Food Smokers and Smoking Tips/Tricks/Techniques
Discussion in 'Food Talk' started by Polymerhead, Jul 15, 2012.
  1. Sep 22, 2017 at 7:34 PM
    horstuff
    horstuff Re-member
    PNW
    2015 Base 2.7 Access Cab 4x4 5 sp
    Loves me some hat pulled pork, fck the claws :D :thumbsup:
    Great ring.
    scottalot and Synergy001[QUOTED] like this.
  2. Sep 22, 2017 at 9:06 PM
    Sprocket
    Sprocket Well-Known Member
    Whatever works for you Dude. Not gonna bash here.
    I'll make a suggestion though - try curling one rack up like a C and placing it on the rack, on edge not on the flat.
    Now add another rack - because 2 is better than 1 - and make it like a 69 shape Ying/Yang style on the same rack
    Cook in the usual way but enjoy twice as much ribs!
    I'll bash a little after reading it all again:
    Cal...'splains it.
    Have fun
  3. Sep 22, 2017 at 9:29 PM
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    I've been looking for a snoker for days and finally found one.
    Good deal?
  4. Sep 23, 2017 at 1:27 AM
    horstuff
    horstuff Re-member
    PNW
    Snokers are so rare... Be cool and gentle.
    Cold Iron, nDub[QUOTED] and scottalot like this.
  5. Sep 23, 2017 at 6:00 AM
    AugustaTaco
    AugustaTaco Well-Known Member
    Josh
    Augusta, GA
    2015 DCSBXSPX4X4 2017 GX460
    "Getting out of hand" - Wife
    It has Tacoma wheels on it, doesn't it? Dream snoker right there...
    Cold Iron, nDub[QUOTED] and WBF610 like this.
  6. Sep 23, 2017 at 7:19 AM
    Cooktop86
    Cooktop86 Well-Known Member
    Jeff
    Hatfield, Pa
    2017 Tacoma TRD sport MGM
    Smoking a pork shoulder and some bacon balls today.
    Maybe some wings later.
    Synergy001, oscolivar1 and Cold Iron like this.
  7. Sep 23, 2017 at 7:20 AM
    Cooktop86
    Jeff
    Hatfield, Pa
    Here is a pic with the rub on the shoulder
    Synergy001, oscolivar1 and nDub like this.
  8. Sep 23, 2017 at 10:11 AM
    Cooktop86
    Jeff
    Hatfield, Pa
    Everything is on the smoker now.
  9. Sep 23, 2017 at 11:07 AM
    horstuff
    horstuff Re-member
    PNW
    What are the balls? Please explain your balls.
  10. Sep 23, 2017 at 11:11 AM
    Cold Iron
    Cold Iron Well-Known Member
    Mn.
    2013 AC T|X Baja
    Meat on a stick. Fire. Good. Meat is always good on a stick, any meat on any stick.
  11. Sep 23, 2017 at 11:37 AM
    horstuff
    horstuff Re-member
    PNW
    How they gonna make decent Q if the sign says no smoking?
    :rimshot:
    Thank you very much. I'll be here all week.
  12. Sep 23, 2017 at 11:48 AM
    Cooktop86
    Jeff
    Hatfield, Pa
    My balls are 80/20 ground meat rolled into the size of meatballs then I wrapped them in bacon. I smoked them for 2.5 hours during that time I was using the bbq sauce I made as a mop so they would dry out.
    Cold Iron, scottalot and bvbull200 like this.
  13. Sep 23, 2017 at 12:01 PM
    horstuff
    horstuff Re-member
    PNW
    So the only seasoning was the mop sauce? And would they even dry out with the bacon wrap? Never done them before, asking for a friend.
  14. Sep 23, 2017 at 12:52 PM
    Fiend13
    Fiend13 Well-Known Member
    Chad
    Waddell/Phoenix area
    08 TRD O/R DC Prerunner
    So please don't shame me, lol. 2 weeks ago I was smoking some chickens and the grease pan caught fire. I know that's my fault for not cleaning it prior. It got so hot that the door bowed out. Once I noticed that, I hosed it with an extinguisher to put the fire out. Any tips or recommendations on what to clean it with? Or just clean it normally, light it up, and let the heat take care of it?
    Cooktop86 and scottalot like this.
  15. Sep 23, 2017 at 1:11 PM
    horstuff
    horstuff Re-member
    PNW
  16. Sep 23, 2017 at 1:23 PM
    dan0mite
    dan0mite #NOTNORM
    Dan
    SC
    d00kie
    Check The Build Thread
    :facepalm:
    scottalot[QUOTED] likes this.
  17. Sep 23, 2017 at 2:11 PM
    Cold Iron
    Mn.
    2013 AC T|X Baja
    Depends on your smoker. I am doing chicken wings with a Vortex on the Weber kettle right now. When I am done and it cools I use a plastic putty knife and scrape the sides and dump the ash bowl. For porcelain coated steel like a Weber kettle or WSM a plastic putty knife is normally recommended. If it was uncoated steel or stainless I would just use a metal putty knife. And if it gets too cooked on I do even on the Weber. But if I stay ahead of it usually isn't a problem. Except in the winter when it freezes solid.
  18. Sep 23, 2017 at 2:49 PM
    Ackrite
    Ackrite Well-Known Member
    SoCal
    1985 Toyota Pickup 4x4 single cab
    Clean looking 85 in the background. Do I spy a flatbed on it?
    scottalot, nDub[QUOTED] and Cooktop86 like this.
  19. Sep 23, 2017 at 3:00 PM
    Ackrite
    SoCal
    "Get them all" is the only acceptable answer. And any reason is a good reason.
    Family portrait today. The other 18 was feeling camera shy and stayed in the garage.
    And the 14 cannot be beat for everyday use.
  20. Sep 23, 2017 at 3:08 PM
    Cooktop86
    Jeff
    Hatfield, Pa
    I used the normal burger seasoning that I would use. I wanted to use the bbq as a glaze.
