Food Smokers and Smoking Tips/Tricks/Techniques
Discussion in 'Food Talk' started by Polymerhead, Jul 15, 2012.
  1. Jul 18, 2017 at 4:52 AM
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Too poor to list anything interesting.
    Smoke belly for a bit then finish in the oven for crispies. Mmmm...
    bvbull200[QUOTED] likes this.
  2. Jul 18, 2017 at 4:55 AM
    Chipskip
    Chipskip N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
    I have been looking into that, was recommend to be by a friend of a friend. You like it? Does it really help?
  3. Jul 18, 2017 at 5:06 AM
    bigfoote13
    bigfoote13 Well-Known Member
    Joe
    South Florida
    15 TRD SPORT
    2016 Sport suspension 1/2 spacer up front and aal in rear SCS Stealth 6 17 inch wheels Wildpeak AT3 265 70 17
    I don't have one. I am going to try the dryer vent first.
    Chipskip[QUOTED] likes this.
  4. Jul 18, 2017 at 5:58 AM
    Cold Iron
    Cold Iron Well-Known Member
    Mn.
    2013 AC T|X Baja
    Most will be bacon, it is all about the cure. Smoking is just to add the smoke goodness, many take the internal temp. to 150 but even that is not required. The maple syrup half will of course all be bacon. My favorite way to cook homemade bacon is thick cut laying directly on the grill grates. The savory half will be half bacon. The rest I will cube up into about 3/8" squares and pan fry. The grease will be used for about any and everything LOL. The chunks will go on salads, baked beans, green beans, scrambled eggs, etc.
    Again IMO it is all about the cure. I have always wet brined it but next belly will finally try dry brine. I think, happy with my brines although always room for improvement.
    Chipskip likes this.
  5. Jul 18, 2017 at 10:45 AM
    Chipskip
    Chipskip N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
    Ok, I have successfully modded my GMG DB.
    If you have a none wifi model, you can go stand next to the grill, with it on, and see if you get a wifi signal from it. If you see something like “GMG...” than you have a wifi chip and can turn your smoker into a wifi model for $9.
    1. Pull your control panel.
    2. Look for a wifi chip (between the two boards, clearly labeled “Wi-Fi”)
    3. Get antenna and cable (I ordered from Amazon, two pack for $9). https://www.amazon.com/gp/product/B06WGMY7LP/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1
    4. Discountect Power -> Remove control board -> Unplug top two white connectors
    5. Plug cable into said chip (I removed the top screw and loosened the bottom, that holds the circuit boards together, then pulled them apart just enough to rotate the boards).
    6. Find spot to mount antenna, I went with the back side of the hopper. I have seen several people relocate and use a bigger antenna on the wifi models for better signal.
    7. Fallow the instructions to connect and update firmware.
    You now have wifi on your GMG in less time than it takes to drink a beer.
    DISCLAIMER: I have heard conflicting reports about warranty, GMG told me this wont void the warranty. This mod is not intended for you to buy a non-wifi to save money and do this. There is no garuntee that your new GMG will have the same wifi chip in it. If you want wifi, then buy wifi. If you bought non-wifi and later regretted it (Or just want to play with it) and you happen to get lucky and have a wifi chip, then proceed at your own risk. I take no responsibility for you or your grill or the number of beers you drink to do this mod.
    CurtB and scottalot like this.
  6. Jul 18, 2017 at 10:47 AM
    bigfoote13
    Joe
    South Florida
    15 TRD SPORT
    Have you been able to get your DB on your home network?
    scottalot likes this.
  7. Jul 18, 2017 at 10:48 AM
    Chipskip
    Chipskip N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
    Yes, I have updated the firmware and connected it to my home network. I have not tested server mode yet.
  8. Jul 18, 2017 at 10:57 AM
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    Interesting.! So maybe the non WiFi models on lack the antenna? I'll be checking this out, and thanks!
  9. Jul 18, 2017 at 10:59 AM
    Chipskip
    Chipskip N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
    Correct, it seems so for some models. Mine was bought June of last year. Some guys on pelletheads.com said theirs was the same and only a few months old.
    The password to connect to the wifi is your serial number, which is on a green plate on the back side of the grill.
    CurtB[QUOTED] and scottalot like this.
  10. Jul 18, 2017 at 11:23 AM
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    I have a signal, but I can't connect. Prolly need to DL the app 1st?
    Chipskip and scottalot like this.
  11. Jul 18, 2017 at 11:24 AM
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    Ahh trying now.
    Chipskip[QUOTED] and scottalot like this.
  12. Jul 18, 2017 at 11:25 AM
    bigfoote13
    Joe
    South Florida
    15 TRD SPORT
    yes u need the app.
  13. Jul 18, 2017 at 11:54 AM
    Chipskip
    Chipskip N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
  14. Jul 18, 2017 at 11:56 AM
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    Yep, it worked at close range. Antenna ordered. I may need some clarification on the install hookup.
    thank you so much for this. The WiFi model was an extra $150 or so? wtf! Just for an antenna!??
  15. Jul 18, 2017 at 12:03 PM
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    @Chipskip You are the man! thanks again!
  16. Jul 18, 2017 at 12:13 PM
    Chipskip
    Chipskip N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
    Glad I could help. If you need me to take pics of the antenna connection, I can. It's the only little gold circle (super small) on the corner of the wifi chip. Just move the top board out of the way and you can easily access it.
    CurtB[QUOTED] and Justified like this.
  17. Jul 18, 2017 at 12:24 PM
    Chipskip
    Chipskip N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
    Next mod for me is to lift it and put on new tires. There is a guy on the GMG unofficial Owners page that makes a kit. 6" lift and tractor tires... tonka tractor that is..
    17097493_1088393857954303_7105415622441504044_o.jpg 17159342_1088393867954302_4013191856696215958_o.jpg
  18. Jul 18, 2017 at 12:36 PM
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    Thanks. When I get the antenna I may just need some help.
  19. Jul 18, 2017 at 1:12 PM
    bigfoote13
    Joe
    South Florida
    15 TRD SPORT
    I had to update my firmware. We ready now!
  20. Jul 18, 2017 at 1:28 PM
    bvbull200
    bvbull200 Well-Known Member
    Bryan
    DFW, Texas
    2013 DCSB SR5 Prerunner Texas Edition
    Fresh wiper fluid
    I don't have a GMG, but that is a pretty badass contribution to the community of people that do, @Chipskip .
    Helluva find.
    CurtB and Chipskip like this.
