Food Smokers and Smoking Tips/Tricks/Techniques
Discussion in 'Food Talk' started by Polymerhead, Jul 15, 2012.
  1. Jan 19, 2018 at 7:43 AM
    Mateo74
    Mateo74 Well-Known Member
    Matthew
    NWI
    16' Tacoma Sr5 Blazing blue pearl
    I think you will be fine, Let us know how it is.
    Kremtok and wilcam47 like this.
  2. Jan 19, 2018 at 7:44 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    I think you will be ok.
    Kremtok[QUOTED] likes this.
  3. Jan 19, 2018 at 7:46 AM
    Cold Iron
    Cold Iron Well-Known Member
    Mn.
    2013 AC T|X Baja
    If the Salmon are running I might be easily talked into it :D
    But I agree think you will be fine.
    Kremtok[QUOTED] and wilcam47 like this.
  4. Jan 19, 2018 at 7:49 AM
    Kremtok
    Kremtok Well-Known Member
    Gary
    Houston, TX
    2021 Tesla Model 3 Long Range AWD
    2018 Triumph Street Triple RS
    Thanks for the reassurances, folks. I’ll be sure to share the results.
    Early July is prime time for reds...we slayed them last year. Up here its not fishing, its catching.
  5. Jan 19, 2018 at 8:01 AM
    Kanyon71
    Kanyon71 Well-Known Member
    MI
    Ya I think you will be good to go. I'm sure you're friends at work won't mind it again in a few days let alone a few weeks. :rofl:
    I would love to visit Alaska at some point, was supposed to do a job there many years ago for the company I worked for but it got cancelled. Was sort of bummed.
  6. Jan 19, 2018 at 8:54 AM
    12thmanhawkfan
    12thmanhawkfan Well-Known Member
    Robby
    Bellingham, WA
    Access Cab 6-speed
    It's got some Mods
    I'm thinking about smoking a chuck roast this weekend. I've never done one before. Aside from covering it in Pitfaced rub, what do I need to look for? What temp do I pull it off at and how long should I let it rest? I heard it's better to practice on the cheaper chuck roasts before spending the money on a brisket. Thanks in advance!
    wilcam47 and bvbull200 like this.
  7. Jan 19, 2018 at 9:08 AM
    la0d0g
    running for the hills
    For crawling not hauling
    Shitty coolers work too! :p
    wilcam47 and t4daddy like this.
  8. Jan 19, 2018 at 9:44 AM
    Kanyon71
    MI
    Very true, not sure I want to use my old ratty one that smells like fish and I can't get that smell out of though. :rofl:
    wilcam47 and la0d0g[QUOTED] like this.
  9. Jan 19, 2018 at 10:01 AM
    la0d0g
    Haha, totally. The old one I use smells like pork because, well, BBQ!
    Kanyon71[QUOTED] likes this.
  10. Jan 19, 2018 at 10:14 AM
    hemitruk
    hemitruk Old man , young boi truk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    i do mine about 300 and have never really probe for tenderness . I just wrap at 160 pull at 200 and leave in cooler minimum 4 hours . Never had a problem .
    Your should come out good.I also save all the juice from wrap pour in bowl and put in freezer till can pull off fat from top . i pour juice over brisket to help keep it moist .Wont get cold by lunch .for me after 4 hours brisket is still hot so no need to worry about it being cold . Your coworkers going to have one good lunch :thumbsup:
    Ackrite and Kremtok[QUOTED] like this.
  11. Jan 19, 2018 at 12:26 PM
    Cold Iron
    Mn.
    2013 AC T|X Baja
    I do it pretty much just like a brisket. @bvbull200 has some pretty good instructions for doing a brisket that will work for a chuckie here I normally go to 203-205° on a chuck roast.
    I like to make chuckie burnt ends out of them:
    It will stall just like a butt and give yourself at least 10 - 12 hours. If you have a WSM then highly recommend using the bottom tray to cook and smoke some carrots, onions and celery in a pan to catch the drippings for the first 4 or 5 hours. Then skimming some juice for Au Jus, take out some carrots as a side then you can make some awesome gravy out of the rest and serve with the roast. Damn it now I'm hungry again.
  12. Jan 19, 2018 at 12:51 PM
    12thmanhawkfan
    Robby
    Bellingham, WA
    Access Cab 6-speed
    It's got some Mods
    Than you sir! Now the debate of if I should turn them into burnt ends or not... These are tough decisions!
    WBF610 and Cold Iron[QUOTED] like this.
  13. Jan 19, 2018 at 12:56 PM
    Ackrite
    Ackrite Well-Known Member
    SoCal
    1985 Toyota Pickup 4x4 single cab
    I over-trim intentionally and have good results. I also do not wrap and let it ride through the stall. As others said, you should be fine.
  14. Jan 19, 2018 at 4:04 PM
    Kremtok
    Gary
    Houston, TX
    In short, my brisket was a disaster.
    It was incredibly tough, but like leather not like tough meat. There was no moisture at all. The thin end of the flat was nearly too hard to cut with my 8” chef’s knife. Mostly it was over cooked, but I think that overtrimming played a role, as well, because the fat would have protected the meat from drying out to the point of turning too hard to cut. This time, people ate all of it. I think they were being polite, but my opinion is that while the flavor was good - especially the rub - eating dry, tough meat is a poor way to live no matter what else it may be.
    Oh well. Like I said, I guess I’ll just have to do it again in a few weeks. Next time I’ll start the cook at the same time, but run it at 225 instead of 275. Hopefully that will be good enough for my inadequate 5-hour period of sleep.
    bvbull200, wilcam47 and truchador like this.
  15. Jan 19, 2018 at 4:07 PM
    Misplaced Nebraskan
    Misplaced Nebraskan TTC #007 'First Gen Best Gen'
    Zach
    Austin
    2001 Taco & 16 T4R TPE
    A trial and error brisket is still brisket. Have had this happen more than once. If it happens, just pull it and mix in some beef broth or sauce and serve on buns. My recovery anyway.
  16. Jan 19, 2018 at 4:08 PM
    horstuff
    horstuff Re-member
    PNW
    2015 Base 2.7 Access Cab 4x4 5 sp
    Wow. I really thought given your description of how it went down that you'd be fine. Interested to hear the brisket pros input on this.
  17. Jan 19, 2018 at 4:26 PM
    wilcam47
    Will
    Bourbon state
    does the traeger have a hot section or is it supposed to be even heating? The outside temp may be a problem. It may have been a lot hotter over the source than what it was set at. If it was trying to compensate it would be too hot, which would make sense it cooked too quick.
  18. Jan 19, 2018 at 4:27 PM
    anonemoose
    anonemoose Well-Known Member
    Bill
    Big Pine, Calif
    2015 White TRD Sport V6 DCSB
    Ride-Rites, Everything Weather-Tech Makes Added some 12 volt outlets with relays
  19. Jan 19, 2018 at 4:39 PM
    Kremtok
    Gary
    Houston, TX
    There’s a metal tray underneath the grates and if you get on the outside edges of that where there’s an air gap between the tray and the grill, those are hot spots. Of course, the brisket was square in the center over the tray, so I don’t think that was it.
    However, I have heard tell that because of the forced air flow through the Traeger, it might be kind of like a convection oven, but I haven’t seen that told through cooking pork butts and ribs. All of my cooking times on those seem to be on par with what folks with other types of smoker use, as well.
    I really do think that I just screwed this one up.
    wilcam47[QUOTED] likes this.
  20. Jan 19, 2018 at 5:02 PM
    wilcam47
    Will
    Bourbon state
    where did you measure the temp at?
