Foodies BS Thread.
Discussion in 'Food Talk' started by T4RFTMFW, Apr 15, 2011.
  1. May 16, 2011 at 3:07 PM
    #61
    woodygg
    woodygg Well-Known Member
    So Cal
    04 DC Tacoma 4x4
    I'm sure eventually, but not with the times we're discussing and not if you keep the proper amount of liquid. I use the high setting on my crockpot... turns out so tender it just falls apart.
  2. May 16, 2011 at 3:44 PM
    #62
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I went with a buddies advice and used one condensed can of cream of mushroom soup and about 1.5 cups of beef stock. I mean there was plenty of liquid to go around.
    Hmmm....maybe I can try it on high next time. How do you cook that? Just cut the time in half since its on the high setting?
  3. May 16, 2011 at 3:48 PM
    #63
    Rev720
    Rev720 Well-Known Member
    Alex
    The Woodlands TX
    2010 SR5 4x4 White
    I'm hungry!!!!!!!!!!!!!!!!!!!!!!!!!
  4. May 17, 2011 at 7:43 AM
    #64
    woodygg
    So Cal
    04 DC Tacoma 4x4
    the roast i used was around 2 pounds... cooked it for around 4 hours. it had a lot of liquid - up to about the top of the meat, which the recipe called for. usually if it's tough means it's undercooked - when we're discussing braising anyway.
  5. May 17, 2011 at 8:10 AM
    #65
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Oh okay got yah. Yeah it seems like whenever I make a roast, there is a good amount of liquid after its cooked but I'm assuming thats normal.
  6. May 17, 2011 at 8:35 AM
    #66
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    I wouldn't cover your meat with water, I don't even touch my meat to the water (once I stop laughing I'll continue on)
    Is your meat tough as in like a raw chuck (still one piece of meat) or tough and dry because of over cooking? I'm guessing the first one if your meat is not dried and shriveled looking, which means more time. Another note is I'm not sure, but I would think that if you add the cream soup you should probably add alittle more water/broth because the cream will thicken/dry quicker and overall not allow your roast to braise.
  7. May 17, 2011 at 8:41 AM
    #67
    woodygg
    So Cal
    04 DC Tacoma 4x4
    You'll need to explain more - as the definition of braising is cooking at a lower temperature, for a long time IN LIQUID. So not sure how your meat doesn't touch any water (or do you mean water versus other types of liquid).
  8. May 17, 2011 at 9:32 AM
    #68
    jjew18
    Alliance Airport
    05 PreRunner SR5
    Actually I would check your defintion of braising, use too much liquids and you are making a stew. The moisture in the steam when you are using a crock-pot braises the meat.
    To clarify how I cook, look back a few pages for how I cook my raost, but in short, you place your vegetables in the bottom of your pan which are sittin gin water, your meat is on top of your vegetables out of the water. Hence you are using dry heat and moisture to cook your roast.
  9. May 17, 2011 at 12:23 PM
    #69
    jjew18
    Alliance Airport
    05 PreRunner SR5
    I know it sounds bad, but braising is using a combination of dry and moist heats.
  10. May 17, 2011 at 12:33 PM
    #70
    woodygg
    So Cal
    04 DC Tacoma 4x4
    the amount of liquid in braising can vary quite a bit, by definition. thanks for clarifying. almost every recipe i've ever seen (in fact, everyone i can remember) has you bring the liquid up about halfway to the top of the meat. your method would do really well in a pressure cooker, where you don't use, nor need much liquid.
    that being said, there are many ways to end up with a great dish, however if i were instructing someone new that was having problems getting it to come out how they want, i'd probably start with a more traditional approach, get that right, and then tweak or try it other ways. that was why i threw out that receipe, first because it was probably one of the very best i've ever had (really, i'd tell you otherwise, i'm my own worst critic) and it was easy.
  11. May 18, 2011 at 7:16 PM
    #71
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    slow braised turkey leg, turned into chili/mole enchiladas with a fried egg on top!! flay can kiss my butt. :)
  12. May 18, 2011 at 8:02 PM
    #72
    aficianado
    back to bone stock.
    only other picture i took..hehe. the lettuce added a coolness to the spicey sauce.
  13. May 19, 2011 at 4:17 AM
    #73
    FoxySandChick
    FoxySandChick Well-Known Member
    Kristin
    Henderson, NV
    07 DC 4x4 Base model V6 Impulse Red Pearl
    De-badged, limo tint, black wet okole's, weathertechs, extra d-rings, TSB bilsteins
  14. May 19, 2011 at 4:29 AM
    #74
    FoxySandChick
    Kristin
    Henderson, NV
  15. May 19, 2011 at 5:50 AM
    #75
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Those nuggets look killer!!:eek:
    This looks like a pretty simple recipe Kristin, I'll have to try this one too!;)
  16. May 20, 2011 at 12:14 AM
    #76
    FoxySandChick
    Kristin
    Henderson, NV
    Those nuggets were simple to make and were very yummy!! I basically followed the recipe, but added some more italian seasoning for extra flavor and skipped the added salt. ;)
    A lot of the recipes on that website are pretty quick and simple, so I've printed out a bunch of them to try and you know I don't like to cook lol but these got me motivated to try some new things! :D
  17. May 20, 2011 at 9:57 AM
    #77
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Yeah I'll have to that nugget recipe this weekend. I'll let you guys know how it turns out.;)
  18. May 20, 2011 at 10:09 AM
    #78
    TacoMatt02
    TacoMatt02 Well-Known Member
    South Carolina
    02 sr5 double cab
    i cook my bacon in the oven with brown sugar and cayenne on top, comes out caramelized and the most bomb ass bacon ever.
  19. May 20, 2011 at 10:13 AM
    #79
    TacoMatt02
    South Carolina
    02 sr5 double cab
    haha yes, watch all there shit
  20. May 20, 2011 at 10:13 AM
    #80
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Cant go wrong with garlic salt!!:D I really like Lawry's garlic salt the best!!
