Food Smokers and Smoking Tips/Tricks/Techniques
Discussion in 'Food Talk' started by Polymerhead, Jul 15, 2012.
  1. Aug 10, 2017 at 11:12 AM
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Too poor to list anything interesting.
    A few sleepless trial runs so you can get a feel for it.
    I drop a fire extinguisher nearby for easy reach. Plus this is done under the car port which is 6'-8' from anything combustible.
    scottalot and nDub[QUOTED] like this.
  2. Aug 10, 2017 at 11:17 AM
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    Good idea.
    I do it on my back porch... Probably not the brightest idea but haven't had any issues yet.
    One of the reasons I put the smoker in a SS tub with a couple inches water if I have to leave it for any period of time.
  3. Aug 10, 2017 at 12:55 PM
    anonemoose
    anonemoose Well-Known Member
    Bill
    Big Pine, Calif
    2015 White TRD Sport V6 DCSB
    Ride-Rites, Everything Weather-Tech Makes Added some 12 volt outlets with relays
    scottalot likes this.
  4. Aug 10, 2017 at 3:32 PM
    anonemoose
    Bill
    Big Pine, Calif
    Sometimes I don't trust reviews but 3 different sites run about the same - pan needs clean up for the welds and the knife needs a good sharpening, not a good knife for some meats. The plastic inserts sound like a good idea, if I can get 1/8th inch cuts I'd be happy. I have 12 pounds of cut meat right now so not in a hurry but unless someone has used one and says it's junk I will be ordering after this camping trip.
  5. Aug 10, 2017 at 3:39 PM
    horstuff
    horstuff Re-member
    PNW
    2015 Base 2.7 Access Cab 4x4 5 sp
    Looks like it would slide all over the counter.
  6. Aug 10, 2017 at 3:54 PM
    anonemoose
    Bill
    Big Pine, Calif
    That's one of the complaints about it. As Scottalot said, a non-slip mat. Need to see it, then figure it out.
  7. Aug 10, 2017 at 4:02 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
  8. Aug 10, 2017 at 4:03 PM
    wilcam47
    Will
    Bourbon state
  9. Aug 10, 2017 at 4:15 PM
    WBF610
    WBF610 Member well known
    Carey
    Eastern PA
    2016 DC OR
    mats, flaps, and stickers. Extang solid fold 2.0. Mobtown sliders and full skids. AVS vents
    Just found an 18" wsm for $80 on CL.
    Ackrite, Cold Iron and wilcam47 like this.
  10. Aug 10, 2017 at 4:19 PM
    horstuff
    horstuff Re-member
    PNW
    la0d0g likes this.
  11. Aug 10, 2017 at 4:24 PM
    WBF610
    Carey
    Eastern PA
    2016 DC OR
    Emailed them, told them I'd take it. We'll see what happens.
  12. Aug 10, 2017 at 4:55 PM
    anonemoose
    Bill
    Big Pine, Calif
    I was thinking clamping it down, sheet of plexiglass on top, adding weight. For the small pieces... I have sliced my fingers so may times on a mandolin, when I scream all Robi asks is "you need stitches this time?"
    scottalot[QUOTED] likes this.
  13. Aug 10, 2017 at 6:13 PM
    Cold Iron
    Cold Iron Well-Known Member
    Mn.
    2013 AC T|X Baja
    Why yes it is, although Sniper in my avatar passed away a couple of months ago at the age of 14. Been around the breed for more than 30 years now. 2 months ago took in a rehomed Toller from a breeder in Texas that is a year and a half. Handful and hunting season is almost here. He has come a long ways.
    My 2.5 year old is just waiting for hunting season, impatiently. He turned 2 in SD last year. He has the ditch chickens down pretty good.
    And the limb chickens in the deep woods
    But normally use 1949 16 ga. M37 on ruff
    Maybe brisket, never bought a prime brisket. But every other cut of beef sure as hell can. If you can't you need a new butcher shop or packing plant.
    I have that T-shirt. Make that long johns and down parka at teens and twenties below zero.
    Those black plastic Weber covers suck when it gets cold you can't even remove them they are so stiff.
    I have this one-
    https://www.amazon.com/gp/product/B014KF8KSE/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
    Works great. I put a towel under it to prevent sliding. And when I get close to the bottom use a small plastic cutting board on top to press down. Knife isn't the best but isn't bad. Made a lot of jerky with it so far.
  14. Aug 10, 2017 at 6:24 PM
    Cold Iron
    Mn.
    2013 AC T|X Baja
    Fired up the Vortex again tonight. Got back from Buffalo NY Monday night and had enough Buffalo wings when I was there so was looking for something different.
    Parmesan garlic (naked here) and rub a dub mixed 50-50 with Memphis rub.
    20 min in.
    After 30 minutes pulled the naked wings and tossed in my garlic Parmesan mix and threw back on to get a cheese crust. Did 10 more minutes.
    Turned out pretty damn good. The rub mix burnt of course with the high heat. Still pretty tasty
    One thing to be carful of with the Vortex is all the grease that drips out of the wings sitting on the edges. I didn't clean it after the last time I used it. At the end after I pulled them immediately got a huge Class Bravo fire.
    Grate is clean now...
    nDub, Kanyon71, bvbull200 and 3 others like this.
  15. Aug 10, 2017 at 6:29 PM
    dan0mite
    dan0mite #NOTNORM
    Dan
    SC
    d00kie
    Check The Build Thread
    I was considering one of those vortex dohicky thingamabobs. Worth it vs just moving all the charcoal to one side for indirect?
  16. Aug 10, 2017 at 6:31 PM
    horstuff
    horstuff Re-member
    PNW
    Good question :popcorn:
  17. Aug 10, 2017 at 6:38 PM
    anonemoose
    Bill
    Big Pine, Calif
    That has good reviews, added to my list to consider.
  18. Aug 10, 2017 at 6:45 PM
    Ackrite
    Ackrite Well-Known Member
    SoCal
    1985 Toyota Pickup 4x4 single cab
    You are doing it wrong. They list it at $80, you offer $50. 80% of the time it works 100%.
    nDub, WBF610[QUOTED] and Cold Iron like this.
  19. Aug 10, 2017 at 6:47 PM
    JeffRoyJenkins
    JeffRoyJenkins Essentially Non-Essential
    Jeff
    Lake Stevens, WA
    2024 F-150 XLT PowerBoost
    Good looking pup, I have been wanting a Toller for a while but there aren't any breeders in my area and I haven't really ever seen any Tollers around here.
  20. Aug 10, 2017 at 7:01 PM
    Ackrite
    SoCal
    Nice looking dog. I am patiently waiting til Halloween week for my trip to SD for some pheasant.
    I finally picked up a good shotgun for my annual trip a few months ago.
