For Sale: (4) Tire Pressure Monitors
Discussion in 'Buy / Sell / Trade' started by dougarmintrout, Feb 24, 2010.
  1. Feb 24, 2010 at 3:15 PM
    dougarmintrout
    dougarmintrout [OP] New Member
    Doug
    Seattle
    2010 Access Cab Prerunner
    These came out of the factory 16" steel wheels on my '10 Tacoma. They were the wrong angle for my new rims.
    These only have 500 miles on them. They are $115 new from the dealer. I'll take $200 for all 4.
    I live in Seattle, 98105.
    Part#: PA66 GF33
  2. Feb 24, 2010 at 3:25 PM
    Flynn Diesel
    Flynn Diesel Well-Known Member
    Phoenix, AZ
    2010 PreRunner SR5 Double Cab
    •BFG AT KO 285/70/17, XD Addict 17x9, Light Racing UCA’s, Billstein 5100’s, OME 885’s, Toytec AAL, Seat Belt warning disable, Grill Craft Black MX Upper & Lower Grill, VisionX 55/65 watt xenon Low/High Beam lights. FOG Light only Mod. Tailgate theft prevention mod. Wet Okole armrest mod. Redline Hood Struts, Weathertech floor liners. AMP Bed Extender. Wet Okole Seat Covers. Pioneer P4200DVD
    You know you could have still used them. I just had the ones in my steel wheels put in my new XD's. They won't mount flat because of the angle but can still be used if you mount them upside down. Then they will be at the right angle and work just fine. You just need to make sure that if the tires are ever removed from the wheels you tell them that the TPMS is not mounted flat and to push the valve stem into the tire before removing. Otherwise they will break them off. Would have saved you some money.
  3. Feb 24, 2010 at 3:30 PM
    tacobale
    tacobale Well-Known Member
    Good to know. So I guess I can use my sensors from the steel wheels and use them on the Toyota 16" Aluminum wheels?
  4. Feb 24, 2010 at 5:57 PM
    Flynn Diesel
    Phoenix, AZ
    Yes. They took mine out of 16" steel wheels and put them in 17" XD Addicts. If you ever have the tires taken off the wheels and forget to tell them that they are mounted upside down, they will break when they try to remove them. Also if you ever get a flat they will more than likely get get smashed. I wasnt about to spend $400 on new ones so I'll take my chances.
