Footwell Lights That Don't Suck (2nd Gen Edition!) - In Stock!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kmorgan3, Jan 31, 2022.
  1. Jan 31, 2022 at 2:50 PM
    kmorgan3
    kmorgan3 [OP] Redside Electric, LLC | VLEDS
    Kyle
    PNW
    2020 4Runner SR5 Premium | RAM 1500
    INTRO
    Hey everyone!
    If you haven't heard, we've been working on a plug-and-play footwell light kit for the 3rd Gen and that project is now coming to a brief close (kits are nearing shipment but we will make some changes to them down the road). Well, we've had some inquiries and decided we'd bring the kit to the 2nd Gen! This thread is intended to share our ongoing development of the 2nd Gen kit.
    FUNCTION
    For those of you that aren't familiar with the kits, they come with a OE-style harness and a PWM (pulse-width-modulator) that allow you to add factory-like footwell lights without splicing any wires. With the kit, you plug the OE-style harness into your truck, run the wires to the PWM, and then attach your lights using some extensions. That's it. When you do this you will get two modes of lighting:
    COURTESY MODE
    This mode is full brightness and triggers whenever you unlock your door, open a door, or immediately after you turn off your engine. The lights fade in/out like your overhead dome light. This mode is super bright! You can almost get a sun tan on your feet.
    NIGHT MODE
    This mode is adjustably dim (you can control how bright your lights are using the PWM) and provides ambient lighting whenever your parking lights or head lights are on. Note: COURTESY MODE takes priority over NIGHT MODE, so if you have a door open while your headlights are on, the lights will be full brightness.
    Lights
    The entire kit is built around the newly redesigned VLEDs footwell lighting strips. They are BRIGHT. The standard options will be 5500K white, deep red, blue, or an aqua blue. The user can select whichever they prefer, and swapping them in and out is a breeze. For other color options (i.e. other shades of white) VLEDS will be offering lights separately and you can get them without buying the entire kit with all of the harnesses if you want to change. Standard kits will come with 2 lights with the option to add 2 more lights as a stand-alone kit if you want to illuminate the rear footwell.
    Ordering
    These kits are IN STOCK! You can order from one of our authorized vendors.
    Installation
    Instructions for the 2nd Gen can be found here!
    Kolter45, Naveronski, llibrm and 10 others like this.
  2. Jan 31, 2022 at 3:07 PM
    Ruminator
    Ruminator Chairman of the Bored
    Mark
    Northern Illinois, USA
    2017 Red TRD-Sport, ACLB, MT!!!
    Alright doll-face, c'mon and bore me!
    :thumbsup:
    I eagerly await Gen (?) controlled from the overhead dome/map light switch, though.
    <edit> Don't mind me, I'm confusing iterations of light development with Tacoma generations.
  3. Jan 31, 2022 at 3:15 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    if they set it up like the 3rd gen it seems we could do both. tap into dome but have a split into an anytime. That we setup some diodes and switch to have 2 inputs for on/off.
    Is there any chance similar to the 3rd gen a splitter could be added in case you were running puddle lights? I have a setup just have not installed but would be nice to link them all together from the dome/courtesy.
  4. Jan 31, 2022 at 3:55 PM
    kmorgan3
    Kyle
    PNW
    This kit will be identical to the 3rd Gen, meaning you will just have to crack the door open instead of utilizing a switch (without modification). The next iteration of the footwell lights will more than likely have switch controls, but that is a distance off and will be sold as an add-on to the first kit. The goal of the add-on will be to tie the footwell lights into the dome SPDT.
    Yes you can add a splitter to run some puddle lights. Since MESO never made puddle pods for the 2nd Gen, I won't be including any special splitters/adapters in this kit. You would just get a cheap 3-way WP splitter from VLEDS and split the signal off of the HIGH setting for your puddle lights. Super easy.
  5. Jan 31, 2022 at 3:59 PM
    nudavinci64
    Robert
    Makes sense. If it's easy to split or tap into it to run it works. I had not go that far into it. Would there be an option to toss the splitter in if wanted? Nice to know about an add-on kit connecting to the dome will be a definite add-on I would want.
  6. Jan 31, 2022 at 4:28 PM
    Steelhead Bum
    Steelhead Bum Well-Known Member
    Mitchell
    Eastern WA
    13 DCLB Sport 4x4, 92 AC MT 4x4
  7. Jan 31, 2022 at 5:29 PM
    JMcFly
    JMcFly Well-Known Member
    Central FL
    2012 Tacoma SR5 4x4
    well I need something else to throw my money at.
  8. Feb 1, 2022 at 12:13 AM
    nudavinci64
    Robert
    What is the timing on the 2nd gen setup? I haven't had interior in my truck in over a year headliner, panels and my first thought is I could have some light again with the footwells.
    With the first release is there a way to turn off the footwells? Also is this only for the front? If so are you able to tap into the wires if you wanted to run a second set on the rear or another light? I do have a set that are in my seats but never got around to tapping into the circuitry to do it. mostly wired just needs that last step. Maybe that splitter like the puddle lights??
  9. Feb 1, 2022 at 7:36 AM
    kmorgan3
    Kyle
    PNW
    Timing is TBA but a prototype is already made and shipped out. I have to coordinate with VLEDS to figure out a rough estimate, but typically we don’t like giving estimates because the supply chain loves to ruin them.
    Turning them off is as easy as unplugging the PWM which will be mounted in an easy to reach location. There will be a rear add-on kit just like the 3rd Gen. You can simply add an extension to the 2nd footwell light and run it to the back seat (run the extension underneath the door sill). No need for a splitter if you’re doing that — the lights have a daisy chain output designed to string together another light:
    BizzyB726, 6 gearT444E and Halliwax like this.
  10. Feb 1, 2022 at 9:09 AM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    :pccoffee:
    I'd be in for red or white.
  11. Feb 1, 2022 at 9:44 AM
    kgarrett11
    kgarrett11 Master Yoda
    Garrett
    CA desert
    2015 DCLB
  12. Feb 1, 2022 at 10:36 AM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    If you need any beta testers for the red ones I'm your Huckleberry. Otherwise let me throw dolla dolla bills at ya.
    Steelhead Bum likes this.
  13. Feb 1, 2022 at 11:06 AM
    Steelhead Bum
    Mitchell
    Eastern WA
    Same although I think switchback white/red would be better. White when door ajar and dimmed red for night time driving.
    Bravisimo and Chris(NJ)[QUOTED] like this.
  14. Feb 1, 2022 at 11:09 AM
    ToxicTwin
    ToxicTwin Money Talks...It Says Goodbye
    Robert
    Glendale AZ
    2009 TRD OR
    Very interested.
  15. Feb 1, 2022 at 3:27 PM
    rb799
    rb799 Member
    Chesapeake, VA
    '13 Prerunner TRD Offroad
    Ham radio with direct power, Pop 'n Lock 8521, ImYrYo mirror bracket
    Interested in red or white!
  16. Feb 1, 2022 at 3:58 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
  17. Feb 1, 2022 at 5:35 PM
    azgunrunner
    azgunrunner A guy that knows a guy, that knows a guy...
    George
    Arizona
    06 DCLB Sport
    ADS 2.5, Dakar leaf springs KMF sliders CBI Ditch light mounts, DD SS3 pods Bumpers pending OBA pending
    watching....
  18. Feb 1, 2022 at 7:57 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I must just be old, but why do you need to see your feet when driving at night?
    o_O
  19. Feb 1, 2022 at 8:00 PM
    wi_taco
    Adam
    SE Wisconsin
    I thought it was weird too except when I bought my previous vehicle (2018 Subaru Forester) it came with this feature in red lights. Tell you hwat it’s pretty nice, kinda helps lessen strain on your eyes or maybe that’s my placebo explanation. Also helps find crap on the floor - kinda hard with just our dome light.
  20. Feb 1, 2022 at 8:05 PM
    Jimmy92870
    Jimmy92870 Well-Known Member
    Texas (DFW)
    07 DCSB PreRunner
    I'm in for a set of these whenever available.
