Food Smokers and Smoking Tips/Tricks/Techniques
Discussion in 'Food Talk' started by Polymerhead, Jul 15, 2012.
  1. Jan 16, 2018 at 5:12 PM
    Aloha Scout
    Aloha Scout Drink beer and smoke your meats
    Misplaced Nebraskan likes this.
  2. Jan 16, 2018 at 5:27 PM
    Misplaced Nebraskan
    Misplaced Nebraskan TTC #007 'First Gen Best Gen'
    Zach
    Austin
    2001 Taco & 16 T4R TPE
    When the time comes I'll let y'all know :thumbsup:
    CurtB, Kanyon71 and Aloha Scout like this.
  3. Jan 16, 2018 at 6:07 PM
    anonemoose
    anonemoose Well-Known Member
    Bill
    Big Pine, Calif
    2015 White TRD Sport V6 DCSB
    Ride-Rites, Everything Weather-Tech Makes Added some 12 volt outlets with relays
    You guys need to learn how to make real tacos al pastor
    https://www.mexicoinmykitchen.com/2017/05/tacos-al-pastor.html
    and the salsa to top it off with
    Taqueria Style Salsa Recipe
    It’s the time of the year when many will use their barbecue grills almost every weekend if possible. For these days when you’re grilling your meat or chicken, warm up some tortillas alongside the meat to enjoy your grilling feast by making some tacos, and top it off with one of the most famous salsas in Central Mexico, one that’s sought after in many “Taquerias” for those who like to have a good, spicy, tasteful salsa. A good taco has to have a really good salsa to go along.
    This salsa traditionally has Chiles de Arbol, tomatoes, tomatillos, garlic, onion and water. This is a very spicy salsa, but you can adjust the spiciness to fit your own taste by reducing the amount of Arbol peppers. This salsa goes well with Tacos al pastor. Most Taquerias in Mexico City that sell Tacos al Pastor offer this salsa to top your tacos with. Some people know this salsa as Salsa de Chile de Arbol and others as Salsa Taquera.
    Ingredients
    Makes 32 ounces fills a ketchup squeeze bottle nicely.
    NOTES:
    I personally like this salsa when the tomatoes and tomatillos are pealed - broiler, hot water or blow torch method.
    • The taste varies depending on the size of the tomatillos you buy – small are tart while larger are mellower
    • If you want your salsa in a dark red color use more tomatoes than tomatillos
    • Arbol peppers are spicier than other dry peppers. If you prefer less heat in your salsa remove some of the seeds from peppers.
    • Smoke with mesquite until they are done, then run thru a blender.
  4. Jan 16, 2018 at 6:50 PM
    Misplaced Nebraskan
    Zach
    Austin
    Consider it added to the list!
    Aloha Scout and wilcam47 like this.
  5. Jan 16, 2018 at 7:11 PM
    horstuff
    horstuff Re-member
    PNW
    2015 Base 2.7 Access Cab 4x4 5 sp
    Synergy001 and wilcam47 like this.
  6. Jan 16, 2018 at 7:48 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Totally had a brain dump, Ive been working with some walnut and cherry, working my way to a new cutting board and using the planer. I have a big pile of shavings and rather than throw it out I figured Id just try to use it in the smoker!:facepalm:Should be an ok mix huh?
    Kanyon71, Cold Iron and Kolunatic like this.
  7. Jan 16, 2018 at 8:15 PM
    horstuff
    horstuff Re-member
    PNW
    Let us know :)
  8. Jan 17, 2018 at 4:39 AM
    Cold Iron
    Cold Iron Well-Known Member
    Mn.
    2013 AC T|X Baja
    Walnut is a pretty powerful wood to smoke with had a lot of it around growing up, American black walnut. But yes it should be fine unless you fumed the cherry with ammonia first or have glue from glue up in the shavings but sounds like you aren't at that part yet. Interesting I've been thinking of making another cutting board and new knife block with laminated walnut and cherry, always loved the look. You have to post pictures when your done!
    wilcam47[QUOTED] likes this.
  9. Jan 17, 2018 at 6:04 AM
    Kanyon71
    Kanyon71 Well-Known Member
    MI
    Sounds good to me. I will be on the lookout for the thread. :)
  10. Jan 17, 2018 at 8:57 AM
    wilcam47
    Will
    Bourbon state
    Im doing an end grain cutting board, theres a little bit of wood glue in there but not a lot, Maybe not a good idea to use that if its toxic smoke. I had enough pieces for about half a cutting board so I have to make another laminate to try to match it to the other pieces, then square everything up and hopefully glue it together soon. My goal is something similar to this, but I dont know how well it will come out...Im having issues with my fence on my table saw.
  11. Jan 17, 2018 at 10:15 AM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    Smoked beef cheek (cabeza) in green chili verde
    Also made a pizza on the BGE. Got temps up to 650. Cheated with pre-made crust though.
    grdgz97, la0d0g, Synergy001 and 8 others like this.
  12. Jan 17, 2018 at 4:57 PM
    wilcam47
    Will
    Bourbon state
    The chips I had for lunch are no match for these pics ;)
  13. Jan 17, 2018 at 5:01 PM
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    You had chips? I had a freaking tuna pouch....
  14. Jan 17, 2018 at 5:12 PM
    wilcam47
    Will
    Bourbon state
    seeing the pics of a fresh pizza just made my stomach growl and try to eat itself;)
  15. Jan 17, 2018 at 5:30 PM
    t4daddy
    North Alabama
    I started to not even check in on this thread tonight, for that very reason.
    Cold Iron and wilcam47[QUOTED] like this.
  16. Jan 17, 2018 at 5:31 PM
    bvbull200
    bvbull200 Well-Known Member
    Bryan
    DFW, Texas
    2013 DCSB SR5 Prerunner Texas Edition
    Fresh wiper fluid
    :anonymous:
  17. Jan 17, 2018 at 5:35 PM
    bvbull200
    Bryan
    DFW, Texas
    Fresh wiper fluid
    In for this!
  18. Jan 18, 2018 at 3:27 AM
    PerazziMx14
    PerazziMx14 I'm fat but identify as skinny, I'm Trans-slender
    Close to 39.9609243°N, -77.5763777°W
    Jowls have been cured, rinsed, sugared, rested and are now hanging in the garage to air dry. Will start them on smoke later today or tomorrow.
  19. Jan 18, 2018 at 7:37 AM
    Chrisf06
    Chrisf06 Well-Known Member
    Bogart, Georgia
    2014 MGM Tacoma DC TRD Off Road
    It got cold here the last few days, but i had some tenderloins and was hungry... Don't mind the felt ring seal hanging, that happened in the 20 minute ordeal that was me trying to get the BGE open because it was frozen shut. Looks like I'm in the market for a new seal.
  20. Jan 18, 2018 at 8:10 AM
    PerazziMx14
    Next time its frozen shut either stick a hair dryer in the bottom vent for 5 or 10 minutes or you can drop in a lighted sawdust wax block or a few piece of lighted lump.
    scottalot likes this.
