For Stock Rigs Only
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacoma Mike, Aug 16, 2019.
  1. Apr 23, 2021 at 3:05 PM
    Trikster
    Trikster Well-Known Member
    Kevin
    2008 Tacoma 4x4 Double Cab
    Hows everyone doing? Long time, no see. Didn't get any notifications from the site for a while, phone died, computer died...lost a couple of friends to cancer...been a rough one. Today, I took Rosie in for an oil change and to look at the driveline (was making some noise, couple bolts came loose). Guy put in an over flow catch bottle, but he forgot to take it out! Got wedged in the fan and the other end pulled the V-belt off the pulley. It came to rest on the timing belt. Thankfully as soon as I heard the buzzing when I turned on the truck, I immediately turned it off. Had I not, they might have owed me a new motor!
    The other thing the guy did is, I think, tweak my drivers chair. It used to be very easy to adjust, not its very hard. If you are looking at the seat from the top, it is no longer square with the steering wheel. Its pointing at 11 o'clock. Anyone elses look like this? Am I remembering it wrong? Does the chair not sit square to the wheel? Oh, and he left a giant dirty handprint on the upholstery and steering wheel. So great... :(
    Plain Jane Taco likes this.
  2. Apr 23, 2021 at 3:07 PM
    Venom
    Venom Well-Known Member
    Kevin
    Massachusetts
    Yukon DoIt and Plain Jane Taco like this.
  3. Apr 23, 2021 at 3:15 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Damn Kevin....sorry to hear about your friends. Not sure about the seat thing
    FlyingWolfe likes this.
  4. Apr 23, 2021 at 3:55 PM
    Trikster
    Kevin
    Yeah. One friend had a softball size tumor right next to his heart, other one had leukemia. Both went within a day of each other. Lost my grandmother in law this afternoon.
    Next time you get in your truck, just take a look at at the two front chairs and see if front of the chair lined up.
  5. Apr 23, 2021 at 4:19 PM
    Yukon DoIt
    Yukon DoIt Opinionated Northerner
    Paul
    Yukon, Canada
    2006 White Tacoma DCLB 4wd Auto, 1988 Blue 4Runner 4wd Manual
    Stock-y
    Looks like a fun road to motorcycle on...
  6. Apr 23, 2021 at 4:24 PM
    Plain Jane Taco
    USA
    Wow...so much loss. So sorry brother.
    I just went and sat in my rig. Nothing seems unsquare
  7. Apr 23, 2021 at 4:25 PM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    New Toy. Was 40% off at HD online. Arrived at store today. 165' laser measurer/ sq footage calculator.
    Trikster, 907rx7 and Plain Jane Taco like this.
  8. Apr 23, 2021 at 5:18 PM
    Plain Jane Taco
    USA
    Nice!
  9. Apr 23, 2021 at 5:24 PM
    Plain Jane Taco
    USA
    Dampers came in. The quality of these things seems stout. Very robust. Was comparing them to the stock Bilstein 4600s on my rig. The bottom spring perch on the Eibachs is at leat twice the thickness of the one on the Bilsteins. And the shank between the bottom bolt mount on the bottom of the strut is way thicker. Anxious to see how they ride.
    Sneak peek:
  10. Apr 23, 2021 at 7:00 PM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Somebody better tag that NSFW!
  11. Apr 23, 2021 at 7:01 PM
    Yukon DoIt
    Paul
    Yukon, Canada
    Stock-y
    Bill is anxious about that girth...
    Plain Jane Taco and BananaMan like this.
  12. Apr 23, 2021 at 7:24 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    :rofl:
  13. Apr 23, 2021 at 8:38 PM
    BananaMan
    BananaMan Well-Known Member
    Bumfrick nowhere Maine
    06 2.7 RC 2wd manual "squattytruck"
    He whipped out the measuring stick really quick...
  14. Apr 23, 2021 at 10:31 PM
    tattooedsnake
    tattooedsnake Well-Known Member
    Erick
    Connecticut
    '10 TRD sport 4x4
    -Bilstein 6112 front shock. Leveling lift -Bilstein 5100 rear shock w/TSB leaf pack. -Cooper Rugged Trek 265/70/17 -EBC front ultimax rotors w/yellow pads -Stoptech sport rear drums -Steel braided brake lines -Wet Okele seat covers front/rear with heaters -Custom built exhaust with Black Widow venom 250 muffler -Afe Stage 2 Dry CAI -Diode dynamics SS3 fog lights yellow. -OPT7 Projector Headlight Assembly w/Black backing -Undercover Flex Tonneau cover -Weather Tech floormats front and back
    130k miles and a happy "congrats" to my taco. New 6112 Bilstein's (1st clip), Taco lean spacer, Stainless steel brake lines, OEM LCA, Camber bolts/hardware , Inner/outer tie rod ends, and all of the OEM nuts and bolts to put it all back together again.
    I got the work done by my local shop who has been working on the truck for a while.
    I got all of the parts fromhttps://toyotaparts.mcgeorgetoyota.com Send them your Vin # and ask for help building a cart.
    I picked up the truck today. Holy Hell the difference is AMAZING!!! The front end feels completely different from all of the new hardware. Planted and responsive, no extra movement when pulling into parking lots and going over speedbumps. The shocks still needs to settle some and soften up but the initial stiffness is not terrible at all.
    Currently sitting at 1.5" lift with it sitting level front and back. I was expecting at least .75" increase in height from the longer shocks and taco lean spacer. I set the shocks on the 1st clip. Once the shock settle I will remeasure.
    Before suspension install.
    1/2 tank of gas from center hub to fender
    FL-19.75"
    RL-21.25"
    FR-20"
    RR-21.5"
    =1.5" rake
    4/23/2021-picked up truck from shop
    FL- 21.5"
    RL- 21.5"
    FR- 21.5"
    RR- 21.5"
    Level truck front and rear w/ 1.5" increase in front height.
    Changing all of the front components at once instead of a bushing hear and there made a drastic difference in feel. Adding the stainless steel break lines are a change that are worth while if you have old rubber lines already. I've only had the truck for a little while and it is great. The shiny new bolts and white stickers don't look to bad either.
    Some new pics.
    Trikster, BananaMan, Delta09 and 3 others like this.
  15. Apr 24, 2021 at 1:28 AM
    Plain Jane Taco
    USA
    Awesome. I see no bro-lean....so you're good to go hanging out here.
    :D
    tattooedsnake[QUOTED] and Sig45 like this.
  16. Apr 24, 2021 at 1:33 AM
    Plain Jane Taco
    USA
    I'll have ample amounts of lubrication handy for proper installation.
    :anonymous:
  17. Apr 24, 2021 at 3:18 AM
    Venom
    Kevin
    Massachusetts
  18. Apr 24, 2021 at 3:19 AM
    Venom
    Kevin
    Massachusetts
    Good morning everyone!
    Taco critter and Plain Jane Taco like this.
  19. Apr 24, 2021 at 3:57 AM
    Plain Jane Taco
    USA
    Good morning Kevin
    Venom[QUOTED] and Taco critter like this.
  20. Apr 24, 2021 at 6:20 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
