Food Smokers and Smoking Tips/Tricks/Techniques
Discussion in 'Food Talk' started by Polymerhead, Jul 15, 2012.
  1. Oct 19, 2012 at 8:22 PM
    #141
    Polymerhead
    Polymerhead [OP] Well-Known Member
    Missouri
    '18 TRD Limited Inferno...Tundra!
    I smoke brisket for less time than pork. and I cut across the grain and slice it thin - maybe 3/16". Doing this helps me not have to worry about tender. I think brisket should be firm. If I wanted it to fall apart I'd cook it in the crockpot. I am definitely not the brisket pro on the board though. I've only done a couple. As far as I can tell, brisket dries out easily and the last thing I want is mealy beef because I tried to cook it long enough to get it really tender.
  2. Oct 20, 2012 at 3:47 AM
    #142
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    I thought it was funny that we both have the same grille and use tin foil to stop the smoke from venting so quickly. ;)
    The brinkman does a decent job but the loss of heat and smoke make the process take longer than it should.
  3. Oct 20, 2012 at 8:43 AM
    #143
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    Well here goes nothing, put the shoulder on about a half hour ago.
  4. Oct 20, 2012 at 8:51 AM
    #144
    PB65stang
    PB65stang Well-Known Member
    Patrick
    Kansas City
    2016 F150 Lariat 4x4
    5100s (2.5" front), OEM Raptor wheels, 315/70/17 BFGs, Undercover, tint, Weathertechs.
    Brisket is tough to do. I make sure to baste often and definitely have a water pan below it to keep it moist. It takes a long time too...I've done brisket for 16 hours before. The best brisket I did was about 9 hours on the smoker, then finished in the oven wrapped in foil. Extremely juicy...people raved over it! I did the technique on virtualweberbullet.com.
  5. Oct 20, 2012 at 8:55 AM
    #145
    PB65stang
    Patrick
    Kansas City
    Good luck! Pork is generally pretty straight forward...just keep the temp right and take your time. As a general rule, a 10 lb butt usually takes me about 12 hours, so I'd guess your 6 lber would probably take me 7-8. I'm sure it will be delicious!
  6. Oct 20, 2012 at 9:44 AM
    #146
    jtav2002
    Josh
    Reading, PA
    So after about an hour or so the "temp" gauge has hovered between the line of "warm" and ideal" and hasn't gotten up any warmer (obviously I need to buy a real thermometer for it to monitor actual temp. Any tips on getting it hotter? Is it just going to hover there now or does it take awhile to get up to temperature? I did have some foil up around the top where the bigger openings were where the lid and the base meet to keep some of the heat from escaping.
  7. Oct 20, 2012 at 9:47 AM
    #147
    Polymerhead
    Missouri
    I'd try to open the bottom vent a little if there is one. If you're smothering the coal, you'll get acrid thick smoke instead of light blue smoke and the fire probably won't stay lit and you won't get the heat you need.
  8. Oct 20, 2012 at 9:49 AM
    #148
    jtav2002
    Josh
    Reading, PA
    I'll check, don't think there's any operable vent per se in the bottom. Just the door on the side.
  9. Oct 20, 2012 at 9:58 AM
    #149
    jtav2002
    Josh
    Reading, PA
    Well I just went out temperature has gone up so ill just monitor for now.
    EDIT: and its dropped back down into "warm" grrrr
  10. Oct 20, 2012 at 10:45 AM
    #150
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    What type smoker you using, a pill type. If so a light breeze used to kill mine. Set up a wind break of some sort if possible. On the temp you need a internal meat thermometer, pull at 190-195, and let rest 1 hour before pulling. No two butts will finish at the same time
  11. Oct 20, 2012 at 10:51 AM
    #151
    jtav2002
    Josh
    Reading, PA
    Should I just stick the meat thermometer in now and leave it in the meat?
  12. Oct 20, 2012 at 10:55 AM
    #152
    t4daddy
    North Alabama
    That's what I used to do, now I use a prob, so I don't have to open up the smoker to check actual temps. "if you looking, you ain't cooking"
  13. Oct 20, 2012 at 10:57 AM
    #153
    PB65stang
    Patrick
    Kansas City
    My sisters boyfriend has the same smoker and has temp problems too. You can try adding a half chimney or so of lit charcoal but I'd think there has to be a vent on the bottom? How does the charcoal get fed oxygen to stay lit otherwise?? If no vent, I'd say all you can do is add more lit charcoal.
  14. Oct 20, 2012 at 10:59 AM
    #154
    jtav2002
    Josh
    Reading, PA
    The latter part is what I'm worried about, constantly opening up to check. But I might as well just throw the thermometer in it and check back later since I don't have anything else. I'm sure the wind isn't helping my cause, I did place it on the driver rather than the back porch since it was less breezy. May have to bring the Taco through the back yard and in front of the smoker to block some of the wind lol.
  15. Oct 20, 2012 at 11:00 AM
    #155
    PB65stang
    Patrick
    Kansas City
    Probe is a nice thing to have...personally I wouldn't just leave the thermometer in there...just check temp every couple hours until it gets closer to being done, then a little more frequently.
  16. Oct 20, 2012 at 11:00 AM
    #156
    jtav2002
    Josh
    Reading, PA
    Alrighty.
    First time, didn't except it to go smoothly anyway.
  17. Oct 20, 2012 at 11:09 AM
    #157
    PB65stang
    Patrick
    Kansas City
    It's all about learning and figuring out what works for you. And you get to eat your "mistakes"!
  18. Oct 20, 2012 at 11:26 AM
    #158
    toughtaco
    toughtaco Well-Known Member
    05 tacoma dbl cab short bed
    TRD CAI, MBRP dual exhaust, PIAA headlights and driving lights, 5% limo tint, 3 inch Skyjacker lift , AFE throttle body spacer, 285/70/17 BF Goodright AT TA KO, Grillcraft MX with PIAA's behind the grill, anytime fog light mod, reverse camera anytime mod, and PIAA fog lights on the rear bumper anytime mod light bar behind back window with truck lights for reverse assistance, Optima Red Top Battery, Onza 3x5" LEd reverse lights attached to light bar behind cab
    I dont know if the gourmet is anything like the regular brinkmann, but I had to put the fire bowl on brick to put it into the smoker to get the temp up a bit. It worked for me. The only reason I put foil around the top was bc there were so many ribs that the lid didnt close. I might try it at some point to foil the edges just to see if I can smoke it quicker.
  19. Oct 20, 2012 at 11:30 AM
    #159
    t4daddy
    North Alabama
    Yeah, trying is half the battle. Sub 200 degree temps are not gonna hurt a meat thermometer (dishwasher is prolly as hot) the one I have as spent countless hours inside of smokers/grills and it's prolly 20 years old. Seems there "should" be a vent/damper on there, but not sure. Do you happen to have the box the smoker came in? I folded the flaps in, top and bottom and set it over my pill smoker for a wind break. That's the main reason I swapped to a double insulated electric, it's like cheating, program times and temp, load smoke generator, forget it. Rain, wind or cold. I use a Masterbuilt Smokehouse and a A-MAZ-N smoke generator.
  20. Oct 20, 2012 at 11:31 AM
    #160
    jtav2002
    Josh
    Reading, PA
    I've since removed the foil and I have the little hatch open a crack and the temp has gone up some. I think it is getting smothered maybe from air floW underneath
