*FOR SALE* | GUSSETED SPINDLES (Various Gusset Options Available)
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by m00seNUckLEz, Apr 2, 2018.
  1. Jul 28, 2021 at 7:18 PM
    #181
    BOMBS
    BOMBS Well-Known Member
    2017 Black Tacoma TRD Off Road
    Do you do installs?
  2. Jul 28, 2021 at 7:27 PM
    #182
    m00seNUckLEz
    m00seNUckLEz [OP] tAc0 aFiCi0nAd0
    Fresno, CA
    Under Construction
    I can. I prefer to wait until the weather cools down a bit though.
    BOMBS[QUOTED] likes this.
  3. Jul 28, 2021 at 7:27 PM
    #183
    m00seNUckLEz
    Fresno, CA
    Under Construction
    Thank you, sir.
  4. Jul 28, 2021 at 8:03 PM
    #184
    BOMBS
    Ok. Sounds good. I'll wait for the weather to cool down.
  5. Aug 6, 2021 at 10:14 AM
    #185
    m00seNUckLEz
    Fresno, CA
    Under Construction
  6. Aug 10, 2021 at 6:04 PM
    #186
    m00seNUckLEz
    Fresno, CA
    Under Construction
    Gusseted spindles on a 5thGen 4Runner
    theolee, montijo505, BOMBS and 2 others like this.
  7. Aug 30, 2021 at 10:30 AM
    #187
    T.Barn
    T.Barn Well-Known Member
    Todd
    Hampton Roads, Virginia
    2010 AC 4x4 6MT
    Awesome work, message sent.
    m00seNUckLEz[OP] likes this.
  8. Aug 30, 2021 at 10:46 AM
    #188
    m00seNUckLEz
    Fresno, CA
    Under Construction
    :thumbsup:
  9. Aug 30, 2021 at 11:21 AM
    #189
    TWTaco
    TWTaco Well-Known Member
    Dave
    Hi Ryan
    Questions for you.
    I will be adding the icon S2 secondary shock kit will the the double sheer steering work with this kit?
    I dont wheel as much as i had planned on but is it still worth doing the double gusseted steering kit just to have the security when i do wheel. Any ill affects for daily driver? Or should i just go with regular gusseted spindles? I do have 1.25 spider trax spacers on my truck now. I do have the SDHQ billet brake sensors those will have to come off for the double sheer? FYI also running icon lower control arm skid have to for the S2 kit.
    My truck is pretty heavy adding photo. I do want to retain the option of running the sway bar even though i dont think i will need it with the secondary kit. I am running 700lb coils.
    Your thoughts and suggestions?
    Thanks
    Dave
  10. Aug 30, 2021 at 11:55 AM
    #190
    m00seNUckLEz
    Fresno, CA
    Under Construction
    Good afternoon. I just sent you a PM :thumbsup:
    TWTaco[QUOTED] likes this.
  11. Aug 30, 2021 at 11:57 AM
    #191
    TWTaco
    Dave
    Thank you!
  12. Aug 30, 2021 at 1:55 PM
    #192
    AugustaTaco
    AugustaTaco Well-Known Member
    Josh
    Augusta, GA
    2015 DCSBXSPX4X4 2017 GX460
    "Getting out of hand" - Wife
  13. Aug 30, 2021 at 2:32 PM
    #193
    m00seNUckLEz
    Fresno, CA
    Under Construction
    Just a reminder, if any of you guys have Instagram you can see more of my work there
  14. Aug 30, 2021 at 4:54 PM
    #194
    BOMBS
    Don't forget about those that don't have Instagram. We like things posted here as well.
  15. Aug 31, 2021 at 9:18 AM
    #195
    m00seNUckLEz
    Fresno, CA
    Under Construction
    TC Gusseted spindles for @dens13-tacoma on Instagram
    D42C07B7-7D6E-4030-BDE3-BEDA9F0A192A.jpg 27725A44-1307-49AC-9E04-EF5F6208F7E7.jpg
    montijo505, TWTaco and BOMBS like this.
  16. Aug 31, 2021 at 10:23 AM
    #196
    Amart2215
    Amart2215 beastlytaco714
    Anthony
    White 2006 Tacoma SR5 PreRunner
    front: @kingshocks 2.5 extended travel @totalchaosfabrication UCA’s & Stock length expedition series LCA’s @maxtracsuspension 4in Spindle Lift Rear: @accutuneoffroad Custom King shocks w/ @deaver_suspension_inc Stage 2 leaf springs and @archive_garage HH w/ cross tube and King 2.0 Bump Stops Wheels/Tires: @vtxwheels Rogue Off-Road Wheels 17” -10 offset @yokohamatire Geolander M/T G003 33x12.5R17 Accessories: @alpharexusa NOVA-Series LED Projector Headlights @roughcountry 30” Light bar and light pods with @ragofabrication ditch light brackets @uptopoverland Bravo roof rack @agency_6 grab handles and d-ring tow hitch @envegrilles Grille insert
    Which set do you recommend for a Dirt King long travel kit, i’m leaning towards the JDFAB one.
  17. Aug 31, 2021 at 11:19 AM
    #197
    m00seNUckLEz
    Fresno, CA
    Under Construction
    Personally, I chose to really push the Total Chaos style of gussets because they are strong, and they allow you to keep your sway bar if you want. Dirt King gussets are strong too, but you can’t keep your swaybar. JDFAB gussets are strong also, can’t keep sway bar either, but I can modify them to make them work. I have to trim some material in that area to make it work.
    56D9E016-2DA1-4A58-AFB2-45822E330CB2.jpg 45518998-12F8-4084-AD24-45D72EA28671.jpg
    montijo505 likes this.
  18. Aug 31, 2021 at 11:26 AM
    #198
    Amart2215
    Anthony
    I actually don't plan on keeping the sway bar on the truck when I get the LT kit installed.
  19. Aug 31, 2021 at 11:45 AM
    #199
    m00seNUckLEz
    Fresno, CA
    Under Construction
    That’s fine. The swaybar capable TC gussets are significantly stronger than the non-swaybar TC ones, that’s why I still recommend going with those.
    Keep swaybar on, take it off, makes no difference, your spindles are still protected.
    I’ve seen people still bend the non-swaybar versions, mostly LT guys going really hard.
    If you want the JDFAB ones, and install those when you get your kit on, that’s fine also. All up to you. I’m easy to work with.
    I have both styles of gussets in stock.
  20. Aug 31, 2021 at 2:36 PM
    #200
    Amart2215
    Anthony
    For sure man, will probably go with the TC gusset then. But is there any benefit to having the JDFAB heim joint?
