For Sale: 4x4 Manual Hubs, Spindles, Knuckles and CVs
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by zippsub9, Feb 21, 2021.
  1. Apr 24, 2024 at 10:38 AM
    #181
    zippsub9
    zippsub9 [OP] Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    @Sinkalip
    Will have it all packaged up here shortly.
  2. May 18, 2024 at 5:24 AM
    #182
    zippsub9
    Halfmoon, NY
    14 DCLB
    @leid will be on the way today.
    Black97v6MT, Jase, Sinkalip and 3 others like this.
  3. Jun 17, 2024 at 1:55 PM
    #183
    Tydeorum
    Tydeorum Well-Known Member
    Anderson S.C.
    4x4 SR5
    I'm interested in the cost of a new assembly for my 99 v6 4x4 manual hub truck. It's time to replace the bearings and I don't have the tools to this myself. Can I get a qoute on what it would cost and if you need the cores?
    zippsub9[OP] likes this.
  4. Jun 17, 2024 at 4:02 PM
    #184
    zippsub9
    Halfmoon, NY
    14 DCLB
    Thanks for the inquiry. I will get you some info back here shortly once I get back home tomorrow.
  5. Jun 17, 2024 at 4:39 PM
    #185
    leid
    leid Well-Known Member
    Brandon, MS
    1997 V6 Tacoma 4x4 & 2020 V6 Tacoma TRD 4x4
    ECGS & ZUK diffs w lockers/Marlin R150F/NITRO axles/winches
    Hey zipp,
    Just wanted to take a minute to give you some feedback on the manual hub OEM "blue label" CVs you built up for me: beautiful work! My rig sees so much high water that I have deemed it necessary to seal the CV boots at the seams with UltraBlack to help keep water/moisture out. I learned that valuable lesson quite a few years back when my '97 V6 Taco was a lot younger by ruining a pricey set of new OEM CVs when I did not think it necessary to seal them against the deep sandy mud/high water I routinely wheeled thru. In the picture below, the CVs you sent me are on the inside all set up and sealed ready to install with the old well-worn CVs that were replaced on the outside. The old set of OEM remans. lasted thru 6 years of use/abuse including approx. 800-900 days of off-roading fun. No evidence of water intrusion on the old CVs which were also sealed with Ultrablack, the boots are still very serviceable, so the old CVs can function as emergency spares if needed. Everything has been back together for a couple weeks now, the new CVs are working nicely with 3" of lift with an auto locker & CV bushing in the ECGS front diff., so I call this front-end refresh done. But I will do my level best to wear out this new set of reman. OEM CVs over the next 6 years. Appreciate it, hope you are healing up well, and thanks again!
  6. Jun 17, 2024 at 6:02 PM
    #186
    zippsub9
    Halfmoon, NY
    14 DCLB
    Leid, thanks so much for the feedback. I think your level of care and maintenance is what makes the difference in part longevity. You have a wealth of knowledge and experience gained only through time. Enjoy and let me know if there is anything else I can do to help out.
    Black97v6MT, Jase and leid[QUOTED] like this.
  7. Jun 19, 2024 at 9:27 AM
    #187
    zippsub9
    Halfmoon, NY
    14 DCLB
  8. Jun 27, 2024 at 6:03 PM
    #188
    w8tdstrgecube
    w8tdstrgecube Well-Known Member
    Brian
    Wisconsin
    2004 Gold Regular Cab 2.7L Manual 4x4
    @zippsub9 wondering if you would help me with a quote for components for manual hub swap? Thanks!
    Black97v6MT, Nano909 and zippsub9[OP] like this.
  9. Jul 2, 2024 at 5:09 PM
    #189
    zippsub9
    Halfmoon, NY
    14 DCLB
    leid, Black97v6MT, surfishjoe and 2 others like this.
  10. Jul 2, 2024 at 6:03 PM
    #190
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    Curious on how you go about getting the cage and balls into the outer joint?
    When I've gone to disassemble them, I always end up cutting the cage
  11. Jul 2, 2024 at 6:26 PM
    #191
    zippsub9
    Halfmoon, NY
    14 DCLB
    It is super low tolerance but if you rotate the cage to remove each ball one by one then rotate it 90 degrees. There is small sweet spot where the cage can drop out.
    dannybubbles likes this.
  12. Jul 3, 2024 at 11:15 AM
    #192
    betterbuckleup
    Ian
    Concord, CA
    Hm. Maybe I didn't try enough different positions, but the balls didn't seem like they wanted to come out in any position. I'll keep that in mind for if there's a next time.
    zippsub9[QUOTED][OP] likes this.
  13. Aug 28, 2024 at 1:31 PM
    #193
    Ruizbau2699
    Ruizbau2699 Well-Known Member
    Noe
    Easley South Carolina
    2018+1999 Tacoma TRD OFF-ROAD
    Hey @zippsub9, your work looks great! I’m looking at getting my front end rebuilt, and if you could quote me for a steering knuckle with wheel bearing and reinforced spindle gusset. It’s going on a 99 Tacoma non abs, auto 4wd
  14. Aug 28, 2024 at 3:23 PM
    #194
    zippsub9
    Halfmoon, NY
    14 DCLB
    Thanks for the kind words. I will send a PM and get some numbers together for you here shortly.
    Ruizbau2699[QUOTED] likes this.
  15. Aug 31, 2024 at 2:13 PM
    #195
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    @zippsub9 and anyone else that has installed these, Jason included two seals, part no. 90080-30028. I thought these were the dust seals for the back of the spindles' mating surface with the CV's but after watching this and checking a related thread, I wasn't so sure.
    https://youtu.be/1TpOYj0sUpA?t=1625
    https://www.tacomaworld.com/threads...outboard-dust-seal-wheel-bearing-seal.770754/\
    EDIT: I answered my own question with the above thread, any comments on how people installed them are certainly welcome. Thanks.
    Black97v6MT likes this.
  16. Aug 31, 2024 at 7:35 PM
    #196
    zippsub9
    Halfmoon, NY
    14 DCLB
    It is a snug friction fit on the outboard of the CV. I use a small bit of lube to ease it on. I use a PVC pipe or wooden dowel to lightly tap them on. The rubber seal is the most important piece to avoid tearing. The thin metal lips can be bent back if bent or damaged without issue. It overlaps with the backside of the knuckle metal lip seal.
    Dalandser[QUOTED] likes this.
  17. Sep 4, 2024 at 4:10 PM
    #197
    cdj1
    cdj1 Well-Known Member
    Clint
    Muuurville, TN
    97 Tacoma
    King Extended travel coilovers, 5100 Shocks, Daystar shackles,OME Leaf Springs,255/85/16, front diff drop, RAT skid plates, 4.56 gears, LSD in rear, Aussie locker in the front, Front Range Offroad twin sticks, trail gear/ Bash Fab rear bumper, elite off road front bumper and sliders, warn m8000 winch, in cab winch control
    Can I buy just a drivers side spindle with the bearing pressed in? I just broke my spindle on the trail last weekend so the hub is fine.
  18. Sep 4, 2024 at 4:32 PM
    #198
    zippsub9
    Halfmoon, NY
    14 DCLB
    Absolutely, anything for a bag of onions. But seriously, PM on the way.
  19. Sep 4, 2024 at 5:02 PM
    #199
    cdj1
    Clint
    Muuurville, TN
    97 Tacoma
    Haha. I moved from Vidalia about 4 years ago. I am just outside of Knoxville TN now.
  20. Sep 14, 2024 at 6:12 AM
    #200
    Enfield1
    Enfield1 Well-Known Member
    Brad
    Bryan, Tx
    '18 White DCSB OR 4wd auto
    Can I get a quote for a rebuild on 4cyl manual hubs with CVs, ball joints and gussets? I have cores with factory CVs if that is needed.
