Food Smokers and Smoking Tips/Tricks/Techniques
Discussion in 'Food Talk' started by Polymerhead, Jul 15, 2012.
  1. Jan 18, 2018 at 8:15 AM
    Chrisf06
    Chrisf06 Well-Known Member
    Bogart, Georgia
    2014 MGM Tacoma DC TRD Off Road
    Yeah, thats a good idea... I hit the seal with a hairdryer for a while, and then with my lump lighter magic wand whatever thing and that didn't work, ended up carefully getting a small pry bar in between the seals on the front, but that one side stuck a bit and peeled. I may just find some adhesive and secure it back, its still in fine shape.
    scottalot and wilcam47 like this.
  2. Jan 18, 2018 at 8:29 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    if its still in one piece should be able to glue it back. Just some kind of food safe epoxy or sealant.
    scottalot likes this.
  3. Jan 18, 2018 at 8:37 AM
    Chrisf06
    Bogart, Georgia
    wilcam47 and scottalot like this.
  4. Jan 18, 2018 at 9:00 AM
    Cold Iron
    Cold Iron Well-Known Member
    Mn.
    2013 AC T|X Baja
    Personally prefer the food grade (and safe) RTV Although honestly don't think it will hurt using what you are using. There is some debate over the food safe aspect. It is between the metal and felt and not exposed so I don't feel it is a hazard. But just in case use food grade RTV. Permatex makes good stuff that is what we used in the Engine room of ships on flanges that don't take a silver seal or flex gasket.
    I put seals on all my charcoal burners. If you don't keep them covered the snow melts on top and can run down inside and then freezes and sticks to the felt. That is why they come off. And why I keep mine covered in the winter.
    The gasser just throw the cover over the top because I only use the side table to sit the chimney on when it is hot after dumping.
    Been a week since I've grilled has been below zero for most of the last 3 weeks. In the 20's now and supposed to hit 30 this weekend. Time to shovel the deck off and free the grills and smoker.
    And my banana ketchup, cane vinegar and Calamansi should be here today :anonymous: Time to run to Costco and get the meat.
    RickS and wilcam47 like this.
  5. Jan 18, 2018 at 9:04 AM
    PerazziMx14
    PerazziMx14 I'm fat but identify as skinny, I'm Trans-slender
    Close to 39.9609243°N, -77.5763777°W
    3M Super77 is what you want to use. Clean the ceramic with acetone and then spray both surfaces w/ 3M Super77 wait until its tacky and stick the gasket to the ceramic. Close the lid for 24 hours and your done.
    Do not use RTV. The glue only needs to hold the gasket in place not bond it to the ceramic. I replaced my felt gasket with a Nomex one 8 years ago with 3M Super77 as per the directions and the top gasket just came off (because I snagged it) a couple months ago. If I hadn't snagged it, it'd still be in place.
    Another trick is to piece of wax/parchment paper between the lid/base after its cooled down a bit.
    wilcam47 likes this.
  6. Jan 18, 2018 at 9:16 AM
    Chrisf06
    Bogart, Georgia
    Thanks for the tips guys! We aren't used to much snow down here so its not a common problem. The cover would have been on it except I cooked a few nights ago and it wasn't cooled off enough to put the cover on before i went to bed, and woke up to snow!
    Cold Iron and wilcam47 like this.
  7. Jan 18, 2018 at 9:18 AM
    PerazziMx14
    After 7 days in the cure spice mixture I removed from the zip top bag rinsed w/ cold water to get off the bulk of the spices then vac packed. Then into the Sous Vide bath at 134* for about 17hrs. Removed from SV put into ice water bath to rapidly cool then opened the bag (smelled great) removed the "corned beef" and patted it dry with paper towels. Then a dusting of onion powder, granulated garlic and a heavy dose of black pepper. Wrapped in plastic wrap and put in the fridge to "firm up" and until I have time to get it over some smoke later tonight or tomorrow.
  8. Jan 18, 2018 at 9:22 AM
    Kanyon71
    Kanyon71 Well-Known Member
    MI
    My smoker has lived it's life to date in the garage so far, which has solved all these issues for me. Now if it would only not be stupid cold and snowy I would go out and smoke some meat. :)
  9. Jan 18, 2018 at 9:56 AM
    Aloha Scout
    Aloha Scout Drink beer and smoke your meats
    I almost feel bad for y’all who are freezing right now. I’m not sure if I’d prefer snow over rust. Here in Hawaii, any bare metal part rusts. Never ending battle
    Kremtok and scottalot like this.
  10. Jan 18, 2018 at 10:00 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Where ever you live, something sucks. Just have to figure out what sucks worse to you and go where it's not. :D
  11. Jan 18, 2018 at 10:19 AM
    wilcam47
    Will
    Bourbon state
    True. [​IMG]
  12. Jan 18, 2018 at 10:33 AM
    Kanyon71
    MI
    I lived in FL for 18 years and hopefully soon will be back there.
    Rusting grill sucks less than face freezing and falling off while trying to smoke a brisket. :rofl:
  13. Jan 18, 2018 at 11:30 AM
    truchador
    truchador Well-Known Member
    Otto
    WV
    15 DC OR
    weathertech, seat covers, scratches
    Cold =salty roads =rust lol
    So don’t be too jealous
    Cold Iron and scottalot like this.
  14. Jan 18, 2018 at 1:23 PM
    wilcam47
    Will
    Bourbon state
    zombie land. If you havent seen it;)
    scottalot[QUOTED] likes this.
  15. Jan 18, 2018 at 1:27 PM
    Iamraiderpower
    Iamraiderpower Well-Known Member
    :D
    uurx, scottalot and wilcam47[QUOTED] like this.
  16. Jan 18, 2018 at 1:49 PM
    Cold Iron
    Mn.
    2013 AC T|X Baja
    It's all mind over matter. It doesn't matter if you don't mind.
    truchador, "OldManTan" and scottalot like this.
  17. Jan 18, 2018 at 3:47 PM
    RickS
    RickS New Old Stock
    Rick
    DFW'ish, Texas
    '22 Tundra Limited
    Bobbles and trinkets
    Just noticed Nova laying behind the Jumbo Joe.
    Cold Iron[QUOTED] likes this.
  18. Jan 19, 2018 at 7:13 AM
    Kremtok
    Kremtok Well-Known Member
    Gary
    Houston, TX
    2021 Tesla Model 3 Long Range AWD
    2018 Triumph Street Triple RS
    There’s a brisket on the Traeger now with plenty of Pitfaced rub from our very own @bvbull200 . I followed the brisket guide but it cooked way faster than expected. Put it on around 2330 at 275 and woke up at 0500 to 183 internal temp. Wrapped it and put it back on. Pulling it off in a bit, but I think it may be over cooked already. It’s supposed to be lunch for the guys at work. It’s 0613 now...
    I also think I may have over trimmed it. Turned out way thinner than I expected.
    Yet another thing I hated about Hawaii...the only thing that didn’t rust there was my H&K USP.
  19. Jan 19, 2018 at 7:16 AM
    Kanyon71
    MI
    What makes you think it's over cooked? What temp is it at? Nice thing is you can pull it, wrap it and toss it in a nice cooler and let it sit for hours, you will lose some of the bark firmness but that really doesn't bother me.
  20. Jan 19, 2018 at 7:28 AM
    Kremtok
    Gary
    Houston, TX
    I just think that I overtrimmed it and that there’s no way it can be tender meat. I guess it’s hard to tell with the bark on the outside, but the internal temp was just over 200 when I pulled it and put it in the cooler. I warmed the cooler with hot water from the bath tub, too, because dummy me left the cooler in the garage last night. The unheated garage. In Alaska. In January.
    Anyhow, so long as it doesn’t get cold before around 1100, we’ll have food for lunch. Worst case scenario is that I do this all over again in a few weeks. What I really need to learn is how to trim the meat properly. Anyone feel like visiting Homer and barbecueing every day for a week or two?
    hemitruk, wilcam47 and bvbull200 like this.
