Food Smokers and Smoking Tips/Tricks/Techniques
Discussion in 'Food Talk' started by Polymerhead, Jul 15, 2012.
  1. Oct 14, 2012 at 8:38 AM
    #121
    toughtaco
    toughtaco Well-Known Member
    05 tacoma dbl cab short bed
    TRD CAI, MBRP dual exhaust, PIAA headlights and driving lights, 5% limo tint, 3 inch Skyjacker lift , AFE throttle body spacer, 285/70/17 BF Goodright AT TA KO, Grillcraft MX with PIAA's behind the grill, anytime fog light mod, reverse camera anytime mod, and PIAA fog lights on the rear bumper anytime mod light bar behind back window with truck lights for reverse assistance, Optima Red Top Battery, Onza 3x5" LEd reverse lights attached to light bar behind cab
    Here are the ribs........ they went from my stove to my dads house, where the party is going to be.
    His house
  2. Oct 14, 2012 at 8:55 AM
    #122
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2018 Jeep Wrangler JL Rubicon
    Has anyone made a smoker out of an old gas grill. I have an old grill from camping/tailgateing that I hate to throw out.
  3. Oct 14, 2012 at 8:59 AM
    #123
    PB65stang
    PB65stang Well-Known Member
    Patrick
    Kansas City
    2016 F150 Lariat 4x4
    5100s (2.5" front), OEM Raptor wheels, 315/70/17 BFGs, Undercover, tint, Weathertechs.
    Sounds like a busy day, toughtaco! Good job on doing so much BBQ. I'm doing 2 chickens tonight...will post pics later!
  4. Oct 14, 2012 at 11:20 AM
    #124
    Polymerhead
    Polymerhead [OP] Well-Known Member
    Missouri
    '18 TRD Limited Inferno...Tundra!
    Haven't, but it surely would be doable. My smoker is made from a keg.
  5. Oct 14, 2012 at 11:23 AM
    #125
    BostonBilly
    Easton
    Ya I saw that very cool. I figure close all the holes but one or add a stack to the top like yours. Grate the inside one half for food the other for wood. Would there be more to it or is that all
  6. Oct 14, 2012 at 11:34 AM
    #126
    Polymerhead
    Missouri
    That'd be about it. If I was doing one horizontally I'd add a stack on one side, add a thermometer in the lid in the middle and separate off a little firebox on the far side. Drill some holes next to the firebox. I'd start with maybe two 1/2" holes and see what temp it keeps. If the fire stays lit, then you're good. If it goes out, you need to drill another hole. I only have a couple small holes allowing air into my keg.
  7. Oct 14, 2012 at 11:42 AM
    #127
    BostonBilly
    Easton
    Cool thanks for the info
  8. Oct 19, 2012 at 11:59 AM
    #128
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    So my smoker will be getting it's inaugural use tomorrow, doing a pork shoulder. Should I put the rub on tonight and let I sit in the fridge like that overnight?
  9. Oct 19, 2012 at 1:37 PM
    #129
    Polymerhead
    Missouri
    Absolutely.
  10. Oct 19, 2012 at 1:42 PM
    #130
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    we have a green egg. idk how old it is, but i can remember us having it when i was little. so i’d say 15+ years old. i love some home smoked pulled BBQ!
  11. Oct 19, 2012 at 1:45 PM
    #131
    PB65stang
    Patrick
    Kansas City
    Totally up to you. Some people, like posted above, do. Others, like myself, subscribe to the theory that it does you no good to apply a rub beforehand, as it doesn't absorb into the meat at all. But it's definitely not going to hurt anything.
    Same deal goes for smoke wood...some people soak it, others do not. Tests have shown that water doesn't absorb into the wood very deep anyways, so you're not gaining anything from doing it.
  12. Oct 19, 2012 at 1:57 PM
    #132
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    LOL
    I usually fold up tin foil and wedge it between the top and the base on my Brinkman. I am in the market for another smoker. Probably a Weber.
  13. Oct 19, 2012 at 5:10 PM
    #133
    jtav2002
    Josh
    Reading, PA
    Pork shoulder I have is about 6lbs. How long are you guys doing per pound? Leave it on the whole time or pull it off after several hours and throw in oven?
  14. Oct 19, 2012 at 6:18 PM
    #134
    Polymerhead
    Missouri
    I usually smoke a ~9 lb shoulder and smoke it for at least 6 hours, 8 is better. For a 6 lb shoulder, I'd shoot for an hour a pound assuming you're smoking around 225 degrees. By that time you have pretty good bark usually, and it's not going to take in much more smoke. After 6 or 8 hours of smoke, the goal is simply to bring the meat up to 190 or so. An oven set at 220 is as good or better as a smoker for this part.
    Just fight the urge to pull it during the stall - your shoulder will hit 165-170 degrees and stall out there for a couple hours at least. You will get the urge to stop cooking it. DO NOT STOP COOKING IT. After the stall it'll rise from 170 to 190 in about 2 hours. Then let it rest for at least an hour and then it'll pull like butter.
  15. Oct 19, 2012 at 6:30 PM
    #135
    jtav2002
    Josh
    Reading, PA
    Sounds good, thanks.
  16. Oct 19, 2012 at 6:33 PM
    #136
    Polymerhead
    Missouri
    Good luck man. Take pics if you get a chance!
  17. Oct 19, 2012 at 6:59 PM
    #137
    toughtaco
    The ribs were flowing over the edges, the top was just placed on the ribs. That is why I wrapped it in foil.
  18. Oct 19, 2012 at 7:00 PM
    #138
    toughtaco
    I am going to try to get the biggest pork shoulder I can get my hands on for next Sunday's party. I will probably make that on Friday though so I can have it pulled once it's done then move onto the next meat.
  19. Oct 19, 2012 at 7:58 PM
    #139
    MTBerJim
    MTBerJim You Know We Can't Do This All Day!!!
    Long Island, NY.
    2012 Tacoma 2.7, Auto, 4x4
    Original
    I've got the very same smoker, My brother-in-law also has the same one, I used his for a party before I bought mine.
    The side box is great, I can tend to the coals/wood chunks without having to disturb the food under the other cover. I think I paid $170 for mine.
  20. Oct 19, 2012 at 8:09 PM
    #140
    MTBerJim
    Long Island, NY.
    Original
    In a related subject, on my first outing using a smoker (so effing green) I tried doing beef brisket. Taste wasn't to shabby, texture was another thing. Very tough, of course I later found out beef brisket isn't for the faint of heart.
    The question is, what do you guys do to get them tender? A lot of the BBQ shows the guys do all kinds of stuff, not the least of which is injecting the brisket.
    what do you do and be honest is it tender after?
