocated horns, l.e.d bed lights, l.e.d engine bay lights, l.e.d lights above cup holders, in glove box, rear cup holder, in console storage & cubby next to steering wheel, Grillcraft grill, 17x8.5 SCS Ray10's, 35x12.50 Nitto Ridge Grapplers, Borla cat back exhaust, map & dome l.e.d's, TEQ badge on grill, Redline tuning hood struts, Maxtrac spindles, SPC Light Racing UCA's, Bilstein 5100's front set at 0 with OME 885's & extended length Bilstein 5100's in the rear, All Pro expedition leaf springs & 2" blocks, extended brake lines front & rear, 1.5" 4crawler drive shaft spacer, Beefed Taco carrier bearing drop, 1.25" spidertrax wheel spacers on rear, Kenwood DNX570 touchscreen with navigation, 30" led light bar in lower bumper opening, 1/4" top plate spacer drivers side, Bullet Proof Fabricating skid plate, Cali Raised ditch lights & Rago f Fabrication brackets, Amp Research power steps, smoked l.e.d 3rd brake light, Wet Okole seat covers, under cab LED'S tied to dome circuit
    Sunday I'm gonna attempt to smoke bacon wrapped scallops, lobster tails & ribeye steaks for mothers day, wifey's request.
    Kanyon71, la0d0g, scottalot and 3 others like this.
  19. May 12, 2017 at 5:39 PM
    #9039
    horstuff
    horstuff Re-member
    PNW
    Hoo boy, will need a report on those scallops please.
    scottalot and WBF610 like this.
  20. May 12, 2017 at 5:48 PM
    #9040
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    Will do, along with pics. Haha
