For all those Auto to manual conversion guys.
Discussion in '1st Gen. Tacomas (1995-2004)' started by mechanicjon, Jun 3, 2017.
  1. Jun 3, 2017 at 12:18 AM
    mechanicjon
    mechanicjon [OP] They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Has anyone tried this and confirmed the check engine light stays off? "
    Fixed! The cure for a check engine light after auto to manual swap
    After much pain and suffering (and a pair of reading glasses for the FSM) I've finally figured out the way to turn off the check engine light after doing an auto to manual swap. Mine is a 1996 2.7, your mileage may vary.
    I'm not going to mention wire colors since they vary from year to year and truck to truck but here's the info:
    Buy (3) 500 ohm 1 watt resistors (4:1 safety factor) and wire them between shift solenoids A, B, and E to ground. I.e. one side of the each resistor to each shift solenoid wire and tie the other side of all three together and then to ground. A handy ground can be found on the connector for your now unused 'L4' or 't-case neutral' position switch.
    Cut wires 5 and 6 from your P/N position switch and connect them together- this allows your truck to start. Now, find and cut the lead that indicates 'drive' and connect to the common of the switch. You'll probably already have this common tied to one side of your reverse light switch so just connect the 3 together. Leave the rest of the wires in the connector.
    Now, buy a 2k ohm 1/4 watt resistor and connect between the two leads of your trans temp sensor.
    That's it! No codes thus far but I will keep you updated as I go along and especially after I complete the famous Toyota 'drive cycle' which I need to do to pass inspection. If you have done it differently and it works please post an update! Enjoy!
    Greg "
    Dalandser, Madjik_Man and SnowroxKT like this.
  2. Jun 10, 2017 at 8:59 AM
    buckmaster243
    buckmaster243 I don’t know what to do with my hands
    Buck
    Washington
    2013 DCLB, 2023 4runner
    I tried it and I still had a cel. I'm not saying it doesn't work though, I could have just as easily messed up compared to what they did. Truck runs and operates like it should though
  3. Jun 10, 2017 at 9:52 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    There's another speed sensor in transmission. I didn't think you could get buy without it. Wonder if i could build a module that would duplicate it off the speed sensor 1. Hmmmmm......
  4. Jun 10, 2017 at 9:56 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    What code does it set?
  5. Jun 10, 2017 at 9:47 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    Do you know what code is set?
  6. Jun 11, 2017 at 7:35 AM
    buckmaster243
    Buck
    Washington
    There was a couple I believe. A park neutral safety switch code and some other weird one. I can't remember anymore what it was. I ended up cutting the whole pnss off and capped all the wires so that might be part of the problem. I think in the post the guy said to leave all the unused wires in the switch.
  7. Jun 11, 2017 at 7:38 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    If i could find out what codes. I'd like to try and come up with a fix.
  8. Jun 11, 2017 at 7:42 AM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    Any advice on doing this swap on a 2nd gen 2.7? I'm thinking of just getting the whole engine harness and ECU.
    BassAckwards likes this.
  9. Jun 11, 2017 at 7:45 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    Manual harness and ECUs are getting hard to find. Especially for the 2002 -2004 v6.
  10. Jun 11, 2017 at 7:46 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    2nd...gen..... no idea
  11. Jun 11, 2017 at 7:52 AM
    buckmaster243
    Buck
    Washington
    I'm away from my 4runner for the next month or so out of town for work. I'll try to get them for you as soon as I get home.
  12. Jun 11, 2017 at 10:41 AM
    COMAtized99
    COMAtized99 Well-Known Member
    North Carolina
    99 DCLB v8
    The Bed is stock...ish
    When I had a manual transmission behind me 4.7, I had to run an auto ecu because a manual version doesn't exist.
    I wired things so that the ECU "thought" the transmission was in reverse. I then wired the neutral position switch to the N/O switch on the clutch.
    I wired in a few resistors for thinks like the shift solinoid, and AT temp sensors and some others. I looked in the FSM for specifics in Ohms readings.
    I ran it that way for almost 3 years before I went back to a slush box this year.
  13. Jun 11, 2017 at 12:23 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    The A340 trans has a second speed sensor from what I understand. Without it, it will set a code.
  14. Jun 11, 2017 at 1:45 PM
    COMAtized99
    North Carolina
    99 DCLB v8
    The ECU I was using was from a 2002 Tundra, so that would have had an a340. I remember something about a speed sensor, but it's been awhile. All I used was resistors. When the ECU thinks the transmission is in reverse, it only runs basic function checks.
    When I first got it going, I wired in the basic stuff to get the engine to run, then delt with codes as they came.
  15. Jun 11, 2017 at 2:43 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    Interesting about the reverse. Did you use clutch switch to override reverse to allow you to start it?
  16. Jun 11, 2017 at 3:20 PM
    COMAtized99
    North Carolina
    99 DCLB v8
    Nope. Hard wired in reverse, and wired the neutral to the Normal open switch on the clutch pedal (closes when you push the clutch). The ECU never seemed to care that the neutral signal would pop in randomly. Also, the engine ecu never seemed to care that the truck was running 60-70-80mph plus in reverse. Just goes to show you that the ECU does not actually "think".
  17. Jun 11, 2017 at 3:25 PM
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    Subbed. I want to do this
  18. Jun 11, 2017 at 3:30 PM
    COMAtized99
    North Carolina
    99 DCLB v8
    I would recommend getting a manual ecu, if you can. If not, you can make an auto ecu work.
    buckmaster243 likes this.
  19. Jun 11, 2017 at 4:15 PM
    smmarine
    Melbourne FL
    It'd have to be the ECU and complete wiring harness. The harness connections are different. I got my truck because it had 61k on it when I found it. I was not excited with the 2.7 auto but for the miles and price I didn't care. I'm sure with a manual it'd be a different beast
  20. Jun 11, 2017 at 4:30 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    You can purchase the plastic plug housing with no terminals from Toyota for $8 each. Then transfer your pins to the new plugs. Time consuming but can be done. I believe @COMAtized99 is doing that.
    Did you notice any differance in the way your truck ran hardwired in reverse? Curious if an 03-04 drive by wire would react the same way.
