Food Smokers and Smoking Tips/Tricks/Techniques
Discussion in 'Food Talk' started by Polymerhead, Jul 15, 2012.
  1. May 26, 2017 at 8:08 AM
    #9461
    DBTaco
    DBTaco Well-Known Member
    NC
    '08 4x4 TRD off road
    I'm not sure which route I want to go. As some of you know I've been looking at the Char-griller barrel grill from Lowes(I know its not the best from what I've heard on here) but I would like to get the side smoker box to go along with it. I know everyone is a big Weber fan, but I'm not sure if I want to go with a kettle type. I know they have to be great grills, I'm just not sure about cooking on it with ribs, butts, etc big pieces of meat along with using coals and adding wood.
    scottalot likes this.
  2. May 26, 2017 at 8:29 AM
    #9462
    horstuff
    horstuff Re-member
    PNW
    2015 Base 2.7 Access Cab 4x4 5 sp
    For a bit more money why not get the Oklahoma Joes from Lowes? Side box already on it. Problem with the inexpensive smokers is lots of air gaps, hard to maintain temps. With the Ok Joe the side box is built with it, probably better air control. Plus it's one of the highest rated at its price point.
    WBF610 and scottalot like this.
  3. May 26, 2017 at 8:45 AM
    #9463
    DBTaco
    NC
    Thanks I'm going to check those out
  4. May 26, 2017 at 8:49 AM
    #9464
    DBTaco
    NC
  5. May 26, 2017 at 9:06 AM
    #9465
    la0d0g
    running for the hills
    For crawling not hauling
    Cold Iron, scottalot and grdgz97 like this.
  6. May 26, 2017 at 9:23 AM
    #9466
    bvbull200
    bvbull200 Well-Known Member
    Bryan
    DFW, Texas
    2013 DCSB SR5 Prerunner Texas Edition
    Fresh wiper fluid
    I would give the Oklahoma Joe Bandera a serious look:
    https://www.lowes.com/pd/Oklahoma-J...2-0-sq-in-Charcoal-Vertical-Smoker/1000086127
    There is a bit of a cult following for the older New Braunfel's version of these smokers that used to use thicker steel and were generally more well constructed, but when I saw these on the floor of my local Lowes, I was astonished. It is a GREAT design. My first smoker was a Bandera that I restored. I made a charcoal basket for it, added a baffle on the cooking chamber, put inlets for a wireless thermometer, and added a drain plug to it. We touched up a few gaps, then added new casters. I only switched because we started building our own UDS smokers. For an offset, it was fantastic. I'll see if I can scare up a couple of pics of mine from back in the day.
    scottalot and Jeppa63 like this.
  7. May 26, 2017 at 9:24 AM
    #9467
    grdgz97
    grdgz97 Well-Known Member
    Georgetown, TX
    2015 TRD Sport DCSB
    Getting paid to Q?!? Winning!:bananadance::bananadead:
    scottalot and la0d0g like this.
  8. May 26, 2017 at 9:47 AM
    #9468
    bvbull200
    Bryan
    DFW, Texas
    Fresh wiper fluid
    Here is the Bandera I had after I restored it. The new ones come with the baffle already installed. I can't tell if they have a fire basket included or not. I forgot to look when I was in the store.
    First brisket I ever cooked was on that Bandera. It was a bit dry, but that smoke ring... I was hooked on BBQ from that point on.
  9. May 26, 2017 at 10:44 AM
    #9469
    horstuff
    horstuff Re-member
    PNW
    Doesn't look *too* dry. Great ring!
  10. May 26, 2017 at 11:02 AM
    #9470
    truchador
    truchador Well-Known Member
    Otto
    WV
    15 DC OR
    weathertech, seat covers, scratches
    I have mine on a piece of cement backer board. Works fine with briquettes but lump scares me what with the popping and the sparks
  11. May 26, 2017 at 11:23 AM
    #9471
    Cold Iron
    Cold Iron Well-Known Member
    Mn.
    2013 AC T|X Baja
    Yep been doing it for 15 years in this house, since the first week I moved in. And have thought of using a cement backer board but IMO for it to really work should have an air space under it. And the edges of the board will get chewed up with a snow shovel half the year here if not protect somehow. Going to finally break down and build a lipped base out of IPE wood for both the smoker and kettle. And only use briquettes, I agree with truchador. For the way I cook don't see an advantage of lump anyhow. When I rebuild the deck will do it with IPE wood, it has a Class A fire rating and burns about as well as cement does. But I also am a firm believer in never leaving a burning fire unattended.
    For now... The WSM has an ATC connected to it so all lower vents are closed with the exception of the air inlet connection piece which is also closed due to the air hose connected. So nothing can fall out of the bottom.
    I clean the ash catcher on the kettle clean before each cook. And watch it like a hawk. IME the real danger comes from the chimney starter I have had hot coals fall out it that get stuck in the bottom. So always double check it after dumping it into the kettle.
    Not saying it is a good idea to cook on a wooden deck. I also have a garden hose run up the side of my house to the deck for watering flowers, cleaning, and just in case. And a Class A, B and C fire extinguisher sitting by the door. I just replaced that a few months ago they do have a shelf life.
    ^^:thumbsup:
    scottalot and truchador[QUOTED] like this.
  12. May 26, 2017 at 12:49 PM
    #9472
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    My local home depot had the Kingsford charcoal sale, but listed the limit as 5. I didn't care as I can only find room for 3, but thought I'd let you know.
  13. May 26, 2017 at 1:08 PM
    #9473
    Kanyon71
    Kanyon71 Well-Known Member
    MI
    Those look mighty tasty. I did a breakfast sammich the other day with leftover breakfast fatty I did last weekend. Hit the spot. I had hoped to have more leftovers but everyone tore them up.
    scottalot and bvbull200[QUOTED] like this.
  14. May 26, 2017 at 1:19 PM
    #9474
    bvbull200
    Bryan
    DFW, Texas
    Fresh wiper fluid
    It was good enough at the time, but 6 years and hundreds of briskets later, they've come a long way for me.
    Funny how that always seems to happen with a good fatty, eh?
    :thumbsup:
    Kanyon71[QUOTED] and scottalot like this.
  15. May 26, 2017 at 3:28 PM
    #9475
    EricL
    EricL Tomahawk Chopper
    Greenwood, SC
    2015 Slowmobile
    SOS Offroad Concepts Armor
    First beef smoke. Did Italian sausages earlier in the day that were really yummy, but this beef chuck roast just melts in your mouth.
    Still have chicken, STL ribs, and beef brisket to smoke before this long weekend is done.
    Kanyon71, la0d0g, scottalot and 5 others like this.
  16. May 26, 2017 at 4:06 PM
    #9476
    WBF610
    WBF610 Member well known
    Carey
    Eastern PA
    2016 DC OR
    mats, flaps, and stickers. Extang solid fold 2.0. Mobtown sliders and full skids. AVS vents
    I have the ok Joe's 3 in 1. I used high temp caulk to fill the gaps, used stove rope around the doors, and put a 3" vent pipe in to grate level. I can control the temp just fine now.
    Get it. I wish I had that much space on mine. Get a tube of high temp caulk and some stove rope to fill the gaps on the doors. It should run well with those mods.
  17. May 26, 2017 at 4:16 PM
    #9477
    itzyoboipaul
    itzyoboipaul Well-Known Member
    Paul
    PFville, TX
    2020 TRD OR Cement
    Y'all got your lowes/Home Depot kingsford charcoal sale right ?
  18. May 26, 2017 at 4:21 PM
    #9478
    EricL
    Greenwood, SC
    2015 Slowmobile
    :eek:
    :drool:
    :hungry:
    :cheers:
  19. May 26, 2017 at 4:40 PM
    #9479
    EricL
    Greenwood, SC
    2015 Slowmobile
    Nothing wrong with that, at all! :drool: :hungry:
    Got 6 lbs of chuck to form up into burgers this weekend. Picked up some small cheese cake frames to form the meat up in, hold in the spices, etc. Got the idea from a Youtube video that I can't find now... :(
  20. May 26, 2017 at 4:46 PM
    #9480
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    2012 Spruce Mica TRD Sport
    Tinted windows 5%, sill protectors, TRD stubby antenna, weathertech in channel rain guards, wheathertech floor mats, BHLM, Truxedo low pro qt, DTRL deleted, anytime backup camera, bed storage locks, fog lights on anytime, tailgate theft deterrent, painted engine cover, relocated horns, l.e.d bed lights, l.e.d engine bay lights, l.e.d lights above cup holders, in glove box, rear cup holder, in console storage & cubby next to steering wheel, Grillcraft grill, 17x8.5 SCS Ray10's, 35x12.50 Nitto Ridge Grapplers, Borla cat back exhaust, map & dome l.e.d's, TEQ badge on grill, Redline tuning hood struts, Maxtrac spindles, SPC Light Racing UCA's, Bilstein 5100's front set at 0 with OME 885's & extended length Bilstein 5100's in the rear, All Pro expedition leaf springs & 2" blocks, extended brake lines front & rear, 1.5" 4crawler drive shaft spacer, Beefed Taco carrier bearing drop, 1.25" spidertrax wheel spacers on rear, Kenwood DNX570 touchscreen with navigation, 30" led light bar in lower bumper opening, 1/4" top plate spacer drivers side, Bullet Proof Fabricating skid plate, Cali Raised ditch lights & Rago f Fabrication brackets, Amp Research power steps, smoked l.e.d 3rd brake light, Wet Okole seat covers, under cab LED'S tied to dome circuit
    This is the Char-Griller I have, other than some leaks as stated before that can be easily fixed I have no complaints. I bought it at Home Depot. I believe it's got a little more cooking surface that the OK Joe's.
    http://www.homedepot.com/p/Char-Gri...arcoal-or-Wood-Smoker-in-Black-8125/206282469
    scottalot, EricL and truchador like this.
