FOOL PROOF way to improve your gas mileage!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by twhalm, Feb 15, 2017.
  1. Feb 16, 2017 at 9:14 AM
    #61
    tgear.shead
    tgear.shead Well-Known Member
    You know that a 5-speed transmission has FIVE speeds and not just THREE, right?
    At 3000 rpm, that thing will be moving just about 82 mph in 5th gear.
    http://www.engineersedge.com/mechanics_machines/transmission-gear-ratio-calculator.htm
    Use these values;
    Width: 245
    Profile: 75
    Wheel: 16
    Axle Ratio: 4.10
    1st gear: 3.95
    2nd gear: 2.06
    3rd gear: 1.44
    4th gear: 1.00
    5th gear: 0.81
    6th gear: does not apply.
  2. Feb 16, 2017 at 9:36 AM
    #62
    Spare Parts
    Spare Parts Well-Known Member
    Southern Maine
    2022 Off Road Premium 4Runner Lunar Rock
    Ok, I give up, I don't understand the fact that when the AC compressor is running it is harder to move that BIG RUBBER BELT, thus causing the engine to work harder, thus using more fuel. I also don't understand that when I am sitting idle and I turn on the AC the engine idles harder.
    You win
  3. Feb 16, 2017 at 9:39 AM
    #63
    airfish
    airfish Well-Known Member
  4. Feb 16, 2017 at 9:41 AM
    #64
    Spare Parts
    Southern Maine
    I do agree they didn't control enough of the variables. How ever you don't need to be a scientist to use the scientific method to learn or prove stuff.
  5. Feb 16, 2017 at 9:41 AM
    #65
    bajatacoguy
    bajatacoguy Well-Known Member
    Johnny
    RI to NH
    Blk Taco
    OEM: Bed Mat Roof Rack Tri-Fold Tonneau Cover Door Sill Protectors KO2's Dobinson GTS Suspension TRD Beadlocks Timbren Bump Stops SPC UCA Rear SuperSpring SSO Slimline Winch Bumper SmittyBilt x20 Mobtown Sliders Mobtown Front Skid Avid Basket Bed Rack DECKED Draw Organizer Total Chaos Bed Stiffners Relentless Fab Bed Corner Tie Downs CBI Ditch Light Brackets ARB Dual Compressor Instant Air Tank Smittybilt RTT Road Shower II Indel-B Fridge/Freezer w/ Slide Ironman 4x4 Insulated Fridge Case Redline Tuning Hood QuickLIFT Yo_Hec - Center Console Molle Little Johnny III CB Radio KB Voodoo Flashlight Kit Switch Pro 8100 BlueSea Fuse Pelfreybilt Fuse Panel Mount Gecko - LED Bed Lights Gecko - LED Hood Lights Raptor Grill Lights Cali Raised - Bed Flag Pole Holder Center Console Tray & Organizer Weather Tech Floor Mats Weather Tech Hood Deflector TRAILER BUILD HAPPENING! Plate: Negan
    This goes for all the donkeys who drive 3rd Gens & constantly complain like some chick who got felt up on a first date.
    ABA180 likes this.
  6. Feb 16, 2017 at 9:42 AM
    #66
    kmoto
    kmoto Well-Known Member
    NoVA
    2012 AC TRD Sport 4x4
    TRD S/C and other doohickeys
    Don't be a cool guy and buy 33" E Load tires.
    In other news: the sky is blue and water is wet.
    TRDMountaineer and twhalm[OP] like this.
  7. Feb 16, 2017 at 9:44 AM
    #67
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Instructions unclear.
    Penis stuck in zipper.
    twhalm[OP] likes this.
  8. Feb 16, 2017 at 9:50 AM
    #68
    uwu
    uwu Well-Known Member
    You misunderstood my post, but thanks for the information!
  9. Feb 16, 2017 at 9:58 AM
    #69
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    Vacuum Guage and learning to DWL helps teach peeps how they could be driving more efficiently.
  10. Feb 16, 2017 at 10:03 AM
    #70
    tgear.shead
    I think it goes without saying that you don't have to have a formal education in a particular field to be able to apply elements of that field, but it does help you to know how to apply it correctly. They were generally pretty bad at applying controls. As far as scientific accuracy, I'd rate their "confirmed" results as being predominantly acceptable (its easy to prove that something is possible -- just do it), but their "busted" results, or those based on accuracy of measurement were highly suspect, often tainted by poor experimental design and controls.
  11. Feb 16, 2017 at 11:15 AM
    #71
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
  12. Feb 16, 2017 at 12:47 PM
    #72
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Good, at least not in the sober guy's truck haha..though if you went to a show in MA last year hmmm
  13. Feb 19, 2017 at 4:43 PM
    #73
    cliffyk
    cliffyk Well-Known Member
    Cliff
    Saint Augustine, FL
    2009 DCSB SR5 TRD Sport 145k miles
    It takes 3.5 to 7 HP to drive the AC compressor, depending on the compressor's displacement and operating pressure. That power is generated by the engine's burning air and gasoline. The power is transmitted to the AC compressor by the previously referred to "BRB".
    When the AC compressor clutch engages it places that 3.5 to 7 HP load onto the engine (actually the pump's start-up load at first) and engine speed drops a bit until the ECU switches in the added air/fuel to accommodate the additional load. On modern cars the ECU also controls the AC on/off so it knows when the AC system needs some boost and can enable the AC rpm boost simultaneously, and even anticipate it a bit. Larger engines have higher rotating mass to better handle the initial load, smaller engines have less rotational inertia and AC startup can be quite noticeable...
    Here's a solution that isolates the energy consumption of the AC from that of the truck:
  14. Feb 19, 2017 at 5:18 PM
    #74
    baodown
    baodown Well-Known Member
    13 DCSB 09 600RR 15 Aprilia RSV4
    I feel like a noob asking this but my truck comes stock with 265/70/16 tires. I'm now using 265/70/17 tires and my speedometer is off according to the TW tire size calculator. If my speedo shows 65mph then my actual speed is 67ish. How does this affect my fuel efficiency and how do I calibrate it correctly? Thanks!
  15. Feb 19, 2017 at 5:28 PM
    #75
    twhalm
    twhalm [OP] Well-Known Member
    Denver, CO
    2015 TRD/OR Manual, OME , Dual battery
    If you have larger tires that means for every rotation of the tire you are going a bit further. So if the tires are bigger and the difference the tire size calculator is 3% you are getting 3% better gas mileage than calculating with your odometer will give you.
    So just add 3%!
    baodown[QUOTED] likes this.
  16. Feb 19, 2017 at 5:29 PM
    #76
    jbrnigan
    jbrnigan Well-Known Member
    Midwest
    2015 TRD Sport, 4X4, 4.0L, Auto - Access Cab
    Yep,.......If ya gotta worry about what it costs, you can't afford it
  17. Feb 21, 2017 at 7:00 AM
    #77
    tgear.shead
    When people DON'T worry about what things cost, you know what happens? They END UP being unable to afford ANYTHING.
  18. Feb 21, 2017 at 8:23 AM
    #78
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    Probably not a full 3%. Will lose some mpg due to heavier tires, maybe a little more lost if wider tires.
  19. Feb 21, 2017 at 8:26 AM
    #79
    rmepilot
    rmepilot Well-Known Member
    Rob
    Huntsville, AL
    '23 LR DCSB TRD OR 4x4 Premium Pkg
    2019 Jeep GC Summit 5.7l '15 DCLB S/C 4x4 Limited Pyrite Mica - Deceased
  20. Feb 21, 2017 at 8:31 AM
    #80
    MadDaddy
    MadDaddy Pork Rind Extraordinaire
    53 Miles West of Venus
    Many & varied
    I just logged 429 and 425 miles to a tank on mostly highway driving. I drove 5mph under the speed limit with cruise control on. I think I could've done better if my tires were aired up a bit. I am lifted with oversized tires, a few bolt-one (80-100lbs?), and had half a bed full of camping gear. I drafted semi's from 50' back running 62-65mph. It can be done, m'bros!
    Spare Parts likes this.
