Food Smokers and Smoking Tips/Tricks/Techniques
Discussion in 'Food Talk' started by Polymerhead, Jul 15, 2012.
  1. Jan 14, 2018 at 8:59 PM
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    want!
    scottalot likes this.
  2. Jan 14, 2018 at 9:06 PM
    Poindexter
    Poindexter Well-Known Member
    north of Denali
    15 V6 auto 4x4 mag gray
    Looking for sausage recipe ideas. So far i have 18ozs bison chuck diced small, and 4 ounces of beef fat from an apple smoked prime rib, also diced small.
    wilcam47, scottalot and Cold Iron like this.
  3. Jan 14, 2018 at 9:53 PM
    horstuff
    horstuff Re-member
    PNW
    2015 Base 2.7 Access Cab 4x4 5 sp
    PM incoming.
    scottalot and CurtB[QUOTED] like this.
  4. Jan 15, 2018 at 3:45 AM
    WebberLander
    WebberLander Well-Known Member
    Mark
    Colorado
    2011 SR5 4x4
    Overlanding Rig
    Hey gang, wanted to follow up on my post with some recent pictures using my outlined method above. Got off work early yesterday so started a batch. Total cook time was about 5 1/2 hours. Came out very tender and a good smoke line.
    Synergy001, Kanyon71, nDub and 9 others like this.
  5. Jan 15, 2018 at 5:21 AM
    Cold Iron
    Cold Iron Well-Known Member
    Mn.
    2013 AC T|X Baja
    Back in North Central Pa. and Twin Tiers most of us used 2/3 bovine and 1/3 pork for all sausage. But the rest of the country can vary and notice that a lot use beef in the mix also. Like @Misplaced Nebraskan used 50% venison and 25% each pork and beef for his summer sausage. Plenty of recipes out there but my advice is to think it through before you commit to it. And don't get crazy with adding a lot of extra ingredients like booze in the mix. Hunting pheasants in SD we even have that made into sausage to get around the possession limits when crossing State lines. And have ended up with some sausage that is not much to my liking, although others seem to like it. So think the ingredients through and how they might taste mixed first is my advice. Can't always tell until you do it sometimes though.
    Looks perfect to me in every aspect! While I like my Shun also like my Miyabi knives too :thumbsup:
    Synergy001, wilcam47, RickS and 3 others like this.
  6. Jan 15, 2018 at 6:19 AM
    DBTaco
    DBTaco Well-Known Member
    NC
    '08 4x4 TRD off road
    Are beef ribs "tough" Its been years since I've had any and the last ones I had were tough. Granted I didn't cook them and they were cooked on gas. I've seen them at the grocery stores and wondered if they were always tough.
    robssol and Misplaced Nebraskan like this.
  7. Jan 15, 2018 at 6:40 AM
    la0d0g
    running for the hills
    For crawling not hauling
    If cooked right they can be super tender. For me, I only do them in a crock pot with a little soy and other spices typically found in Asian cooking. If I'm smoking ribs they're pork.
  8. Jan 15, 2018 at 6:42 AM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Totaled but still alive! Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers,m, Rear bumper 2.0, Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    I’d call them chewy. If you cut them into individual ribs then they’re not to bad.
    DBTaco[QUOTED] and scottalot like this.
  9. Jan 15, 2018 at 7:21 AM
    Misplaced Nebraskan
    Misplaced Nebraskan TTC #007 'First Gen Best Gen'
    Zach
    Austin
    2001 Taco & 16 T4R TPE
    How do you like the miyabi? I was back and forth a lot on that and my shun. Still want one I think.
    Cold Iron[QUOTED] likes this.
  10. Jan 15, 2018 at 8:28 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    There are a ton of different types, Just depends what you are looking for. Breakfast, summer etc. Cabelas has some good kits, as does high mountain. just have to find out what you are wanting to make. Id try to make little batches first rather than make a bunch then it not be what you want and you end up wasting a lot.
    Cold Iron likes this.
  11. Jan 15, 2018 at 8:34 AM
    Cold Iron
    Mn.
    2013 AC T|X Baja
    I like both. Have a full set of Henckle Pro S and happy with their steel so have no issues with them making the steel for Miyabi. The Pro S are my heavy lifting knives now. The Miyabi is a 10* edge and Shun 15* so have to sharpen and hone at different angles but not a big deal to me. Supposedly the Miyabi have less issues with chipping even though they have a thinner edge. I use a wooden board and never have had a problem with the Shun either. I think the cutting board material may be why a lot of people have chipping issues by using too hard of a material, even the plastic boards are likely too hard. Really like the Miyabi knifes so far. Then again I really my ancient walnut 3" swept blade Chicago Cutlery paring knife sometimes too :anonymous:
  12. Jan 15, 2018 at 11:35 AM
    horstuff
    horstuff Re-member
    PNW
    I assume it's worth going out of your way to get refrigerated lard, not shelf stuff. Correct?
    wilcam47[QUOTED] likes this.
  13. Jan 15, 2018 at 1:00 PM
    wilcam47
    Will
    Bourbon state
    I like manteca or lard refrigeration not required but needs to be used in a reasonable amout of time. Can use crisco in a pinch or bacon fat/drippings. at room temp or melted is better.
  14. Jan 15, 2018 at 1:11 PM
    wilcam47
    Will
    Bourbon state
    this is a batch that is now gone, I used butter flavor crisco.
    Synergy001, oscolivar1 and truchador like this.
  15. Jan 15, 2018 at 2:10 PM
    anonemoose
    anonemoose Well-Known Member
    Bill
    Big Pine, Calif
    2015 White TRD Sport V6 DCSB
    Ride-Rites, Everything Weather-Tech Makes Added some 12 volt outlets with relays
    I'll just leave this here....
    https://timesofsandiego.com/politic...sses-old-town-priest-to-bless-uncooked-bacon/
  16. Jan 15, 2018 at 2:54 PM
    Ackrite
    Ackrite Well-Known Member
    SoCal
    1985 Toyota Pickup 4x4 single cab
    They can be tough if not cooked right. If you consider cooking them in 2 stages, they should come out with the same or similar texture to a properly cooked brisket since they are going to just about the same internal temp.
    The first 3 hours will be where they are cooked and take in the smoke flavor, but the wrap is where they get tender.
    You can also do the 3-2-1 method, but I skip that last hour since I appreciate the beef flavor over an added glaze.
    On a side note tidbit about using coffee, the science behind it will help tenderize the beef also with the acidity. That is according to my research.
    wilcam47 and oscolivar1 like this.
  17. Jan 15, 2018 at 7:39 PM
    Misplaced Nebraskan
    Zach
    Austin
    Busy night tonight. Got the venison summer sausage cut, vacuum sealed, and wrapped in freezer paper
    Checked on the dry ageing prime ribs. At one week they are darkening nicely. Can't wait to smoke one!
    Then I had 5 pounds each of beef and ground pork butt... mix together and portion to 20 half pound Moink Burgers! Why not?!
  18. Jan 15, 2018 at 7:45 PM
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    Yum.....
  19. Jan 15, 2018 at 7:46 PM
    Misplaced Nebraskan
    Zach
    Austin
    Should be set for a bit :D
    robssol, wilcam47 and scottalot like this.
  20. Jan 15, 2018 at 7:50 PM
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    Huh. After looking very closely I’m fairly certain I see my name on on of those summer sausages.
    Might as well send it on over :D
