Foodies BS Thread.
Discussion in 'Food Talk' started by T4RFTMFW, Apr 15, 2011.
  1. Oct 6, 2011 at 3:32 PM
    #1121
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Haha, I think I'd rather be in heat!! But I know what you mean. I was born and raised in So Cali so I got spoiled with its weather. Now I live in a place with cold friggin winters and hat friggin summers!!! Spring and Fall only seem to last like 1 month out here!!!:mad:
  2. Oct 6, 2011 at 3:34 PM
    #1122
    futuretacoowner
    futuretacoowner Well-Known Member
    Andrew
    Canada
    02 2.7L xtra cab
    Over here its about the same quality as the butcher, and cheaper also.
  3. Oct 6, 2011 at 3:41 PM
    #1123
    woodygg
    woodygg Well-Known Member
    So Cal
    04 DC Tacoma 4x4
    If the inside of the steak is cold, by the time you get the inside warm enough, the outside will be overdone. So essentially it cooks it much more evenly.
  4. Oct 6, 2011 at 3:47 PM
    #1124
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Ah okay makes sense. Now does tenderness become a factor.
  5. Oct 6, 2011 at 3:49 PM
    #1125
    woodygg
    So Cal
    04 DC Tacoma 4x4
    Not sure I follow the question regarding tenderness?
  6. Oct 6, 2011 at 3:50 PM
    #1126
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Yeah that didnt sound right, my bad. If you let it get to room temp, is the meat more tender after you cook it then it would be if you cooked it cold?
  7. Oct 6, 2011 at 3:55 PM
    #1127
    futuretacoowner
    Andrew
    Canada
    02 2.7L xtra cab
    I say is, though indirectly. because you are not over cooking it the meat doesn't lose as much of its juices.
  8. Oct 6, 2011 at 3:56 PM
    #1128
    woodygg
    So Cal
    04 DC Tacoma 4x4
    Hmmm... well, it could tend to be in that it cooked faster and didn't need to sit in the heat as long (moreso on the outside) - but I've never heard or read anything that indicated it affects the tenderness.
  9. Oct 6, 2011 at 3:58 PM
    #1129
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Oh okay got yah. Thanks, I was just curious.
  10. Oct 6, 2011 at 4:06 PM
    #1130
    woodygg
    So Cal
    04 DC Tacoma 4x4
    I've heard from multiple sources that the ultimate steak is cooked using the sous vide method. Read this article... it's really interesting and describes it
    http://www.mensjournal.com/the-mad-scientist-reinventing-food
    MJ: As a scientist, what do you find most surprising about traditional cooking methods?
    NM: People believing that searing meat seals the juices in — that kind of thing. There’s a whole belief system at cooking schools: Just pick a topic and someone will say, “Thou must never do this!” and another will say, “Thou shalt always do this!” There are people who believe you should turn a steak once, others many times. But what you’re really trying to do is cook the meat to about 125 or 130 degrees over a surface that’s 300 or 400 degrees. If you really want to cook it properly, you should cook it slowly, sous-vide, at low heat so it won’t overcook, and then use high heat — not for sealing in juices but because that makes it look pretty and taste good — with an oxyacetylene blowtorch hot enough to melt pans.
  11. Oct 6, 2011 at 4:20 PM
    #1131
    futuretacoowner
    Andrew
    Canada
    02 2.7L xtra cab
    gonna try that sometime. if only i could remember where i put my vacuum sealer
  12. Oct 6, 2011 at 4:23 PM
    #1132
    toughtaco
    toughtaco Well-Known Member
    05 tacoma dbl cab short bed
    TRD CAI, MBRP dual exhaust, PIAA headlights and driving lights, 5% limo tint, 3 inch Skyjacker lift , AFE throttle body spacer, 285/70/17 BF Goodright AT TA KO, Grillcraft MX with PIAA's behind the grill, anytime fog light mod, reverse camera anytime mod, and PIAA fog lights on the rear bumper anytime mod light bar behind back window with truck lights for reverse assistance, Optima Red Top Battery, Onza 3x5" LEd reverse lights attached to light bar behind cab
    Man I have gone since tuesday and lots of postings....... going to have to get caught up on quoting on some of these posts.... Heres dinner, sorry for blurry pics...
    Pulled pork BBQ sandwich, cooked all day in crock pot then pulled (yes by hand). Fresh cucuzza..... so tasty
    Thats a sandwich
  13. Oct 6, 2011 at 4:30 PM
    #1133
    futuretacoowner
    Andrew
    Canada
    02 2.7L xtra cab
    looks great!!!
  14. Oct 6, 2011 at 4:31 PM
    #1134
    toughtaco
    That steak looks serious.,.... good job!!!
    Good looking ka bobs
    If you were to box that and deliver it I bet you could get $20.00 at least for that pie....
    Good looking smoker, thats a good job seasoning the meat before smoking it too!!!
  15. Oct 6, 2011 at 4:40 PM
    #1135
    toughtaco
    Never made what in a crock pot? If you meant the pulled pork, I did it in the crock pot bc we have been running around crazy between emergency room and dr appt so we had no time. Before we left for a dr app I threw a pork roast in the crock pot, then pulled it when we got home.
  16. Oct 7, 2011 at 1:52 PM
    #1136
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    For the veg heads....
  17. Oct 7, 2011 at 1:56 PM
    #1137
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Always lovin some veggies! ^^^
  18. Oct 7, 2011 at 4:10 PM
    #1138
    LUSETACO
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    CHEEEEEEZ
  19. Oct 7, 2011 at 7:52 PM
    #1139
    toughtaco
    ^^^ Nice presentation...good job with the tomatoes....
  20. Oct 8, 2011 at 10:37 AM
    #1140
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    X2
