For All You Haters That Say Intakes & Exhausts Don't Make Power - Dyno Proof
Discussion in '4th Gen. Tacomas (2024+)' started by rat107, Jan 14, 2025.
  1. Jan 15, 2025 at 8:40 PM
    #81
    dneal
    dneal Well-Known Member
    MidMO
    24 TRD OR 6M
    If your dyno pull shows over 100 lb ft less than spec, you're doing it wrong. You don't lose that much through the driveline.
    The base numbers aren't kosher.
    hoodwinked likes this.
  2. Jan 15, 2025 at 8:53 PM
    #82
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Less restriction = higher VE = less waste heat = more timing/lower AFRs = more power.
    And/or they can override knock sensitivity a little
  3. Jan 15, 2025 at 9:36 PM
    #83
    Xperivent
    Xperivent Well-Known Member
    ‘24 Supersonic ORP & '04 Impulse Red DC OR
    Ignore the blue line. The red line is a stock tacoma…. i read
    143ish HP and 254ish ft/ib Torque at 3,000 RPM
    Somebody who loves math figure the difference between the baseline in this dumb youtube video and this other baseline, and then what the video says after mods.
    Thx
  4. Jan 15, 2025 at 9:53 PM
    #84
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    There was mention of the truck being JB4 tuned in the comments of the video.
    One guy mentioned OTT, and they commented they were working with YotaWorks.
    I do find it odd that their power gains look awfully close to a tuned truck.
    JB4 and OTT tunes basically mimick their graphs. Yet they claim the intake and exhaust did all the work?
    I find it hard to believe……..but anything is possible.
    Maybe the truck can compensate that much on it’s own?
    Goin2drt likes this.
  5. Jan 16, 2025 at 7:02 AM
    #85
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    I refuse to watch clickbait Youtube videos and instead choose to commet from a position of ignorance. :thumbsup:
    But was this truck tuned or not? The gains are still inflated IMO but make more sense if it was also tuned.
  6. Jan 16, 2025 at 9:17 AM
    #86
    TnShooter
    Deogee
    STOCK
    They never say.
    One can only assume it’s stock.
    But the number are power curve lead me to believe it’s more than “just parts”.
  7. Jan 16, 2025 at 10:50 AM
    #87
    timetoeatpotatoes
    timetoeatpotatoes Well-Known Member
    2024 Bronze Oxide Trailhunter
    Wouldn't it have to be? You are getting more air and have less backpressure. wouldnt you need to tune the ECU to expect that?
    All these dyno runs seem really weird to me though, and not reflective of what toyota tells us we should be getting.
    batacoma likes this.
  8. Jan 16, 2025 at 10:52 AM
    #88
    velogeek
    velogeek Well-Known Member
    Andrew
    Gilbert, AZ
    2024 4Runner
    Exactly this, it's just two data points. Restriction is a curve and 70hp is truly possible if it were restricted enough. The problem is that if that restriction was so bad at 3k, the physics of how a turbo operates (assuming no other restrictions) would require an even larger gain anywhere above that on the dyno sheet.
    Schlappesepple and max911 like this.
  9. Jan 16, 2025 at 11:00 AM
    #89
    Newwt
    Newwt Well-Known Member
    Tampa, FL
    21 SUPER WHITE TRD OR 4X4 , 24 BCM TRD OR
    Yeah, I just went back and looked at the old video and they are being disingenuous. In the old video they said they did 3 runs
    This is their best run(blue line- no dip) 267/306
    In the new video they are using their worst pull (260/283) but are saying it's the average of the 3 pulls. So yeah, Is it just the intake/exhaust or is there a small tune as well, either way I don't think I can trust them because I bet all they did was stick their best run against their worst stock run and said "Its all averages"
  10. Jan 16, 2025 at 11:13 AM
    #90
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Well, I'm certainly not buying it. If it seems too good to be true, it usually is. Just the extreme difference alone is enough to tell me something isn't right.
    TXpro4X4 likes this.
  11. Jan 16, 2025 at 11:18 AM
    #91
    Snakepilot
    Snakepilot Well-Known Member
    Tucson, AZ
    2025 Tacoma TRD Pro
    The only "performance" mod I would be interested in is a factory tune like Ford did for the Ranger Raptor. 12% more HP and 25% more Tq for $825. If Toyota offered a tune that added 25-30hp and 65-70Tq for under $1K, I'd be all over it.
  12. Jan 16, 2025 at 11:25 AM
    #92
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    I still want to see a hybrid on the dyno to see if it's close to what Toyota claims. There could be some iForcemax runs out there, but I haven't seen anything.
  13. Jan 16, 2025 at 11:37 AM
    #93
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    Yeah, it might be hard to get an actual run. They likely only add as much electric power as they feel is needed, based on more than just how hard you are pushing the pedal down. Not sure a typical dyno run could simulate what is needed to see what the max torque could get to unless you know more about how they control the electric power.
    For the spec, Toyota may have just added the max torque of the electric motor to what 2.4T puts out.
    batacoma[QUOTED] likes this.
  14. Jan 16, 2025 at 11:43 AM
    #94
    batacoma
    batacoma Truck Wars
    Sounds right to me. I'm sure you can feel the torque over the non-hybrid and their probably isn't a way to capture it on a dyno.
  15. Jan 16, 2025 at 11:43 AM
    #95
    Newwt
    Tampa, FL
    Theres roughly a 15% drivetrain loss for automatics so with a pull for a stock non hybrid numbers should be somewhere around 235hp and 278ftlbs
  16. Jan 16, 2025 at 11:48 AM
    #96
    gmtech
    gmtech Well-Known Member
    quad cities illinois
    2016 trd or. 2024 trd OR iforcemaxx!!
    Stock AF
    does anyone know of any drag race videos of 2 24s one none hybrid and one hybrid? TRD Jon says his new pro is way more powerfull than his OR none hybrid. ive only driven my ifroce maxx.
  17. Jan 16, 2025 at 11:49 AM
    #97
    Snakepilot
    Tucson, AZ
    2025 Tacoma TRD Pro
    Newwt likes this.
  18. Jan 16, 2025 at 12:15 PM
    #98
    PDKTaco
    PDKTaco Well-Known Member
    Montana
    2024 TRD Off-road
  19. Jan 16, 2025 at 12:30 PM
    #99
    PDKTaco
    Montana
    2024 TRD Off-road
    Here is OTT numbers. OTT Premium fuel Blue is nearly identical to R4T intake + Exhaust numbers!
    Red baseline OEM regular fuel
    Blue OEM Premium
    Green OTT beta tune
  20. Jan 16, 2025 at 12:51 PM
    #100
    slater
    slater Well-Known Member
    San Diego
    24 white Tacoma TRD Sport 2wd
    He said the 4th gen will CRUSH the 3rd gen...
    Sorry, just figured ide throw that in.........
