For Stock Rigs Only
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacoma Mike, Aug 16, 2019.
  1. May 1, 2021 at 10:45 AM
    kidsmoke
    kidsmoke Well-Known Member
    Flyover Country
    '13 BR AC SR5 4x4 AT
    Picture perfect day on the Maine coast. Working hard cleaning up the campground. 5 kegs of flight deck. Bonfire on the rocks over the water. Family member showed up in his 2001, lives it’s whole life on Cape Cod, and it’s about rusted through its 2nd frame. 4B46009C-8D85-4D51-AFBB-1CB0BFF23A59.jpg97E49EE6-7658-47E4-8215-D2E9C9480F2F.jpg
  2. May 1, 2021 at 12:16 PM
    kidsmoke
    Flyover Country
  3. May 1, 2021 at 2:29 PM
    Venom
    Venom Well-Known Member
    Kevin
    Massachusetts
    Sunny, windy and 60 degrees. Better than rain.
  4. May 1, 2021 at 2:31 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    That's beautiful
    Venom likes this.
  5. May 1, 2021 at 2:32 PM
    Venom
    Kevin
    Massachusetts
    @Plain Jane Taco
    Do you have any pictures of the fire pit? Cleaned and empty.
    I'm looking for ideas on fire pit designs.
    Plain Jane Taco likes this.
  6. May 1, 2021 at 3:10 PM
    Plain Jane Taco
    USA
  7. May 1, 2021 at 3:45 PM
    Venom
    Kevin
    Massachusetts
    Thank You!
    Is there anything under the steel bowl?
    Do you have to use pavers as a base?
  8. May 1, 2021 at 3:45 PM
    lynyrd3
    Bill
    East Central Upstate NY
    Derby time :fingerscrossed:
  9. May 1, 2021 at 4:21 PM
    Plain Jane Taco
    USA
    The basic set up is just 36 curved landscape blocks with a 36" steel firepit bowl without the legs. Very simple. What you place it on is completely up to you. You certainly don't have to use pavers....or anything for that matter.
    I wanted a very solid, level base for it to sit on though. So I used 9 16"×16" pavers as the base....basically a 4'×4' square.
    I cut out the 4x4 square and dug down 4" and leveled it as much as possible. Then I laid down a couple of layers of weed mat. Next I added 2" of compacted and leveled paver stone, followed by 1" of compacted and leveled paver sand. Then I laid down the 16×16 pavers.....which are about an inch thick. This brought me up to ground level. And just to make sure there would be no migration it's all locked together with paver lock around the perimeter....under the soil.
    Next I filled in the spaces between the pavers with sand.....a lot like grouting tile. Then it's just a matter of laying down the 36 landscape blocks.
  10. May 1, 2021 at 4:39 PM
    Venom
    Kevin
    Massachusetts
    What is the overall height? I want it high enough that it doesn't become a trip hazard.
    What do you think about stamped concrete as a base instead of pavers, pros/cons, if any?
    Did you use any concrete adhesive to lock the fire pit blocks?
  11. May 1, 2021 at 4:45 PM
    VooDooBob
    VooDooBob Sitting on pins and needles.
    Robert
    21 VDB Off-Road
    Nice grass.
  12. May 1, 2021 at 4:50 PM
    Plain Jane Taco
    USA
    You can build it as low or high as you want. 3 rings seemed right for me. It's certainly not a trip hazard at that height. It's very obvious it's there.
    No adhesive. The whole thing as a unit is quite heavy. In the 5 years I've had it nothing as moved at all. That said....you could use construction adhesive if you wanted.
    Not sure what the height is. Less than 18" I would guess.
    Don't know what stamped concrete is....or at least not by that name
    Venom[QUOTED] and Sig45 like this.
  13. May 1, 2021 at 4:53 PM
    Plain Jane Taco
    USA
    Thanks Rob. It's kinda my thing. Yard work it relaxing for me. Yeah....I'm weird.
    It started years ago with wanting a clean, soft place for my kids to play. They're older now. But I still have it as a "hobby".
    :anonymous:
  14. May 1, 2021 at 5:06 PM
    Plain Jane Taco
    USA
    Both are well kept :D
    Taco critter and VooDooBob like this.
  15. May 1, 2021 at 5:18 PM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Ohhhh reallllly......
  16. May 1, 2021 at 5:20 PM
    VooDooBob
    Robert
    21 VDB Off-Road
    That didn’t take long.
  17. May 1, 2021 at 5:55 PM
    Plain Jane Taco
    USA
    Delta09[QUOTED], Sig45 and VooDooBob like this.
  18. May 1, 2021 at 6:09 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Yanno I've heard that several times before :rofl:
    Aiight, I gotta stop. The guys are looking at me like I'm nuts. :rofl:
  19. May 1, 2021 at 6:34 PM
    VooDooBob
    Robert
    21 VDB Off-Road
    I would boycott this thread if you stopped.
  20. May 2, 2021 at 1:28 AM
    Venom
    Kevin
    Massachusetts
    I'm just getting ideas right now. Thanks for your input, it's appreciated.
    This is what I mean by stamped concrete.
    Stamped concrete is the only term I know for this procedure.
