FOOK YOU? NO, FOOK ME!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tgear.shead, Mar 13, 2017.
  1. Mar 14, 2017 at 8:17 AM
    #61
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    Both of mine did.
    MTopp likes this.
  2. Mar 14, 2017 at 8:18 AM
    #62
    tgear.shead
    tgear.shead [OP] Well-Known Member
    Then you must be talking about something else, or had a different year or version of it.
  3. Mar 14, 2017 at 8:18 AM
    #63
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Guys guys guys, he has owned THREE WHOLE TRUCKS. He is clearly qualified enough to know that no other truck on the road has axle hop. Sheesh guys.
    Normantaco, rlx02, PvilleJohn and 3 others like this.
  4. Mar 14, 2017 at 8:19 AM
    #64
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Everyone: Here is an explanation of how things work, ways to address the issue you're experiencing, and supporting evidence that it's a common problem in a leaf-sprung suspension setup.
    OP: BUT MY ANECDOTE!!
    rlx02, PvilleJohn, MTopp and 3 others like this.
  5. Mar 14, 2017 at 8:20 AM
    #65
    stevotivo12
    stevotivo12 Well-Known Member
    Stephen
    2016 Silver Tacoma TRD Sport MT
    Front hellwig sway bar,All pro sway bar end links, Fox 2.5 Resi Coilovers and Shocks, Fox 2.5 Hydraulic Bumpstops, Budbuilt Traction bar, Total Chaos UCAs w/ heim joints, Icon AAL, AFE Power Intake with dynamic scoop, URD spec U, URD short shifter, Flossy weighted shift knob, michelin tires, black badges, black tailgate letters, black grill with custom Diaz Fab Devil horn yota logo, retrofit/morimoto HID conversion, red interior LED lights, Pioneer head unit, kenwood excelon door speakers, 2 10" pioneer subs,
    This devolved quickly... OP your wheel hop solution wont work. It might help you with axle wrap a little tiny bit if youre launching so hard youre bending your leaf springs into an S, but if youre doing that then honestly your clutch is the weak point you should be worried about. If you dont drive a manual then you really are just a douche. The brace might limit axle WRAP, but as others have stated the wheel hop will still be there and instead of the leaf springs absorbing all of this force it will be the rear frame directly, which may last for a while but eventually will bend and make everything shitty for you.
    You have two options: make your leaf springs significantly stiffer (dont do that though, everything will suck like the ride quality, except for the amount of wheel hop),
    or you can add a torque arm as others have said, which wont limit articulation as much as stiff springs but will limit travel a little bit. Best solution would be a budbuilt traction bar or similar trac bar setup mounted to the diff housing, but then you have the issues with longevity if you use it for offroading regularly, but without any limit on articulation. Its all in what you can live with.
    MTopp likes this.
  6. Mar 14, 2017 at 8:21 AM
    #66
    mjp2
    NJ
    He won't read beyond that statement. Expect an "OFF TOPIC!!" post soon.
    Tatts521, PvilleJohn, MTopp and 4 others like this.
  7. Mar 14, 2017 at 8:22 AM
    #67
    gunn_runner
    gunn_runner www.gunnphotoservices.com
    Rocky River, OH
    2013 DCLB TRD
    OME 886 & Dakars. 35" Mickey Thompson Baja Boss
    Cancelling threads...
    MTopp and Torspd like this.
  8. Mar 14, 2017 at 8:23 AM
    #68
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    XRunners have tried this....they didn't have a choice.
    MTopp and TegoTaco like this.
  9. Mar 14, 2017 at 8:24 AM
    #69
    RedRed
    RedRed TACO TUESDAY!!!
    Red
    Lake Norman NC
    15 taco with stuff & things
    1.75" Billy's plus 1/4 spacer on both sides. 1" block in rear. 265/70/17 nitto g2 SCS matte dark bronze 6s
  10. Mar 14, 2017 at 8:27 AM
    #70
    SixthSnail
    SixthSnail I have no idea what I'm doing
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
    I don't have axle wrap. My wheels don't hop. Ha
    MTopp, ramonortiz55 and eccracer104 like this.
  11. Mar 14, 2017 at 8:31 AM
    #71
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Best thread today! :pccoffee:
  12. Mar 14, 2017 at 8:32 AM
    #72
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I know someone else whom argues with reason until blue in the face. Related??? :spy:
    Nickel and MTopp like this.
  13. Mar 14, 2017 at 8:33 AM
    #73
    lesterb315
    lesterb315 Well-Known Member
    Lester
    SoCal
    2012 DCSB Off-Road
  14. Mar 14, 2017 at 8:34 AM
    #74
    mjp2
    NJ
    Yeah, I'm not letting this bit of gold disappear from the system. This is "thread of legends"-caliber stuff. :devil:
    Anderson, PvilleJohn, Nickel and 6 others like this.
  15. Mar 14, 2017 at 8:34 AM
    #75
    DrFunker
    DrFunker Well-Known Member
  16. Mar 14, 2017 at 8:35 AM
    #76
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
  17. Mar 14, 2017 at 8:35 AM
    #77
    xJuice
    Josh
    N. Texas
    19 Tundra MGM
    Except that all S-10 suspension/frames were nearly identical 82-03. Save for ZQ8 and ZR-2
    mjp2 and Krazie Sj like this.
  18. Mar 14, 2017 at 8:35 AM
    #78
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    How can I read the 1st post, when it is not there?
    Oh, here it is:
  19. Mar 14, 2017 at 8:36 AM
    #79
    mjp2
    NJ
    I just reverted it back to his original post.
    RedRed likes this.
  20. Mar 14, 2017 at 8:40 AM
    #80
    DrFunker
    :laugh:
