Food Smokers and Smoking Tips/Tricks/Techniques
Discussion in 'Food Talk' started by Polymerhead, Jul 15, 2012.
  1. Feb 23, 2014 at 6:51 PM
    #1041
    toughtaco
    toughtaco Well-Known Member
    05 tacoma dbl cab short bed
    TRD CAI, MBRP dual exhaust, PIAA headlights and driving lights, 5% limo tint, 3 inch Skyjacker lift , AFE throttle body spacer, 285/70/17 BF Goodright AT TA KO, Grillcraft MX with PIAA's behind the grill, anytime fog light mod, reverse camera anytime mod, and PIAA fog lights on the rear bumper anytime mod light bar behind back window with truck lights for reverse assistance, Optima Red Top Battery, Onza 3x5" LEd reverse lights attached to light bar behind cab
    Got it thanks....
  2. Mar 4, 2014 at 2:51 PM
    #1042
    eastcoastcowboy
    eastcoastcowboy just sittin' in the corner, havin' a beer
    Brian
    Redneckville, NB
    '15 Skewped!!
    Weathertecs, 265/70/17 Duratracs, Trifecta Tonneau
    Horizontal offset build about to begin. Picked this up today.
    Price was as good as it gets :D
    Should be a nice upgrade from the UDS.
  3. Mar 4, 2014 at 4:06 PM
    #1043
    Polymerhead
    Polymerhead [OP] Well-Known Member
    Missouri
    '18 TRD Limited Inferno...Tundra!
    Definitely, definitely keep us posted!
  4. Mar 4, 2014 at 5:12 PM
    #1044
    eastcoastcowboy
    Brian
    Redneckville, NB
    '15 Skewped!!
    Will do. Already made mistake #1. Should have checked the weight chart before I pulled a 500 lb piece of pipe off the truck by myself....lol.
    Any ideas for preferred design. Standard flow, reverse flow, tuning plates, etc.
    Although I've been creeping some of the 'Q forums, I've never cooked on an offset, so any input would be helpful.
  5. Mar 4, 2014 at 5:45 PM
    #1045
    Polymerhead
    Missouri
    Nor have I. I've spent some time looking at plans and cooking on big custom vertical chest-type smokers but I have zero experience on offset setups.
  6. Mar 5, 2014 at 2:46 PM
    #1046
    Primo 95
    Primo 95 Well-Known Member
    Primo!
    San Antonio, TX
    2012 DCSB 4X4
    265/75/16 S/T Maxx 16X8.5 Level 8 Trackers 5100 1.75 HID, LED interior, 3" N-Fab step bars
    Here in Texas - offset is the way to go.
    It is the preferred way for multiple reasons. #1 being fire management. The other being the separation of grease and ash. When you combine these 2, you get Lime and I have read this will rot the metal. A typical brisket will make about a quart of grease/lard.
    Your cooking side should have a drain for the grease. And the ash is kept separate in your offset. Offset also keeps ash off your meat. My offset side is also designed to be used as a direct BBQ grill for steaks/burgers.
    I have a smaller Lyfe Tyme Pit
    Here are some pics of their models to give you some ideas.
    https://www.google.com/search?q=lyf...wXtzoC4Aw&sqi=2&ved=0CEIQsAQ&biw=1360&bih=640
    Gator Pits:
    http://www.gatorpit.net/budgetbbqpits/budget.htm
    Klose:
    http://www.bbqpits.com/
  7. Mar 12, 2014 at 5:50 PM
    #1047
    TEX82Trooper
    TEX82Trooper Outdoor Adventurer
    Las Cruces,NM
    '06 Tacoma TRD Sport camping & hunting rig.
    mild lift (3 inch?) of unknown origin (truck was bought used),much more to come.Self-fabbed rock-rails.
    I haven't been cooking lately, but did finish building this for a good friend in Midland,TX.
    [​IMG] [​IMG]
    [​IMG][​IMG]
  8. Mar 13, 2014 at 5:05 AM
    #1048
    Lastplace
    Lastplace Well-Known Member
    Southeast VA
    Wow, you made that from scratch?
  9. Mar 13, 2014 at 5:20 AM
    #1049
    trufunk
    trufunk Well-Known Member
    Very nice!
  10. Mar 13, 2014 at 7:32 AM
    #1050
    TEX82Trooper
    Las Cruces,NM
    Yes, all scratch built, smoke chamber was a liquid propane tank, everything else I fabbed. Thanks for the complements, Since I lost my job I have been doing whatever I can to get money in the bank.
  11. Mar 13, 2014 at 7:36 AM
    #1051
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    That's awesome! :thumbsup:
  12. Mar 13, 2014 at 7:39 AM
    #1052
    magnetic11
    magnetic11 Well-Known Member
    "some nuke plant"
    11 trd sport
    Fab fours front and rear bumpers, B.A.M.F. weld on rock sliders, softopper, removed mud flaps and D-Badged everything. Icon 2.5 Extended Travel coil-overs, Total Chaos upppers, 2.0 Icon extended travel shocks with the resi's and Dekar Leaf packs.
  13. Mar 14, 2014 at 1:05 PM
    #1053
    Primo 95
    Primo!
    San Antonio, TX
    2012 DCSB 4X4
    I thought I would share this with everyone...it has become the a joke among my fellow local smokers: The infamous Left Sided Brisket.
    It is part myth & part fact. Yes, there are left and right sided briskets. The theory/legend is...cows just like humans are right/left handed/hoofed...and just like your weaker side..the muscles aren't as strong/tight on that side...so you always want a left sided brisket..since it will most likely come from the weaker side of the cow and have a stronger probability of being more tender.
    It is actually good way to test your butcher at your grocery store to see if he really is trained and pays attention to his work.
    Anyway next time you order BBQ, don't only specify moist/lean - say you want it from the left side!
    I just found me a nice whole 8lb brisket..super tender..both tips easily touch...I plan on having it done for lunch on saturday..and this one is a righty!
  14. Mar 17, 2014 at 1:27 PM
    #1054
    478DblSport
    478DblSport Thermonuclear Protection
    Byron, GA
    07 Silver Streak Mica PreRunner DC TRD Sport
    | EXTERIOR | DiamondBack SE Tonneau Cover, Havoc HS2 Hoop Steps, Tailgate Hose Clamp Mod, Shortened OEM Antenna, DeeZee Bed Mat | INTERIOR | Flyzeye V2W (Amber/White/Amber), RAM Mt A-Pillar Mod, Audio: Pioneer AVH-X5700, PDX-5 (119Wx4+410W), Polk Audio MM6501 (F) & MM651 (R), JL Audio CP108LG-W3v3 (Sub), w/Monster, Rockford, & Streetwire cabling, Metra Dash Kit.
    Hey Primo 95, posted your left handed brisket theory/myth over on a grill forum I'm a member of and one member concurred of hearing this story... he posted a link to what he had heard. http://www.bbqsearch.com/search/101390.html
  15. Mar 22, 2014 at 12:37 PM
    #1055
    krap22
    krap22 Well-Known Member
    Beef sirloin tip going on in 20 min. Chicken thighs will go on after about 90 min. :hungry:
  16. Mar 22, 2014 at 4:34 PM
    #1056
    Polymerhead
    Missouri
    I'd like to find something to smoke tomorrow - not feeling a pork shoulder or brisket. Maybe a bunch of ribs - it's been a while since I tried them.
  17. Mar 22, 2014 at 4:49 PM
    #1057
    99TacoDriver
    99TacoDriver Well-Known Member
    South Louisiana
    OME 885x/5100s/LR UCA/3 leaf AAL/275/70/17 Terra Trac X-Venture
    :hungry:
    sub'd for future mouth watering goodness.
    my dad won a big green egg from Heineken a while back and we always smoke up some ribs on it ill post pics one day
  18. Mar 23, 2014 at 9:42 AM
    #1058
    Polymerhead
    Missouri
    Two racks of baby backs and two racks of spare ribs. Going to do a traditional 3-2-1 and see how it works.
    Sticky Pig dry rub, and plan to finish with Stubb's sweet & hot BBQ sauce. On the smoker at 11:30, should be ready by dinner! Just wish there was some Cardinal's baseball to watch today while I cook.
    1638D0B9-B88A-4725-B2CB-4C554E2C37D8_zps_2bb614f2133898b62ce5b1682c60a36d2e843a86.jpg
  19. Mar 23, 2014 at 5:13 PM
    #1059
    Polymerhead
    Missouri
    Great results - a lot of ribs for lunches this week!
    0E326FC5-97E4-4273-BBF8-AFAF40FD1C15_zps_27236c521b688809f1c604d4666305ffffaccc32.jpg
  20. Apr 15, 2014 at 6:39 AM
    #1060
    cdj1
    cdj1 Well-Known Member
    Clint
    Muuurville, TN
    97 Tacoma
    King Extended travel coilovers, 5100 Shocks, Daystar shackles,OME Leaf Springs,255/85/16, front diff drop, RAT skid plates, 4.56 gears, LSD in rear, Aussie locker in the front, Front Range Offroad twin sticks, trail gear/ Bash Fab rear bumper, elite off road front bumper and sliders, warn m8000 winch, in cab winch control
    Anyone try one of these? yneganyn_20cb648bec6e1b85764513c413227648b6dcb824.jpg
    Gonna try it with my smokey mountain weber.
