Food Smokers and Smoking Tips/Tricks/Techniques
Discussion in 'Food Talk' started by Polymerhead, Jul 15, 2012.
  1. Dec 23, 2017 at 3:26 PM
    WBF610
    WBF610 Member well known
    Carey
    Eastern PA
    2016 DC OR
    mats, flaps, and stickers. Extang solid fold 2.0. Mobtown sliders and full skids. AVS vents
    I don’t think his brisket is going to be good. I could be wrong though.
  2. Dec 23, 2017 at 3:33 PM
    anonemoose
    anonemoose Well-Known Member
    Bill
    Big Pine, Calif
    2015 White TRD Sport V6 DCSB
    Ride-Rites, Everything Weather-Tech Makes Added some 12 volt outlets with relays
    Well it does make excellent jerky.....
    wilcam47 and Cold Iron like this.
  3. Dec 23, 2017 at 7:28 PM
    Cold Iron
    Cold Iron Well-Known Member
    Mn.
    2013 AC T|X Baja
    I love my buffalo wings, and really like using the vortex to make them. However once it gets cold there is a problem. They drop a ton of grease and it freezes pretty quickly when it gets cold enough. Normally I just use a plastic putty scrapper and clean the grill it only takes a minute. But once it is frozen it isn't coming out without a blowtorch.
    Tried wrapping aluminum foil around the vortex. It actually made it hotter and the grease caught on fire and I had a class Bravo fire in short order.
    Tried wrapping the whole bowl and made openings for the vents. Basically the same thing the grease ended up catching on fire also.
    Between doing some research and thinking on this tonight came up with a blend of ideas. It is cold enough didn't want frozen grease when I was done.
    Shoot those suckers up with hot sauce using an injector first.
    Then coated with a Caroline style pepper rub. Do not want any sugar on wings it will burn.
    Put the Jumbo Joe inside the 22" kettle and used the grillgrates. They are expensive but claim increases the temp by 200*. It likely comes close.
    My son liked them better than the way I normally do them. I think they need just a little bit more tweaking and will keep playing with it. But crispy on the outside and falling apart tender and juicy on the inside which is filled with hot sauce. A lot less mess to eat and turned out with a stronger smokey grilled flavor than normal. Good baseline to work with anyhow.
    I'm calling it a win, my mouth and stomach do anyhow.
  4. Dec 23, 2017 at 7:31 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    looks like a win to me!
    Cold Iron[QUOTED] and la0d0g like this.
  5. Dec 23, 2017 at 7:54 PM
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    My name is CurtB and I'm a foodaholic. I confess that I have never cooked chicken wings. This thread and the folks posting in it may well be my savior.
    Where to start? Maybe buy some wings and get after it? ;)
    Cold Iron and wilcam47 like this.
  6. Dec 23, 2017 at 8:02 PM
    wilcam47
    Will
    Bourbon state
    rmepilot, dan0mite and Cold Iron like this.
  7. Dec 23, 2017 at 8:03 PM
    wilcam47
    Will
    Bourbon state
    http://virtualweberbullet.com/chicken8.html
    Cold Iron likes this.
  8. Dec 23, 2017 at 10:16 PM
    Aloha Scout
    Aloha Scout Drink beer and smoke your meats
    I actually smoked my own wings tonight too.
  9. Dec 23, 2017 at 10:22 PM
    bvbull200
    bvbull200 Well-Known Member
    Bryan
    DFW, Texas
    2013 DCSB SR5 Prerunner Texas Edition
    Fresh wiper fluid
    On the lighter fluid thing, not for nothing, but Myron Mixon drenches charcoal briquettes with lighter fluid before starting them. He lets it burn off, then uses the bed to burn nothing but peach wood. Massively successful BBQ cook.
    Chimney starter guy, here, though. I don't find the chimney to be appreciably slower and I don't have to wonder if everything is burned off.
    https://www.epicurious.com/archive/holidays/grilling/myronmixonbarbecuetechniques
  10. Dec 23, 2017 at 11:00 PM
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    OK, now I’m confused (doesn’t take much) I’m fairly certain I remember him whaling on a competitor for using LF on a episode of BBQ Pitmasters.
    scottalot and Aloha Scout like this.
  11. Dec 23, 2017 at 11:13 PM
    Aloha Scout
    I’ve used both the chimney and the LF technique. I Have never tasted a difference. I do though let my coals roast for 20 mins, getting them piping hot.
    scottalot likes this.
  12. Dec 23, 2017 at 11:18 PM
    t4daddy
    North Alabama
    I’ll admit I used to use LF. The trick is let it soak for at least one beer before lighting. IMO it’s a bigger thing for grilling vs smoking. I’ll never again, I can have coals ready in less time than you should let the LF soak in, again IMO.
    wilcam47 and scottalot like this.
  13. Dec 24, 2017 at 3:46 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    My name is Connor and I use lighter fluid on all things I burn for food purposes and I am not ashamed.
    Thank you.
  14. Dec 24, 2017 at 3:48 AM
    PerazziMx14
    PerazziMx14 I'm fat but identify as skinny, I'm Trans-slender
    Close to 39.9609243°N, -77.5763777°W
    For lighting the BGE or the Lodge Hibachi I use denatured alcohol. A once or two is all you need. IDK if it reality or a mental thing from the smell of the initial light buy I personally do believe LF imparts taste of the final product. I also only use lump charcoal no bricketts.
    anonemoose likes this.
  15. Dec 24, 2017 at 3:52 AM
    PackCon
    Connor
    I'm not sure why people poo poo lighter fluid. Shit burns off in a matter of a couple minutes if that. It just makes life easier. I don't like using the chimney's. They look good for a couple months then they corrode and seem like a Tetanus hazard. Plus that's one more thing I have to store.
    scottalot[QUOTED] likes this.
  16. Dec 24, 2017 at 3:56 AM
    PerazziMx14
    Smoke hours 14 thru 24 in the books.
  17. Dec 24, 2017 at 4:50 AM
    anonemoose
    Bill
    Big Pine, Calif
    Before I got the pellet grill, that is how I did it as I could taste and smell the LF. I found that DA did not have the calorie/heat to start charcoal so I would soak hickory chips and use them as starter.
  18. Dec 24, 2017 at 5:05 AM
    308savage
    308savage Well-Known Member
    Adam
    East Tennessee
    2012 Tacoma TRD Sport DCSB
    Leveling kit, roll bar
    Could we have a few details please? Temp, recipe?
  19. Dec 24, 2017 at 5:38 AM
    WBF610
    Carey
    Eastern PA
    2016 DC OR
    :transformer:
    I think the heat in the chimney would kill any potential virus or bacteria.
    If you use the chimney, you wouldn’t have to store LF!! :rofl:
    I bought and use a chimney. Mine has held up well and is not showing any sign of corrosion. I got it on sale for the price of one bottle of LF. It’s quicker than those little starter cubes as well.
    Happy Xmas eve all!
    Aloha Scout, t4daddy and Cold Iron like this.
  20. Dec 24, 2017 at 8:03 AM
    MHARMS
    MHARMS Well-Known Member
    2014 Black Tacoma TRD sport DCLB
    GoRhino Dominator D2 nerf bars, K&N air filter, LED cabin lights, Neoprene seats, Billstein 5100 front shocks 2.5" lift, ultra crusher 17” wheels w/ko2s, DIY tinted tail lights, LED reverse lights, CONDENSATE DRAIN HOSE EXTENTION!
    Any good recipes out there for a smoked turkey? I found some I like but I figured I’d also ask here. Using a pellet grill. Also, what wood type do you recommend to smoke with for turkey?
