FOR SALE: 1996-2004 Toyota Tacoma STS Rear-Mounted Turbo System
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by 1SexyTaco, Aug 15, 2010.
  1. Aug 15, 2010 at 9:20 PM
    1SexyTaco
    1SexyTaco [OP] Well-Known Member
    Charlotte, N.C.
    1 Sick Taco
    This is a used STS Turbo bolt-on system:
    T3/T4 Turbo
    38mm Wastegate w/ 7Ib spring
    50mm Blow Off Valve w/ 11Ib spring
    Air Filter w/ Custom Intake Pipe and Dry Charger
    Turbo Oiling System
    HPC Coated Intake/Exhaust Tubing
    Electrical Harness w/ Oil Warning System
    Silicone Connectors, Clamps and Fittings
    Return Oil Cap w/ Quick Disconnect Fitting
    Full Color, Step-By-Step Instruction Manual
    Dual Gauge Pillar Pod
    AEM Wideband Gauge w/ Sensor
    Auto Meter Boost Gauge
    FMU (Fuel Management Unit) w/ Three Discs
    STS Intercooler Kit Bolt-On w/ Piping for Tacomas with this STS Turbo Kit
    255 Walbro Fuel pump
    Kit Includes ALL Necessary Parts and Hardware for Installation
    Complete Kit Price:
    $5,200
    Partial Kit Price:
    $2,800
    This kit has 8,000 miles on it.
    It is in great condition.
  2. Aug 16, 2010 at 4:27 PM
    Idrivetoys
    Idrivetoys Well-Known Member
    Yuma AZ
    I need a 4 door DC 4x4
    what did this produce on your truck??
  3. Aug 16, 2010 at 4:28 PM
    tacomakid96
    tacomakid96 Can you skin Grizz, pilgram?
    Phil
    Out n' about
    2008 Tundra
    God I want it!!
  4. Aug 16, 2010 at 6:24 PM
    1SexyTaco
    Charlotte, N.C.
    1 Sick Taco
    231 hp 286ft lbs torque to the wheels on FMU
  5. Aug 16, 2010 at 6:28 PM
    mrp192
    mrp192 REALLY!!
    Brent
    Cheney WA
    98 V6 4x4 limited
    Stereo, boobies
    why are you selling it?
  6. Aug 16, 2010 at 6:46 PM
    1SexyTaco
    Charlotte, N.C.
    1 Sick Taco
    i'm selling my truck
  7. Aug 16, 2010 at 6:48 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Can you post the dyno slip? Thats alot of HP on only 7 psi. Stock is about 140-150 hp, and 160-175 tq.
  8. Aug 16, 2010 at 7:14 PM
    04trd
    04trd Well-Known Member
    Cleveland Ohio
    2015 f150 lariat
    weather techs, 20precent tint, leveling kit, back flip bed cover, rhino liner
    sooo.... if someone buys this does it come with a 300 page manual to get it all set up :p
  9. Aug 16, 2010 at 7:15 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Its an easy bolt on. The included manual is plenty detailed.
  10. Aug 16, 2010 at 7:17 PM
    yosh2000
    yosh2000 Well-Known Member
    Denver, CO
    '17 Tundra CM 5.7
    x2, i wanna see this dyno sheet!!
  11. Aug 16, 2010 at 7:21 PM
    04trd
    Cleveland Ohio
    2015 f150 lariat
    lets see that sheet! but its really tempting when a supercharger costs four grand installed and 7th injector
  12. Aug 16, 2010 at 7:29 PM
    1SexyTaco
    Charlotte, N.C.
    1 Sick Taco
    You should know that this graph has no correction factor therefore it is exactly what the truck was putting down on the dyno for that day and the conditions for that day were 97.24 degrees farenheit and 18 percent humidity and 29.35 inches of mercury. With an SAE correction factor it would take the plot and determine what the motor would have put down at 59 degrees and 0 humidity and 29.34 inches of mercury, which would have been 232.11 HP and 287.06 ft-lbs of torque. Let me know if you need anymore information.
  13. Aug 16, 2010 at 7:35 PM
    1SexyTaco
    Charlotte, N.C.
    1 Sick Taco
    it was easy to install
  14. Aug 16, 2010 at 7:41 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    i think this kind of system, the way its designed, is one of the easiest things in the world to install! IDK about the design as far as efficiency goes but there are a lot of people you run these kits and are very please! you just need to be careful if you wheel at all for rocks and getting the turbo and plumbing and shit bumped and whatnot.
    GLWTS
  15. Aug 16, 2010 at 8:06 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ok....If this is from a 5VZ engine, How did you get the power to peak at 4500 rpm?? Thats awfully low for a 5VZ engine. When FI, they useually peak around 5200 or so.....and I havent seen one whith a torque peak @ 3K rpm. Looks like a dyno from a NA V8, as opposed to a turbo 3.4 V6......
    This is a bone stock 5VZ dyno
  16. Aug 16, 2010 at 8:09 PM
    08pretaco
    Oliver
    az
    Damn Chris....haha glad there is someone on here to dig and make sure shits what shit is!
  17. Aug 16, 2010 at 8:30 PM
    1SexyTaco
    Charlotte, N.C.
    1 Sick Taco
    my truck was in 4th gear and fuel cut off is at 4500 rpm thats why the peak was at 4500rpm
  18. Aug 16, 2010 at 8:40 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Fuel cut off doesnt have to do with the peak HP, but rather the RPM at which the rev limiter steps in.........
  19. Aug 16, 2010 at 8:45 PM
    1SexyTaco
    Charlotte, N.C.
    1 Sick Taco
    Chris can talk to my friend at SOHO Motorsports that did the dyno run on my truck tomorrow.
  20. Aug 16, 2010 at 8:54 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    That would be cool with me. Im not trying to crap in your thread, just have never seen an FI 3.4 make those numbers ( on 7 psi), and at those rpm's. And still cant figure out why the rpm cut off is below 5700.....
