For Stock Rigs Only
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacoma Mike, Aug 16, 2019.
  1. Mar 28, 2021 at 9:22 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Afternoon to you Bill
    MQQSE and TomTwo[QUOTED] like this.
  2. Mar 28, 2021 at 9:43 AM
    BananaMan
    BananaMan Well-Known Member
    Bumfrick nowhere Maine
    06 2.7 RC 2wd manual "squattytruck"
    Thanks, you as well! Just finishing up wiring the fuel pump, getting ready to stick this whole mess back together next weekend. 1477F260-D886-43E2-A998-4DB3C696A6F0.jpg
  3. Mar 28, 2021 at 10:10 AM
    Tacoma Mike
    Tacoma Mike [OP] 48 Year Chrysler/Toyota/ASE/ Master Tech.RETIRED
    Southern Maine
    Nice
  4. Mar 28, 2021 at 10:36 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
  5. Mar 28, 2021 at 10:42 AM
    Tacoma Mike
    Southern Maine
    Finished up the auger drive shaft
    Needed a little smoothing out for the new bearing/bushing.
    A file and sand paper cures a lot of bad..
  6. Mar 28, 2021 at 11:40 AM
    Plain Jane Taco
    USA
    Nice choices. :thumbsup:
    Maxlife for the slush box in the Camry?
    Delta09[QUOTED] likes this.
  7. Mar 28, 2021 at 11:41 AM
    Plain Jane Taco
    USA
    Awesome :thumbsup:
    BananaMan[QUOTED] likes this.
  8. Mar 28, 2021 at 11:43 AM
    Plain Jane Taco
    USA
    Afternoon Critter
    Taco critter likes this.
  9. Mar 28, 2021 at 11:51 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Yup. Debating on the DIY method and that service might get pushed further into the season depending on the difficulty. Apparently these transmissions don't like to live beyond 100K if never serviced. Even though it just rolled over 30K last coming home, it's 6 years old. A 4-5qt spill and fill should keep it happy. Haven't checked the condition of the fluid, guess I'll have to pop a cooler line to get a small sample. Driving up the mountain is hard as Hell on automatic transmissions, mostly heat.
    The oil choice was all over the place so I just settled for what I think would be good. That an a 3 5qt pack shipped to my door from Wal-Mart was only $65.
  10. Mar 28, 2021 at 12:59 PM
    Yukon DoIt
    Yukon DoIt Opinionated Northerner
    Paul
    Yukon, Canada
    2006 White Tacoma DCLB 4wd Auto, 1988 Blue 4Runner 4wd Manual
    Stock-y
    Hello folks, hope you are having a nice weekend, or had one.
    I'm talking myself off a ledge hearing gurgling behind the dash. It seems while some have associated it with head gaskets, many have had it for a long time with no sense of issues. Gonna try burping and monitoring levels. Also will need to check and see if the water pump is possibly leaking.
    That's the other bittersweet thing about this forum. It makes you want everyone else's truck type, but it also makes you panic at the first sign of symptoms. Hoping it's nothing major, but if it's a head gasket I want to know early so I can do it myself.
    Plain Jane Taco and Delta09 like this.
  11. Mar 28, 2021 at 1:10 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Dunno, sudden air intrusion into the system doesn't sound good at all. If it does come down to the inevitable, remember it's the perfect for other hard to do things like timing chains and guides. Also get the heads completely re-done if you're able to. While it's open might as well. Don't know what kind of winter road treatment is in your part of Canada, but I'd seriously check out the rust on your truck before continuing a major repair like that. Would be a shame to "refresh" the engine to find a hole in the frame 6 months later.
    BassAckwards and Plain Jane Taco like this.
  12. Mar 28, 2021 at 1:21 PM
    Yukon DoIt
    Paul
    Yukon, Canada
    Stock-y
    Yeah, in the Yukon they mostly just sand the roads, not salt it. But I do plan to go under it first, whenever it's dry enough to do so. And it may not be sudden, I've only owned the truck for a month, and up until recently have had to run the fan full blast because of a bad resistor. I suppose I could look at getting the head machined, since I can remove it and just take it or ship it to a shop?
  13. Mar 28, 2021 at 1:26 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    We have several machine shops around here, I just drop them off at the shop. However it seems like you live in a lot more "rural" part of Canada, so that might limit you. Not saying you need to do it, but it's what I would do. I'm a little too anal sometimes.
  14. Mar 28, 2021 at 1:42 PM
    Yukon DoIt
    Paul
    Yukon, Canada
    Stock-y
    I love being anal :lalala:
    But yeah, will have to look into options, this part of the world they are a bit limited for stuff like that. I always have my trusty 4runner if it has to take some time.
  15. Mar 28, 2021 at 1:47 PM
    Venom
    Venom Well-Known Member
    Kevin
    Massachusetts
    I love giving anal, not on the receiving end. :rofl:
    I'm allowed a few bad jokes.
    Delta09 likes this.
  16. Mar 28, 2021 at 1:48 PM
    Yukon DoIt
    Paul
    Yukon, Canada
    Stock-y
    Honestly I was going to tag you, but I figured you'd respond to the bat signal either way...
  17. Mar 28, 2021 at 1:52 PM
    Venom
    Kevin
    Massachusetts
    Delta09 and Yukon DoIt[QUOTED] like this.
  18. Mar 28, 2021 at 2:27 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Here I am trying to be good and you guys are making it impossible. Not taking the bait, nope, no, nope.
    Plain Jane Taco, Venom and Yukon DoIt like this.
  19. Mar 28, 2021 at 2:28 PM
    Yukon DoIt
    Paul
    Yukon, Canada
    Stock-y
    My mind went "Adam said anal, I bet Kevin is going to go after that one. Should I tag him? Nah, I'm sure he'll be here soon."
    Plain Jane Taco likes this.
  20. Mar 28, 2021 at 2:32 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    I didn't even realize where that could have gone where it did when I posted that. I must be off my game; still a little sleep deprived I guess... :rofl:
