Food Smokers and Smoking Tips/Tricks/Techniques
Discussion in 'Food Talk' started by Polymerhead, Jul 15, 2012.
  1. May 19, 2017 at 9:14 AM
    #9201
    Kanyon71
    Kanyon71 Well-Known Member
    MI
    Very nice looking and sound really good.
    scottalot likes this.
  2. May 19, 2017 at 9:20 AM
    #9202
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
  3. May 19, 2017 at 9:23 AM
    #9203
    bvbull200
    bvbull200 Well-Known Member
    Bryan
    DFW, Texas
    2013 DCSB SR5 Prerunner Texas Edition
    Fresh wiper fluid
    We make our own rub that we use primarily on pork ribs and pork shoulder, but it is also good on chicken (it is a "sweeter" rub). Hopefully in 2018, we'll be registered as a business, get production costs down and quantities up, then start "officially" selling it. Right now, we use most of what we make, but sell to folks that request it in a private-transaction-no-implied-guarantee sort of way ;).
    It has 14 ingredients in it, but sugars, salts, garlic, thyme, paprika, serrano salt, onion powder, etc. Smoked varieties of some of the ingredients.
  4. May 19, 2017 at 9:24 AM
    #9204
    horstuff
    horstuff Re-member
    PNW
    2015 Base 2.7 Access Cab 4x4 5 sp
    Do you mind sharing the basics of your brisket cook? Temp, wood, how long, fat cap trim / up or down?
  5. May 19, 2017 at 9:27 AM
    #9205
    wilcam47
    Will
    Bourbon state
    I found your recipe ;)
    Cold Iron, FFBlack, scottalot and 2 others like this.
  6. May 19, 2017 at 9:27 AM
    #9206
    bvbull200
    Bryan
    DFW, Texas
    Fresh wiper fluid
    No problem. Hopping in to a meeting here shortly, but will post my method when I get a few free moments. I, as well as the rest of our team, are open books when it comes to BBQ. Happy to share all successes and, um, "lessons learned" :D.
    truchador, scottalot and grdgz97 like this.
  7. May 19, 2017 at 9:29 AM
    #9207
    bvbull200
    Bryan
    DFW, Texas
    Fresh wiper fluid
    :rofl:
  8. May 19, 2017 at 9:45 AM
    #9208
    la0d0g
    running for the hills
    For crawling not hauling
    I want some meat now!
    Cold Iron, bvbull200 and scottalot like this.
  9. May 19, 2017 at 10:01 AM
    #9209
    itzyoboipaul
    itzyoboipaul Well-Known Member
    Paul
    PFville, TX
    2020 TRD OR Cement
    that was not mine. it was from google :)
    but yes ive had them spam sushi...delish!!!
    hemitruk[QUOTED] and scottalot like this.
  10. May 19, 2017 at 11:12 AM
    #9210
    hemitruk
    hemitruk Old man , young boi truk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    Instead of spam try putting smoked brisket . :thumbsup: In Hawaii rice is the starch of choice .
    wilcam47, Cold Iron and scottalot like this.
  11. May 19, 2017 at 11:14 AM
    #9211
    la0d0g
    How about both! :mindblown:
  12. May 19, 2017 at 11:16 AM
    #9212
    bvbull200
    Bryan
    DFW, Texas
    Fresh wiper fluid
    Not to get all cliche, but I don't "exactly" know the timing because it is now down to look/feel from cooking so many of them. The ranges provided are good approximations, though.
    Full packer brisket. Trim the fat cap down to roughly 1/4". If you don't feel like doing that, scoring it works in a pinch. Remove most/all of the big chunks of fat separating the flat from the point as well. Lastly, find the direction of the grain and cut a little corner off of the end of the flat that goes against the grain. This will give you a line for slicing when it is time to serve without having to search for the grain.
    Usually, I prefer to apply the rub only about an hour or so before it goes on. I have an unsubstantiated hunch behind this**. Salt & pepper briskets are awesome, for sure, but if you want to try an easy rub recipe that imparts a little extra flavor, try this:
    One "good" layer of Adkins Western BBQ Seasoning
    On top of that, one lighter layer of Adkins Chicken & Pork rub
    I know what you're thinking, "Chicken & pork rub?!?!". The Adkins stuff actually isn't all that sweet and is quite savory, so it actually works really well. You should be able to find these locally somewhere, otherwise just order off of Amazon. Even if you don't use them on brisket, they're good, so you'll find a use for them.
    If I want a bigger window for pulling the briskets, I'll get the smoker in the 250-275* range. I can get similar results cooking at 300-325*, but the margin of error is smaller. Favorite wood choice is 50% pecan, 25% cherry, 25% mesquite or thereabouts. If no cherry, just add that percentage to the pecan. Mesquite is stronger, so if you want a heavier smoke flavor, adjust accordingly.
    Smoked with the fat cap down, unwrapped for 6-8 hours or so. I'm looking for when the meat has a really deep mahogany color. The internal temp is often in the 160-180* range. Once the color is good, I reach for the Texas crutch***. I wrap it in foil with the seams tight, but the foil almost tented, so as not to sit tight against the brisket. How long it takes from there is pretty variable, but it rarely takes longer than 90 minutes. After a bit, I'll start checking for tenderness at the thickest part of the flat. This is usually up where the flat overlaps the point. Stick a probe or skewer in and it should go in about like going through warm peanut butter. A wee bit of resistance, but pretty damn easy. If you want to practice by using a temp as your guide instead, wait until this part hits 200*, but learn the feeling as it is a more accurate indicator.
    Pull the brisket and vent it with the foil opened for about 5-10 minutes. Once vented, seal it back up and put it up to rest. I use a Cambro, but a good cooler with a few towels over the brisket will work nicely, just don't open the cooler. I try to time my cooks so that the brisket can rest for a minimum of two hours. Three is even better, though.
    Pull it out of the foil and cut slices of brisket about the thickness of a pencil and enjoy!
    Hope that helps!
    **The smoke ring is a purely aesthetic thing, but it does look sexy. It can be helped along by keeping the surface of the meat moist as the moisture "grabs" the smoke, which contains the particles that set the pink ring. Putting the rub on closer to when it goes on the smoker means that it is pulling moisture to the surface during the first part of the cook. In my head, at least, this is helping the smoke ring come along. I have noticed no real discernible change in flavor by rubbing the night before and letting the rub "penetrate" the meat.
    *** The Texas crutch does sacrifice the bark to an extent. It will not be as firm as an unwrapped brisket. The upside, in my opinion, is a more moist brisket.
  13. May 19, 2017 at 11:17 AM
    #9213
    hemitruk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    Don't think I would like that combo together . Separate oh yea....lol
  14. May 19, 2017 at 11:29 AM
    #9214
    bvbull200
    Bryan
    DFW, Texas
    Fresh wiper fluid
    In keeping with full disclosure, here is the ingredients list for our rub ;)
    Brown Sugar
    Salt
    Turbinado Sugar
    Chili Powder
    Serrano Smoked Salt
    Garlic
    White Pepper
    Celery Powder
    Thyme
    Cayenne Pepper
    6 Pepper Blend
    Habanero Seasoning
    Onion Powder
    Smoked Paprika
  15. May 19, 2017 at 12:05 PM
    #9215
    horstuff
    horstuff Re-member
    PNW
    Lawdy, I couldn't have asked for better. Bravo and thank you kind sir.
    bvbull200[QUOTED] likes this.
  16. May 19, 2017 at 12:34 PM
    #9216
    bvbull200
    Bryan
    DFW, Texas
    Fresh wiper fluid
    My pleasure!
    You just have to post pictures of brisket if you try it out ;).
  17. May 19, 2017 at 12:40 PM
    #9217
    horstuff
    horstuff Re-member
    PNW
    Will definitely do. Thanks again.
  18. May 19, 2017 at 5:07 PM
    #9218
    itzyoboipaul
    Paul
    PFville, TX
    2020 TRD OR Cement
    For all you Stubbs fan. One day sale at Lowes.
    One day only. Today only. Ordered mine online for pick up tomorrow.
    I just grabbed 7 of these
  19. May 19, 2017 at 5:35 PM
    #9219
    horstuff
    horstuff Re-member
    PNW
    YEAH!! Thanks! Gonna order a bunch online and pickup this weekend. Thanks again!
    itzyoboipaul[QUOTED] likes this.
  20. May 19, 2017 at 6:12 PM
    #9220
    horstuff
    horstuff Re-member
    PNW
    You da man! I just bought 6 online, they're ready to pickup at local Lowes. Might get a few more, shoulda got 8.
