For All You Haters That Say Intakes & Exhausts Don't Make Power - Dyno Proof
Discussion in '4th Gen. Tacomas (2024+)' started by rat107, Jan 14, 2025.
  1. Jan 14, 2025 at 12:09 PM
    TexasTacoma713
    TexasTacoma713 Well-Known Member
    PNW
    2024 OR
    No thanks. Truck is already priced high. I’m glad I didn’t get a hybrid. $4k more dollars, 500lb more, for what?? The gasser is plenty.
    From what I’ve seen the dudes that are buying hybrids are boomers that got too much money and don’t need a full size.
  2. Jan 14, 2025 at 12:15 PM
    spicy_fish_taco
    spicy_fish_taco Well-Known Member
    '18 2.7L Taco 4x4 Access Cab
    ahhahahahahahahahhahahh
  3. Jan 14, 2025 at 12:36 PM
    OpeCity
    OpeCity Well-Known Member
    Long Beach, CA
    Most chassis dynos don’t measure well at low RPM, if at all. That’s why even on the new run it shows a steep climb above 2000rpm.
    dneal[QUOTED] likes this.
  4. Jan 14, 2025 at 12:39 PM
    OpeCity
    Long Beach, CA
    More usable power, vastly more torque (delivered thousands of rpm sooner), better ergonomics, better suspension, better ride quality, better tech, better transmission, better brakes, bigger tires, quieter interior
    not sure why you’re laughing
  5. Jan 14, 2025 at 12:40 PM
    dneal
    dneal Well-Known Member
    MidMO
    24 TRD OR 6M
    I don't disagree, but the point was that the baseline was significantly below factory spec. While the guy is bragging about how much power his mods made, he should have been wondering why his baseline was so far below factory spec.
    Flori-duh Taco likes this.
  6. Jan 14, 2025 at 12:59 PM
    OpeCity
    Long Beach, CA
    Probably, but that measured value is still a HUGE gain over other dynos I’ve seen
  7. Jan 14, 2025 at 1:11 PM
    JB_TN
    JB_TN Well-Known Member
    JB
    Tennessee
    2024 Bronze Oxide TRD OR
  8. Jan 14, 2025 at 1:14 PM
    hoodwinked
    hoodwinked Well-Known Member
    I call BS.
    Did you know stickers also add 5hp?
    Flori-duh Taco, Kbar and Goin2drt like this.
  9. Jan 14, 2025 at 1:24 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Ignoring this damning comparison, the entire world knows turbos perform better with more free-flowing exhausts. It's NA they don't do shit on and can make it worse. But no, it's not going to add 70HP on a factory produced engine.
  10. Jan 14, 2025 at 1:30 PM
    dneal
    MidMO
    24 TRD OR 6M
    A huge gain over what? A bad previous dyno run that was down over 100 lb ft of torque from factory spec?
    Best he got was what the truck is already capable of. There were no gains.
  11. Jan 14, 2025 at 1:38 PM
    OpeCity
    Long Beach, CA
    There are other stock dynos out there
  12. Jan 14, 2025 at 1:41 PM
    SchwarzeEwigkt
    SchwarzeEwigkt Well-Known Member
    Central NY
    ‘24 Tacoma TRD Sport 4x4, Solar Octane
    Yeah, those torque curves don't jibe with the delivery for your typical small displacement turbo engine. You typically see a sharp jump in torque as you hit boost threshold RPM and then it goes basically flat until the turbo starts to hit capacity and it starts falling off closer to redline.
    Here's a VAG 1.8T motor with (I think) the 180hp tune typical of them at the time:
    The stock curve from the video looks more like an NA engine's curve does. I'm wondering if they had to play games with the throttle to keep it from kicking down gears or something, since you can only control the maximum gear it'll use rather than directly selecting a gear. I hope it's not that, because that'd mean that the whole graph is meaningless until they were able to mat the throttle.
    That said, I'm used to looking at dyno graphs from less technologically complex engines, evident from the fact that the first thing that I thought of was an engine from 2003. That motor has less complex variable cam timing (I think only on the exhaust cam and certainly narrower range), a variable intake with two settings, port injection, and a single path turbocharger.
    What I am curious about is what was going on that made it enrich the mix so much earlier with the modifications. It fattens from fairly lean (15:1) to "performance rich" (12:1) at 4400 rather than 5300. I wonder if it's a knock prevention thing. Or, maybe that's something with transitioning from direct to port injection or something?
    Either way, I do know the way we find out is by having more folks dyno their trucks. It'll happen more often as the mod scene picks up more.
    Flori-duh Taco and Goin2drt like this.
  13. Jan 14, 2025 at 1:57 PM
    Lennyz1
    Lennyz1 Well-Known Member
    Len
    2024 TRD Sport Premium Hybrid 4x4 Bronze Oxide
    Burger Motorsports was running some tests on the dyno and they specifically said that they could not isolate the trans to do pulls in 4th gear when going full throttle from the start. They had to feather the throttle for a bit on the start and then go full throttle. For this reason they specifically said that the results will vary slightly after repeated pulls using the same tune. They were getting some nice numbers with only intake change.
    OpeCity likes this.
  14. Jan 14, 2025 at 2:03 PM
    OpeCity
    Long Beach, CA
    That would make sense and give significant credence to the idea that these aren’t directly comparable at 3000rpm
  15. Jan 14, 2025 at 2:05 PM
    #35
    Pibbles99
    Pibbles99 One more cast
    Brian
    Southern NH
    21 OR dbl cab
    Maybe redo the dyno?
  16. Jan 14, 2025 at 2:09 PM
    #36
    Newwt
    Newwt Well-Known Member
    Tampa, FL
    21 SUPER WHITE TRD OR 4X4 , 24 BCM TRD OR
    of course it will be, they use a engine dyno. there will be drivetrain loss when you stick a truck on a dyno.
    OP dont even bother, you could post all the proof in the world and this self degrading forum will continue to hate on its own enthusiast.
  17. Jan 14, 2025 at 2:09 PM
    #37
    Dbarffish
    Dbarffish Well-Known Member
    Doug
    Montana
    2024 dcsb TRDOR blue crush
    Stock
    I can afford 20 stickers!!! 100 hp more! Woohoo!
    Kbar and hoodwinked[QUOTED] like this.
  18. Jan 14, 2025 at 2:14 PM
    #38
    Lennyz1
    Len
    Low RPM, under 2K. By 2K it was full throttle and pulling, so I would think the 3K numbers are pretty good. I would imagine that the ECU may have been a limiting factor for the factory run on the Dyno. Here is the video.
    https://www.youtube.com/watch?v=rSNv3203KSE
  19. Jan 14, 2025 at 2:17 PM
    #39
    dneal
    MidMO
    24 TRD OR 6M
    Cognitive dissonance is a bitch.
    Flori-duh Taco and hoodwinked like this.
  20. Jan 14, 2025 at 2:22 PM
    #40
    Newwt
    Tampa, FL
    wouldn't know
