Food Smokers and Smoking Tips/Tricks/Techniques
Discussion in 'Food Talk' started by Polymerhead, Jul 15, 2012.
  1. Jun 12, 2017 at 7:26 AM
    #9961
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    OK, so my terms were close, or close enough to figure out.
    As for the slicing, yes sir, think I have that down now. First one,,, I butchered that bitch bad. Wrong direction, wrong knife, was closer to pulled brisket, than sliced. Case of thinking you know what you are doing, and don't. This one worked out much better. Sliced the tip side of the flat, when it starts to transition with the point, turn it 90 degrees or so and finish the slicing. So :thumbsup:
    And for the dry part, already did add some sauce to it, still good.
    So far the mistakes are still like sex, even the bad parts are still good.
  2. Jun 12, 2017 at 7:27 AM
    #9962
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Too poor to list anything interesting.
    Summary of the smoking thread right here, ladies and gentlemen.
    Kremtok, Hobbs, CurtB and 5 others like this.
  3. Jun 12, 2017 at 7:33 AM
    #9963
    bvbull200
    bvbull200 Well-Known Member
    Bryan
    DFW, Texas
    2013 DCSB SR5 Prerunner Texas Edition
    Fresh wiper fluid
    A couple of questions, if I may, to help troubleshoot your brisket.
    Was it dry and tough or dry and kind of crumbly? Did you rest the brisket at all?
    Keep at it. Briskets are tricky. Of course, at $1.96/pound you can afford to practice a lot :laugh:
    Kanyon71 and greeneggsnspam like this.
  4. Jun 12, 2017 at 7:37 AM
    #9964
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Wasn't tough, just the tip end of the flat, about 1/4 or so, was dry, once it got close to the point, it got much better. Yes, it was rested for a few hours actually. Due to scheduling, I took it off about 2am, and it sat for a few hours until I cut it up in the morning. I did not wrap it in anything though.
    bvbull200[QUOTED] and scottalot like this.
  5. Jun 12, 2017 at 8:41 AM
    #9965
    drwx
    drwx Well-Known Member
    M'boro, TN
    2017 DCSB TRD Offroad 4x4 BBP
    not just northern friends........... it's not cheap in the southeast either. brisket is always $7+ per pound in TN.
    scottalot likes this.
  6. Jun 12, 2017 at 9:09 AM
    #9966
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    damn I can get USDA prime whole packer for $2.99/lbs at costco in LA
  7. Jun 12, 2017 at 9:11 AM
    #9967
    rhion82
    rhion82 El Duderino
    Mitchell
    TN/GA
    16 Taco
    Where are you finding $7/lb Brisket?? Don't think I've seen it that high in TN.
    scottalot and greeneggsnspam like this.
  8. Jun 12, 2017 at 9:38 AM
    #9968
    Kanyon71
    Kanyon71 Well-Known Member
    MI
    I got to do NO smoking this weekend. Left the house early both days and didn't end up home till LATE both days. This coming weekend though I will be taking this new rub for a good test run.
    greeneggsnspam and scottalot like this.
  9. Jun 12, 2017 at 9:43 AM
    #9969
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    The salt and pepper smoke is the Texas flavor Ive been looking for! The brisket I made lasted about 15 minutes...even the scraps were gone! I got one little piece and the rest everyone destroyed!
  10. Jun 12, 2017 at 9:43 AM
    #9970
    bvbull200
    Bryan
    DFW, Texas
    Fresh wiper fluid
    I find that first bit of the flat on the dry side every time anyways. I usually cut in a little ways and start making slices from there. The bit I cut off I mix in with point meat for chopped.
    Lurkin[QUOTED] and scottalot like this.
  11. Jun 12, 2017 at 9:54 AM
    #9971
    Kanyon71
    MI
    I'm tellin ya man, sometimes it's all about that nicely accented beef taste. Good rub is a good rub but sometimes I want the beef flavor to shine through.
    wilcam47[QUOTED] and scottalot like this.
  12. Jun 12, 2017 at 10:06 AM
    #9972
    horstuff
    horstuff Re-member
    PNW
    2015 Base 2.7 Access Cab 4x4 5 sp
    When I get @bvbull200 's rub I'll be using it on pork and chicken and tri-tip, and will try it on other beef, but for brisket, I'm pretty much hooked on just kosher salt and fresh ground black pepper. Hey, idea... I'll do a brisket half and half, no harm there, maybe the rub will make me less insistent on just s&p. With brisket, once you figure out what you like it's pretty much pulling teeth to change, because it's so damn finicky to learn and expensive.
  13. Jun 12, 2017 at 10:24 AM
    #9973
    drwx
    M'boro, TN
    publix and kroger around nashville. it has to be on sale for it to be under $5/lb.
    granted, i never look for brisket, but every time i DO look for it, it's ridiculously expensive.
  14. Jun 12, 2017 at 10:29 AM
    #9974
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Just starting, but have yet to use any rub on anything. Posted before, but I want to get the flavor by itself first before I start adding stuff trying to find out what I like better, or worse.
    NBS FTW - Nuthin' But Smoke, for now anyway
    Scott, just to be clear, that's nuthin' but smoke,,, not nuttin butt smoke. :eek::eek:
  15. Jun 12, 2017 at 10:34 AM
    #9975
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    A good rub on some ribs...
  16. Jun 12, 2017 at 10:40 AM
    #9976
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Sorry, thought you were already out. :rofl::rofl:
    Kanyon71 and scottalot[QUOTED] like this.
  17. Jun 12, 2017 at 10:41 AM
    #9977
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Next round I am going to start adding some rub, and see what I think.
  18. Jun 12, 2017 at 10:50 AM
    #9978
    grdgz97
    grdgz97 Well-Known Member
    Georgetown, TX
    2015 TRD Sport DCSB
    :rofl:
    scottalot[QUOTED] likes this.
  19. Jun 12, 2017 at 10:53 AM
    #9979
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
  20. Jun 12, 2017 at 12:09 PM
    #9980
    Kanyon71
    MI
    I've yet to have a brisket I didn't like. I've had a few I think could have been a LOT better but they still were better than eating tofu. :)
    grdgz97, Cold Iron and scottalot like this.
