Food Smokers and Smoking Tips/Tricks/Techniques
Discussion in 'Food Talk' started by Polymerhead, Jul 15, 2012.
  1. Apr 15, 2018 at 9:45 AM
    gpb
    gpb Well-Known Member
    Atlanta
    2017 White DCSB TRDOR 4x4
    Conveniently, Costco sells those too. :D
  2. Apr 15, 2018 at 10:11 AM
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    And old wore out bladder. :(
  3. Apr 15, 2018 at 10:48 AM
    Misplaced Nebraskan
    Misplaced Nebraskan TTC #007 'First Gen Best Gen'
    Zach
    Austin
    2001 Taco & 16 T4R TPE
    Synergy001 likes this.
  4. Apr 15, 2018 at 11:27 AM
    bvbull200
    bvbull200 Well-Known Member
    Bryan
    DFW, Texas
    2013 DCSB SR5 Prerunner Texas Edition
    Fresh wiper fluid
    It wasn't quite as hot or quite as fast as I wanted, but I got it done.
    To take it from the top:
    1. Trimmed the night before. Not aggressive, but I got a lot of the 'big' stuff removed. For the fat cap, where I didn't spend too much time getting the trim just right, I scored it, careful not to get down in to the meat.
    2. Then I injected it with Butcher's BBQ Prime Dust. More on that in response to @wilcam47 's post, but it needs to be injected 12 hours ahead of time, per the instructions.
    3. I also rubbed it the night before. I don't think it matters much if you put the rub on overnight or just before, but I usually prefer to do it about 30 minutes prior to putting it on the smoker. That said, if I am trying to buy myself some time, I'll do it the night before. Without getting too far in to the details, the rub is a pepper & salt base (pepper being the leader of the two), with some other spices added (garlic, onion, and beyond :D).
    4. Morning of, the UDS was already loaded with charcoal, peach wood, oak wood from a spent bourbon barrel, and a little mesquite. Target temp was 300*, but with the load and the crazy wind, I got to 275* and called it good.
    5. Cooked at ~275* for about 5 1/2 hours (?) unwrapped. As I was working on getting the pork belly in and such I wrapped the briskets in butcher paper. Sidebar: The butcher paper wrap does affect the bark some, but doesn't kill it altogether and the moisture retained nearer the surface of the meat is undeniable.
    6. Cooked at ~275* for another 2 hours for one and 2 1/2 hours for the other. These were both about 13 lb briskets and similar thickness, they just didn't have similar plans for when they'd be done :laugh:. Internal temps, I'm not really sure, but they were buttery smooth in the thick of the flat. Probably just shy of 200*, though? For both of them, when I pulled, I wrapped in foil, then threw back in the smoker for 5-10 minutes to get some heat to carry to the Cambro as I was looking at about a 3 hour rest and the butcher paper doesn't hold as much heat in, so they were starting as if they were partially vented.
    7. 3 hours of rest, slice against the grain, and boom!
    Thanks! It really turned out good. I love cooking for events, but sometimes hate watching all that good food go on someone else's plate :laugh:.
    I do stand by the brisket guide in my sig for an excellent, easy to follow, right-for-all-levels-of-experience option, but my cook method has morphed slightly. I am a pretty big proponent of the butcher paper wrap, now.
    I'm starting to change my thoughts on the injection, too. In the past, I only really used it for competition, but never really bothered for personal cooks or cooking for events. I won't say it is necessary for an excellent brisket at all, but I'm less on the fence about whether it is even worth using in the first place. That Prime Dust just tastes like beef. It isn't any further flavoring or anything (unlike, say, the poultry injection they sell), so the meat just becomes a beef explosion with the bark carrying your preferred tweak/enhancement to the pure beef flavor. I mix that injection to a level that is slightly more diluted than the instructions call for (2 1/4 scoops vs 3 full scoops).
    truchador, nDub, CurtB and 2 others like this.
  5. Apr 15, 2018 at 11:41 AM
    Misplaced Nebraskan
    Zach
    Austin
    Very nice. I've been contemplating that prime dust. May have to try it one
    bvbull200[QUOTED] likes this.
  6. Apr 15, 2018 at 1:08 PM
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    A question. I don't have any butcher paper. Will parchment work?
  7. Apr 15, 2018 at 1:14 PM
    Wolftaco0503
    Wolftaco0503 Well-Known Member
    Adam
    Chicago
    2013 Super White LONG BED TRD SPORT 4x4
    Maglite mod Bottle Opener in bed Weathertech Mats Front & Back
    How many of you guys use pellet grills/smoker and how many of you use traditional Charcoal Either lump or kingsford type?
    Cuffs and bvbull200 like this.
  8. Apr 15, 2018 at 1:16 PM
    bvbull200
    Bryan
    DFW, Texas
    Fresh wiper fluid
    If it is unwaxed parchment paper, it should be fine, but parchment paper doesn't breath as well as butcher paper. My hunch is that it would be more akin to using aluminum foil than using butcher paper.
    I'll find you a link, but you can get the stuff on Amazon. Not too expensive and a roll lasts for a LOT of cooks!
  9. Apr 15, 2018 at 1:16 PM
    bvbull200
    Bryan
    DFW, Texas
    Fresh wiper fluid
    Kingsford guy, here!
  10. Apr 15, 2018 at 1:21 PM
    Cold Iron
    Cold Iron Well-Known Member
    Mn.
    2013 AC T|X Baja
  11. Apr 15, 2018 at 1:57 PM
    Sprocket
    Sprocket Well-Known Member
    OK Joe's Offset, Reverse Flow for $250 - Would be my first stick burner.
    Yes because...
    No because...
    Thank you
  12. Apr 15, 2018 at 2:08 PM
    Wolftaco0503
    Adam
    Chicago
    So you enjoy the taste of glue?
  13. Apr 15, 2018 at 2:31 PM
    gpb
    Atlanta
    Maybe I'm wrong, but I thought parchment paper was silicone impregnated, which gives the non-stick characteristic. I don't think it'd work at all the same and would avoid using it to wrap.
    Looks like butcher paper is easily available on Amazon.
  14. Apr 15, 2018 at 2:34 PM
    bvbull200
    Bryan
    DFW, Texas
    Fresh wiper fluid
    I absolutely love it. When I do pork shoulder, I cover it in Elmer's glue to make the BBQ rub bind better.
  15. Apr 15, 2018 at 2:35 PM
    PerazziMx14
    PerazziMx14 I'm fat but identify as skinny, I'm Trans-slender
    Close to 39.9609243°N, -77.5763777°W
    Pancetta has been in the curing chamber since 3/23/18 (23 days). I wanted to have a look to see if any bad molds were developing so I unwrapped it to have a look and there was nothing negative going on. Since it was unwrapped I did wipe down with vinegar and then wrapped in fresh cheese cloth and trussed. Its now back in the curing chamber.
    Freshly unwrapped and modeling for the camera:
    View of the top side as its hanged in the curing chamber
    View off the seam/overlap where the belly was rolled up originally
    View of the bottom side as its hanged in the chamber. I can't wait to cut into this and see the meat/fat swirl pattern.
    It looks great and smells even better and loosing weight nicely:
    3/24/18 = 1774g
    4/1/18 = 1630g
    4/7/18 = 1579g
    4/12/18 =1547g
    4/15/18 =1530g
    Target weight is 1,068 grams or a 40% reduction in weight from when originally hanged in the curing chamber.
    Synergy001, truchador and scottalot like this.
  16. Apr 15, 2018 at 2:51 PM
    Wolftaco0503
    Adam
    Chicago
    Good cause your eating in the Kingsford
    scottalot likes this.
  17. Apr 15, 2018 at 2:52 PM
    PerazziMx14
    I order my
    I just got my second 200lb load of lump for 2018.
  18. Apr 15, 2018 at 3:03 PM
    Cold Iron
    Mn.
    2013 AC T|X Baja
    Oh that's right you read it on the internet. Therefore it is true....
  19. Apr 15, 2018 at 3:04 PM
    grdgz97
    grdgz97 Well-Known Member
    Georgetown, TX
    2015 TRD Sport DCSB
    You know what glue tastes like?? o_O
  20. Apr 15, 2018 at 3:05 PM
    grdgz97
    Georgetown, TX
    2015 TRD Sport DCSB
    Isn't everything on the 'net true??:anonymous:
