Food Smokers and Smoking Tips/Tricks/Techniques
Discussion in 'Food Talk' started by Polymerhead, Jul 15, 2012.
  1. Oct 17, 2017 at 9:33 AM
    Bulldogs129
    Bulldogs129 Don't find fault, find a remedy
    Malcolm
    Mississippi
    2018 TRD, OR, 4wd, Dblcab, 3.5l, & 2002 Tacoma 4wd, SR5, TRD, 3.4L, auto
    I like the firewall idea...It'll help my flare-ups on the weber
    gilligoon[QUOTED] and scottalot like this.
  2. Oct 17, 2017 at 11:39 AM
    Kanyon71
    Kanyon71 Well-Known Member
    MI
    Have you tried your wood uncooked? I heard you get more vitamins from it. Cooked wood is so yesterday. Silly vegans :)
    scottalot[QUOTED] and wilcam47 like this.
  3. Oct 17, 2017 at 12:05 PM
    gilligoon
    gilligoon Well-Known Member
    Goon
    Watoosa Ridge, GA
    2017 Quicksand TRD OR DCSB
    Bilstein, ICON, Mobtown, Southern Style, Warn, SOS, Nitto, ARE, Northstar
    You are looking at the first 5 minutes of cooking... Once the fire burns down to the coals, I flip the grill over so it's only about 6" from the coals, in a white chert-lined firepit. It's plenty hot... plus I use a meat thermometer to make sure it's 175º in the breast before serving. It's basically rotisserie-style chicken, but on a grill.
    scottalot[QUOTED] and Cold Iron like this.
  4. Oct 17, 2017 at 2:10 PM
    Cold Iron
    Cold Iron Well-Known Member
    Mn.
    2013 AC T|X Baja
    :thumbsup: I have never done them whole like that but use a similar grill when camping. Or rather have many times in the past. My youngest son took this of me cooking 2 split chickens when we were deer hunting almost 15 years ago at the Rainy River on the Canadian Border. Hell guess I was splatchcocking before it was even a word.
    Mainly birch and pine there, all of it you could ever imagine LOL. So always carried oak to cook on. With the Emerald Ash Borer Beetle now it has to be DNR approved wood at more than $400 a face cord :eek: So use charcoal instead when I have to transport wood.
    nDub, gilligoon[QUOTED] and scottalot like this.
  5. Oct 17, 2017 at 2:38 PM
    Bulldogs129
    Malcolm
    Mississippi
    :fingerscrossed::popcorn:
    scottalot[QUOTED] likes this.
  6. Oct 17, 2017 at 3:48 PM
    horstuff
    horstuff Re-member
    PNW
    2015 Base 2.7 Access Cab 4x4 5 sp
    I use this... plastic, but dual so you make more at a time... I put a half cup of 80/20 in each side, press hard with a hand on each side, plop them out, then further squish the patties with cold hands to get them diner style, like 3/8" thick 6.5 inches round. They shrink to perfect when cooked for 2 patties per burger (animal style, how I roll).
    https://www.amazon.com/Charcoal-Companion-Plastic-Hamburger-Grilling/dp/B000P0O51U
  7. Oct 17, 2017 at 4:28 PM
    la0d0g
    running for the hills
    For crawling not hauling
    Haven't found one that is better than my hands.
    Edit: Haven't searched that hard either. I like forming burgers.
  8. Oct 17, 2017 at 4:30 PM
    horstuff
    horstuff Re-member
    PNW
    As long as you have ice water to dip them in now and again so the meat doesn't turn to mush. Overworked and overwarm raw meat is nasty. That's what she...
  9. Oct 17, 2017 at 4:34 PM
    la0d0g
    Agreed. I usually only make four at a time and between mixing it and forming I'm not exceeding 3-4 minutes. Then I let those little guys sit out for an hour or so while setting up the grill though.
  10. Oct 17, 2017 at 4:40 PM
    horstuff
    horstuff Re-member
    PNW
    Leaving them out for awhile after forming the patties is fine so the centers aren’t too cold, but I was more talking about the patties becoming a dense mush from over heat and over work... they should be as loose as they can be without being a problem holding together. That’s the only reservation I have about a press because by definition you’re mushing it together pretty tightly, but when you have a whole bunch to make up, it’s worth it if used properly.
    la0d0g[QUOTED] and Boerseun like this.
  11. Oct 17, 2017 at 5:35 PM
    Misplaced Nebraskan
    Misplaced Nebraskan TTC #007 'First Gen Best Gen'
    Zach
    Austin
    2001 Taco & 16 T4R TPE
    Pics or it didn't happen :spy::D
  12. Oct 17, 2017 at 5:40 PM
    Misplaced Nebraskan
    Zach
    Austin
    I'll allow it :hungry:
    I want a burger now... And bbq :D
  13. Oct 17, 2017 at 6:19 PM
    horstuff
    horstuff Re-member
    PNW
    Fry dip = ketchup, hot sauce, and mayo. Yum fckng yum. Or Uncle Dans Original Southern. Actually fries are good dipped in anything :D
    Cold Iron likes this.
  14. Oct 17, 2017 at 6:36 PM
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    Uh oh. :eek:
    I’ve been doing it wrong... seriously I mush the meat together until it’s nice and gooey before making a patty.
    Time to rethink my technique.
  15. Oct 17, 2017 at 6:40 PM
    horstuff
    horstuff Re-member
    PNW
    I think so anyway. Burgers shouldn’t be dense like meatloaf.
    nDub[QUOTED] likes this.
  16. Oct 17, 2017 at 6:49 PM
    horstuff
    horstuff Re-member
    PNW
    And back on smoking, I smoke my burgers on WSM top rack, no water, 2 hickory chunks, until brown on each side, no flipping required if brown on top (mimnimize breakage). Only takes 10 minutes. Then move rack to lower section of smoker, middle removed, just above the coals. Flames will ensue. Char each side one minute, pull, rest for 5 minutes. Maximum grubbage. Nom nom.
    Close vents, keep remaining coals and chunks for another day. Only thing about this technique with a WSM is you have to know how much ash is in bottom pan when starting, because you can’t know when done and next cook comes up. Needs to breath.
    Cold Iron, bvbull200 and nDub like this.
  17. Oct 17, 2017 at 7:02 PM
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    I use sheets of wax paper between two dinner plates (top to bottom), you can make them uniform and thin/thick as you prefer.
  18. Oct 17, 2017 at 7:06 PM
    horstuff
    horstuff Re-member
    PNW
    Good technique. I use these in between two patties when vac sealing, different brand same thing...
    https://www.amazon.com/Weston-Hamburger-Patty-pieces-10-0102-W/dp/B001MVZN26
  19. Oct 17, 2017 at 7:08 PM
    t4daddy
    North Alabama
    I wondered if I was the only one that reused charcoal. I use a very small Kingsford brand grill with nice cast grates. I modified the coal rack (hard to imagine I know) to raise the coal bed to within four inches of the cooking surface. I cook on a pretty hot grill, usually never leaving it while cooking. As soon as I pull whatever, I choke it down damper wise. Next cook I start with only 10-12 new briquettes and add all the leftover charcoal to top off the chimney. I use charcoal three times as a rule.
    Cold Iron and truchador like this.
  20. Oct 17, 2017 at 10:05 PM
    Soflanick
    Soflanick Well-Known Member
    Nick
    FLORIDA
    2001 tacoma prerunner
    5100 front, 5125 rear, 2"all, old ARE topper, 16x8 XD enduro's on 265/75r16 KO2's
    Got a big cook coming up tomorrow on the 18” wsm.
    2 5lb chickens and a 6 or 7 lb pork butt.
    I’m cooking for 12 people that my girlfriend invited over of course. Gonna have some slow cooker Mac and cheese, green beans, and my “famous” corn bread casserole.
    I was thinking about roasting one bird, and smoking the other. In case some of the guests do not like smoked meat. Maybe do a bear can variation. That or just spatchcock both birds and place them on the top rack of my Weber.
    Cookout is tomorrow, so expect some pictures if I remember lol
