*FOR SALE* | GUSSETED SPINDLES (Various Gusset Options Available)
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by m00seNUckLEz, Apr 2, 2018.
  1. Aug 8, 2023 at 9:19 PM
    #241
    m00seNUckLEz
    m00seNUckLEz [OP] tAc0 aFiCi0nAd0
    Fresno, CA
    Under Construction
    :cheers:
  2. Aug 9, 2023 at 1:02 PM
    #242
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Silly question but can these be dimple died? I am kinda wanting a set for the rally stuff I do with the truck but am not wanting to add weight unnecessarily. I also run a larger sway bar, plan on running the TRD pro uca from the iron man 4x4 one I currently have and run advan rgd2 -10 offset 17in on stock sized tires with a bbk. To give an idea for fitment. I believe I will not have clearance issues but am not sure.
    m00seNUckLEz[OP] likes this.
  3. Aug 10, 2023 at 9:28 AM
    #243
    m00seNUckLEz
    Fresno, CA
    Under Construction
    The gusset fully boxes everything. In order to have a couple dimpled cutouts, you’d have to drill another hole in the backside to be able to wash out any dirt and such that accumulate inside. Water/moisture will probably start to corrode the inside as well as the spindle itself. Might be more of a hassle than beneficial.
  4. Aug 21, 2023 at 12:22 PM
    #244
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
  5. Sep 23, 2023 at 7:15 PM
    #245
    FamousTaco
    FamousTaco Well-Known Member
    Long Beach, CA
    2022 Tacoma 4x4 OR
    Do TC gussets work with JBA UCA?
  6. Oct 10, 2023 at 9:28 AM
    #246
    m00seNUckLEz
    Fresno, CA
    Under Construction
    Heavy duty spindle gussets with a double shear heim upgrade and +3.5” tierods for a FJ Cruiser in SoCal. These will get paired with a modified tundra rack.
    Mully, 05tacomabro, YotaFAB and 4 others like this.
  7. Feb 25, 2024 at 2:19 AM
    #247
    FamousTaco
    Long Beach, CA
    2022 Tacoma 4x4 OR
    Do any of the spindle gussets you do work with JBA UCA?
  8. Feb 25, 2024 at 8:01 AM
    #248
    m00seNUckLEz
    Fresno, CA
    Under Construction
    Yes
    swerveverything and BOMBS like this.
  9. Mar 5, 2024 at 9:30 AM
    #249
    tacopeter
    tacopeter My truck isn't modded. It's well optioned.
    Peter
    Washington State
    21 DCLB TRD OR
    OEM+
    PM sent!
  10. Mar 7, 2024 at 7:12 PM
    #250
    killerkeener
    killerkeener Well-Known Member
    2011 trd 4x4 manual
    None yet
  11. Mar 9, 2024 at 6:55 AM
    #251
    killerkeener
    2011 trd 4x4 manual
    None yet
    PSA .... NOT offering fully welded spindles anymore due to rising cost ..and shipping cost...only offering weld on pieces just like SO MANY other companies ..bummers!!!
    m00seNUckLEz[OP], djthicks and BOMBS like this.
  12. Mar 12, 2024 at 12:05 PM
    #252
    BOMBS
    BOMBS Well-Known Member
    2017 Black Tacoma TRD Off Road
    Thanks for the info.
  13. Sep 16, 2024 at 6:42 PM
    #253
    m00seNUckLEz
    Fresno, CA
    Under Construction
    Spindle Core exchanges have returned
    BOMBS likes this.
  14. Sep 23, 2024 at 6:33 AM
    #254
    m00seNUckLEz
    Fresno, CA
    Under Construction
    Heavy Duty Spindle gussets welded up and shipping out to SoCal for a 3rdGenTacoma today
    DrewTRD and BOMBS like this.
  15. Feb 1, 2025 at 5:18 PM
    #255
    jkish17
    jkish17 Well-Known Member
    Roseville, CA
    2018 DCLB TRD OR
    -Dobinson’s IMS shocks on C59-354 coils -Dobinson’s rear shocks -Dobinson’s L59-111-R heavy leafs -Wheeler’ off road super bumpstops -Wheeler’s off road U-bolt flip -JBA Upper control arms. -35x12.5r17 Yoko Geo MT’s -17x7.5 4Runner spare steel wheels (Part #42611-35430) -Trailgear 1.5 spacers -C4 fabrication rock sliders -Relentless Fabrication High Clearance Rear Bumper, no swingout. -CBI T3 front plate bumper, no hoop/bullbar. -Ironman 4x4 12,000lb synthetic winch -Victory 4x4 roof rack -China camper from Alibaba -CVC tuned -ExtremeLED lightbars in the roof rack and front bumper. -Baja Squadron's in the rear bumper -MESO customs stuff everywhere -Dobinson’s Zenith air compressor mounted under the hood -Homemade S-pod relay box -Entire sound system replaced and sound deadening added
    I took a camping/wheeling trip up close by Nevada in Markleeville a few weeks ago and ended up bending a spindle. I had one hard hit on the trail and I had a feeling but was still surprised it bent so easily. I didn’t think I was going that hard, but obviously it was enough.
    Did some research when I got home and came across this thread and decided to go this route. Messaged Ryan on here with some questions and he gave me his number. Called him and he happened to have a couple sets welded and ready to go, luckily for me. He had answers to all my questions and I ultimately decided not to do the double shear kit since he had these ready to go already and it seemed excessive for my needs.
    He shipped them out quickly and they arrived packaged nicely. They were wrapped in plastic and buried in this recycled cardboard.
    Here's some comparison shots I took before I did the install. These things are beefy!
    I had never changed one out before but figured it couldn't be too hard. I watched this youtube video and it walks you through step by step with torque specs.
    https://www.youtube.com/watch?v=93xEkLJ1ShA&t=944s
    Install was relatively painless and I didn't have to deal with anything rusted too bad since I live in CA. The rotors were stuck on pretty good but with a little heating from torch and some love from a soft hammer they freed up.
    Unfortunately I got to the point above on the first side and discovered that the holes for the caliper bolts were too big on the new spindles. Called Ryan at 7 at night and he answered right away. Once I told him he said he may have accidently sent me a set from a 4runner which uses slightly larger bolts for the brake caliper. He was very apologetic and sorry for the mix up. So I pulled them off and put the bent one back on. Ryan shipped out another set first thing next morning with a tracking number and they arrived the next day.
    Of course luck would have it I got sick and didn't feel up to putting the new ones on for a week. I finally put the Tacoma ones on and shipped the cores and the 4runner ones back to Ryan.
    A few more pics along the way.
    Don't forget the seals on the back. You may need to order new ones, I was able to reuse mine.
    Overall great experience dealing with Ryan. He took care of me when I was desperate and needed some fast. Then again with the super fast shipping and responsiveness with the mix up. They're painted nicely, welds look good to my amateur eyes, and if I somehow bend these things I think my truck would have a lot more problems going on too. I would recommend these to anyone doing even mild wheeling, the risk of bending the factory ones is high. Save yourself from a headache and being stuck in a crappy situation.
    The only question I have is how are people reattaching the bracket pictured below that holds the brake line? With the thickness of the gussets there's no way it'll fit back on there. I could bend it and make it fit, just thought I'd ask here for any input.
  16. Feb 2, 2025 at 8:23 AM
    #256
    m00seNUckLEz
    Fresno, CA
    Under Construction
    Thanks for the write-up. Glad I was able to get you taken care of :thumbsup:
    BOMBS likes this.
  17. Apr 27, 2025 at 10:11 AM
    #257
    TacoDell60
    TacoDell60 Well-Known Member
    Little head's up for 3rd gen Tacoma folks on stock wheels and sway bar that the RC Fab spindles does not allow you to keep oem wheel offset and will not allow you to keep the sway bar. You need at minimum an offset of +5 ish and there's no way the swaybar can be kept at all.
    Avoid the headache I went through and either go another router altogether or be forced to run different wheels or wheel spacers to gain clearance for the inside of the wheel to not touch the knuckle.
    You'll also be forced to lose the swaybar altogether because the clearances are so tight that the swaybar end links interfere with the knuckle to the point of actually losing turning radius at full steering lock.
    Hopefully this will save someone hundreds of $$ in labor cost and many many hours of their precious time.
    If anyone here has successfully run SR5 or TRD Sport wheels (+24 offset) and were able to keep the swaybar with RC Fab knuckles, please let me know because I do not believe it.
    BOMBS and m00seNUckLEz[OP] like this.
