Food Smokers and Smoking Tips/Tricks/Techniques
Discussion in 'Food Talk' started by Polymerhead, Jul 15, 2012.
  1. Mar 18, 2018 at 3:05 PM
    bvbull200
    bvbull200 Well-Known Member
    Bryan
    DFW, Texas
    2013 DCSB SR5 Prerunner Texas Edition
    Fresh wiper fluid
    I'm sure I'm too late to be of much help in this case, but I do often cook brisket in the 275-300* range. It can cut a couple of hours off of your cook time and the results are indistinguishable from cooking at a lower temp. The only drawback is the window for getting it right opens and shuts much faster the higher the temp that you cook at.
    WBF610[QUOTED] and wilcam47 like this.
  2. Mar 18, 2018 at 3:06 PM
    bvbull200
    Bryan
    DFW, Texas
    Fresh wiper fluid
    Whoa! Didn't see this before posting. Nicely done! Looks like you pretty much nailed that one.
    itrsteve[QUOTED] likes this.
  3. Mar 18, 2018 at 3:18 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    looks good!
  4. Mar 18, 2018 at 3:20 PM
    wilcam47
    Will
    Bourbon state
    I do a "quick" brisket @ 250-300 on the smoker for about 3hrs and then wrap/cover in foil, and put in the oven for 3hrs @300 for three hours then let rest for 30minutes before slicing. Bark isnt crispy but still tastes good.
    hemitruk and WBF610[QUOTED] like this.
  5. Mar 18, 2018 at 3:39 PM
    Iamraiderpower
    Iamraiderpower Well-Known Member
    120% agree here. I love cooking mine at 275* ish
  6. Mar 18, 2018 at 3:41 PM
    Iamraiderpower
    Tasting good is all that matters to me
  7. Mar 18, 2018 at 3:53 PM
    Dgibson529
    Dgibson529 Well-Known Member
    Derek
    Westfield, MA
    NE F150s of TW FTW
    Well the brisket came out pretty good! I’d say for my first time it was a win. I didn’t get any pictures but next time I’d like to see a better bark and a little juicier. Seemed as if it was leaning towards the dryer side but still was delicious
    hemitruk, Cold Iron, WBF610 and 2 others like this.
  8. Mar 18, 2018 at 3:55 PM
    Iamraiderpower
    How close to fire were you? Temp? Did you mop it?
    bvbull200 likes this.
  9. Mar 18, 2018 at 3:58 PM
    WBF610
    WBF610 Member well known
    Carey
    Eastern PA
    2016 DC OR
    mats, flaps, and stickers. Extang solid fold 2.0. Mobtown sliders and full skids. AVS vents
    Glad it was good. My first was dry, as a result of it being undercooked.
    Dgibson529[QUOTED] likes this.
  10. Mar 18, 2018 at 4:13 PM
    horstuff
    horstuff Re-member
    PNW
    2015 Base 2.7 Access Cab 4x4 5 sp
    First time doing beef back ribs, so far so good...
    oscolivar1, Kanyon71, TK-422 and 5 others like this.
  11. Mar 18, 2018 at 4:20 PM
    itrsteve
    itrsteve Well-Known Member
    NC
    18 LC/15 GT3
    What’s your guys take on wrapping in either foil or butchers paper? Do you do it at the stall or just while it’s resting.
    I want to find an excuse to try one every weekend with minor corrections to confidently nail it down.
    wilcam47 likes this.
  12. Mar 18, 2018 at 4:22 PM
    Iamraiderpower
    Albeit I’ve never wrapped nor will I ever, if I were to wrap it would be in butchers paper. In my time of seeing and tasting things wrapped in both, the butchers wrapped yielded a crispier taste but if you are hunting for a more moist taste the foil route is way to go
  13. Mar 18, 2018 at 4:24 PM
    wilcam47
    Will
    Bourbon state
    I dont mind foil(helps getting over the stall, aka Texas crutch;) ) , but I did use some pink paper for the last pulled pork. This was the first time I used it so I dont have a good pattern to say anything bad about it. The only difficult thing for me was trying to get a good seal when you are trying to wrap a hot shoulder.
  14. Mar 18, 2018 at 4:42 PM
    PerazziMx14
    PerazziMx14 I'm fat but identify as skinny, I'm Trans-slender
    Close to 39.9609243°N, -77.5763777°W
    • Who say you can't rotisserie on a BGE? $34 for a rotisserie + a 1" x 1" x 1/16th" piece of aluminum angle, small c-clamp and a couple blocks of wood to block the heat and your all set up. A 6+ lb beef clod heart seasoned with Tony Chachere's, kosher salt and lots of black pepper. 6 hours later and what do we have? A Super tender beef that is going to make some killer hot roast beef sandwiches.
    oscolivar1, truchador, TK-422 and 3 others like this.
  15. Mar 18, 2018 at 4:48 PM
    dingo222
    dingo222 Well-Known Member
    Baltimore
    2017 MGM OR DCSB
    That is a cool set up!
  16. Mar 18, 2018 at 4:48 PM
    itrsteve
    NC
    18 LC/15 GT3
    I couldn’t find butchers paper available anywhere local in Raleigh. I planned to have some inhead of time for the next attempt though.
    I want to do one unwrapped and one wrapped at the stall then compare moisture and bark at each.
  17. Mar 18, 2018 at 4:50 PM
    Iamraiderpower
    Amazon has it on the cheap
  18. Mar 18, 2018 at 4:52 PM
    wilcam47
    Will
    Bourbon state
    listed below $19.97 for 200'
  19. Mar 18, 2018 at 5:38 PM
    Dgibson529
    Derek
    Westfield, MA
    NE F150s of TW FTW
    Stayed right around 250* most of the day. +/- here and there. And it was a decent distance from the fire since it’s a side mounted fire box. Also did not mop it with anything
    Didn’t realize it could be dry from undercooking it
    WBF610[QUOTED] likes this.
  20. Mar 18, 2018 at 5:49 PM
    Iamraiderpower
    My brother mop that bad boy every 1-1.5 hours
